[Swift-commit] r3453 - branches/tests-01/tests
Wed Jul 21 16:25:39 CDT 2010
Author: wozniak
Date: 2010-07-21 16:25:38 -0500 (Wed, 21 Jul 2010)
New Revision: 3453
Modified:
   branches/tests-01/tests/nightly.sh
Log:
Modifications to nightly.sh
Modified: branches/tests-01/tests/nightly.sh
--- branches/tests-01/tests/nightly.sh	2010-07-21 21:23:03 UTC (rev 3452)
+++ branches/tests-01/tests/nightly.sh	2010-07-21 21:25:38 UTC (rev 3453)
@@ -1,85 +1,95 @@
 #!/bin/bash
-OUTDIR=$PWD
-LOGCOUNT=0
-SEQ=1
-DATE=`date +"%Y-%m-%d"`
-TIME=`date +"%T %Z(%z)"`
-RUNDIRBASE="run-$DATE"
-RUNDIR=$OUTDIR/$RUNDIRBASE
-mkdir -p $RUNDIR
+# set -x
-OUTBASE=$RUNDIRBASE/tests.log
+# USAGE NOTES:
+# Run nightly.sh -h for quick help
+# When something goes wrong, find and check tests.log
+# Code is checked out into TOPDIR
+# Swift is installed in its source tree
+# The run is executed in RUNDIR (TOPDIR/RUNDIRBASE)
+# The build test is started in TOPDIR
+# Everything for a Swift test is written in its RUNDIR
+# The temporary output always goes to OUTPUT (TOPDIR/exec.out)
-BRANCH="branches/tests-01"
+printhelp() {
+  echo "nightly.sh <options> <output>"
+  echo ""
+  echo "usage:"
+  printf "\t -c      Do not clean                    \n"
+  printf "\t -g      Do not run grid tests           \n"
+  printf "\t -h      This message                    \n"
+  printf "\t -p      Do not build the package        \n"
+  printf "\t -s      Do not do a fresh svn checkout  \n"
+  printf "\t -x      Do not continue after a failure \n"
+  printf "\t output  Location for output (TOPDIR)    \n"
+# Defaults:
+CLEAN=1
+BUILD_PACKAGE=1
+GRID_TESTS=1
+SKIP_CHECKOUT=0
+ALWAYS_EXITONFAILURE=0
+# The directory in which to start:
+TOPDIR=$PWD
 while [ $# -gt 0 ]; do
   case $1 in
+    -c)
+      CLEAN=0
+      shift;;
+    -g)
+      GRID_TESTS=0
+      shift;;
+    -h)
+      printhelp
+      exit 0;;
+    -p)
+      BUILD_PACKAGE=0
+      shift;;
     -s)
       SKIP_CHECKOUT=1
       shift;;
     -x)
-      EXIT_ON_ERROR=1
+      ALWAYS_EXITONFAILURE=1
       shift;;
-      OUTBASE=$RUNDIRBASE/$1
+      TOPDIR=$1
       shift;;
   esac
 done
-OUT=$OUTDIR/$OUTBASE
+LOGCOUNT=0
+SEQ=1
+DATE=$( date +"%Y-%m-%d" )
+TIME=$( date +"%T" )
+RUNDIRBASE="run-$DATE"
+RUNDIR=$TOPDIR/$RUNDIRBASE
+LOGBASE=$RUNDIRBASE/tests.log
+LOG=$TOPDIR/$LOGBASE
+OUTPUT=$TOPDIR/exec.out
+HTMLPATH=$RUNDIRBASE/tests-$DATE.html
+HTML=$TOPDIR/$HTMLPATH
+BRANCH="branches/tests-01"
+SCRIPTDIR=$( dirname $0 )
+cd $TOPDIR
+mkdir -p $RUNDIR
+[ $? != 0 ] && echo "Could not mkdir: $RUNDIR" && exit 1
 header() {
-	HTMLBASE=tests-$DATE.html
-	HTML=$OUTDIR/$HTMLBASE
-	rm -f $OUTDIR/current.html
+        CURRENT=$SCRIPTDIR/html/current.html
+	sed "s at _HTMLBASE_@$HTMLPATH@" < $CURRENT > $TOPDIR/current.html
-	#This doesn't work well with servers that don't follow symlinks
-	#ln -s $HTML $OUTDIR/current.html
-	cat <<DOH >$OUTDIR/current.html
-<html>
-	<head>
-		<title>Redirecting...</title>
-		<meta http-equiv="cache-control" content="no-cache">
-		<script language="JavaScript">
-			function redirect() {
-				window.location="$HTMLBASE";
-		</script>
-	</head>
-	<body onLoad="redirect()">
-		You should be redirected to <a href="$HTMLBASE">$HTMLBASE</a>
-	</body>
-</html>
-DOH
-	cat <<DOH >$HTML
-<html>
-	<head>
-		<title>Swift nightly integration tests and build ($DATE $TIME)</title>
-		<style type="text/css">
-			a:link {color:black}
-			a:visited {color:black}
-			td.success {background: #60ff00; text-align: center;}
-			td.failure {background: #ff6000; text-align: center;}
-			tr.testline {background: #e0e0e0}
-			tr.part {background: #c0c0c0; text-align: center; font-size: large;}
-		</style>
-	</head>
-	<body>
-	<h1>Swift nightly integration tests and build</h1>
-	<ul>
-	  <li>Date: $DATE</li>
-	  <li>Time: $TIME</li>
-	  <li>Test host: $(hostname)</li>
-	</ul>
-	<ol>
-		<li><a href="#tests">Test results</a>
-		<li><a href="#packages">Compiled packages</a>
-		<li><a href="#older">Older tests</a>
-		<li><a href="addtests.html">How to add new tests</a>
-	</ol>
-DOH
+        HEADER=$SCRIPTDIR/html/header.html
+        HOST=$( hostname )
+        SEDCMD="s/_DATE_/$DATE/;s/_TIME_/$TIME/;s/_HOST_/$HOST"/
+	sed $SEDCMD < $HEADER > $HTML
 	FIRSTTEST=1
@@ -87,12 +97,24 @@
 	echo $@ >>$HTML
+a_name() {
+  NAME=$1
+  html "<a name=\"$NAME\">"
+a_href() {
+  HREF=$1
+  TEXT=$2
+  html "<a href=\"$HREF\">$TEXT</a>"
 footer() {
-	MONTHS=("" "Jan" "Feb" "Mar" "Apr" "May" "Jun" "Jul" "Aug" "Sep" "Oct" "Nov" "Dec")
+	MONTHS=("" "Jan" "Feb" "Mar" "Apr" "May" "Jun" \
+                   "Jul" "Aug" "Sep" "Oct" "Nov" "Dec")
 	html "</tr></table></tr></table>"
 	if [ "$BINPACKAGE" != "" ]; then
-		FBP=$OUTDIR/$BINPACKAGE
+		FBP=$RUNDIR/$BINPACKAGE
 		SIZE=`ls -hs $FBP`
 		SIZE=${SIZE/$FBP}
 		cat <<DOH >>$HTML
@@ -148,7 +170,6 @@
 DOH
 outecho() {
 	TYPE=$1
 	shift
@@ -156,7 +177,7 @@
 out() {
-	echo $@
+        # echo $@
 	TYPE=$1
 	if [ "$TYPE" == "test" ]; then
@@ -164,12 +185,11 @@
 		SEQ=$3
 		CMD=$4
 		RES=$5
-		LOG=$6
 		if [ "$FIRSTTEST" == "1" ]; then
 			html "<h1>Test results</h1>"
-			html "<a name=\"tests\">"
-			html "<a href=\"$OUTBASE\">Output log from tests</a>"
+                        a_name "tests"
+			a_href "tests.log" "Output log from tests"
 			html "<table border=\"0\">"
 			FIRSTTEST=0
 		else
@@ -193,10 +213,12 @@
 		fi
 		if [ "$RES" == "Passed" ]; then
 			html "<td class=\"success\" $WIDTH title=\"$CMD\">"
-			html "<a href=\"$LOG\">$SEQ</a>"
+			html "<a href=\"$TLOG\">$SEQ</a>"
 		else
+                        echo "FAILED"
+                        cat $TLOG < /dev/null
 			html "<td class=\"failure\" $WIDTH title=\"$CMD\">"
 		fi
 		html "</td>"
@@ -208,30 +230,33 @@
 aexec() {
-	echo Executing "$@" >>$OUT
-	rm -f $OUTDIR/x73010test.log
+        declare -p PWD
+	echo "Executing: $@" >>$LOG
+	rm -fv $OUTPUT
 	LASTCMD="$@"
-	"$@" >$OUTDIR/x73010test.log 2>&1
+	"$@" > $OUTPUT 2>&1
+        head $OUTPUT
 	EXITCODE=$?
 	if [ "$EXITCODE" == "127" ]; then
-		echo "Command not found: $@" >$OUTDIR/x73010test.log
+		echo "Command not found: $@" > $OUTPUT
 	fi
-	if [ -f $OUTDIR/x73010test.log ]; then
-		cat $OUTDIR/x73010test.log >>$OUT
+	if [ -f $OUTPUT ]; then
+		cat $OUTPUT >>$LOG
 	fi
+# TLOG = this (current) log
 tlog() {
 	TLOG="output_$LOGCOUNT.txt"
-	rm -f $RUNDIR/$TLOG
+	rm -fv $TLOG
 	banner "$LASTCMD" $RUNDIR/$TLOG
-		cat $OUTDIR/x73010test.log >>$RUNDIR/$TLOG 2>>$OUT
+		cp -v $OUTPUT $RUNDIR/$TLOG 2>>$LOG
 	fi
-	TLOG="$RUNDIRBASE/$TLOG"
 	let "LOGCOUNT=$LOGCOUNT+1"
+# Fake exec
 fexec() {
 	FLUSH=1
 	banner "$TEST (faked)"
@@ -241,18 +266,29 @@
 	vtest
+stars() {
+  for i in {1..90}
+  do
+    printf "*"
+  done
+  echo
 banner() {
 	if [ "$2" == "" ]; then
-		BOUT=$OUT
+		BOUT=$LOG
 	else
 		BOUT=$2
 	fi
-	echo "">>$BOUT
-	echo "*****************************************************************************************">>$BOUT
-	echo "* $1" >>$BOUT
+	  echo ""
+          # stars
+	  echo "* $1"
+	  # stars
+        } >>$BOUT
+# Execute as part of test set
 pexec() {
 	banner "$TEST (part $SEQ)"
 	echo "Executing $TEST (part $SEQ)"
@@ -274,6 +310,7 @@
 	FLUSH=0
+# Execute final test in set
 vexec() {
 	if [ "$SEQ" == "1" ]; then
 		banner "$TEST"
@@ -295,10 +332,10 @@
 		RES="Failed"
 	fi
 	tlog
-	out test "$TEST" $SEQ "$LASTCMD" $RES $TLOG
+	out test "$TESTLINK" $SEQ "$LASTCMD" $RES $TLOG
 	if [ "$EXITONFAILURE" == "true" ]; then
 		if [ "$EXITCODE" != "0" ]; then
-			exit
+			exit $EXITCODE
 		fi
 	fi
@@ -311,18 +348,29 @@
 		RES="Failed"
 	fi
 	tlog
-			exit
+			exit $EXITCODE
 		fi
 	fi
-date > $OUT
+build_package() {
+  TEST="Package"
+  pexec cd $SWIFT_HOME/lib
+  pexec rm -f castor*.jar *gt2ft*.jar ant.jar
+  pexec cd $TOPDIR
+  vexec tar -pczf $RUNDIR/swift-$DATE.tar.gz $SWIFT_HOME
+  out package "swift-$DATE.tar.gz"
+date > $LOG
 FLUSH=1
-head
+header
+cd $TOPDIR
 TESTPART="Part I: Build"
 EXITONFAILURE=true
 if [ "$SKIP_CHECKOUT" != "1" ]; then
@@ -335,48 +383,49 @@
         pexec cd cog/modules
 	pexec rm -rf swift
 	vexec svn co https://svn.ci.uchicago.edu/svn/vdl2/$BRANCH swift
-        pexec cd $OUTDIR
 fi
 TEST="Compile"
-pexec cd cog/modules/swift
-pexec rm -rf dist
+pexec cd $TOPDIR/cog/modules/swift
+if [ $CLEAN == "1" ]; then
+  pexec rm -rf dist
+fi
 vexec ant -quiet dist
+SWIFT_HOME=$TOPDIR/cog/modules/swift/dist/swift-svn
-TEST="Package"
-pexec cd dist
-SWIFT=$( ls -d swift-* )
-pexec cd $SWIFT/lib
-pexec rm -f castor*.jar *gt2ft*.jar ant.jar
-pexec cd ../..
-pexec rm -rf swift-$DATE
-pexec mv $SWIFT swift-$DATE
-vexec tar -pczf $OUTDIR/swift-$DATE.tar.gz swift-$DATE
-out package "swift-$DATE.tar.gz"
+if [ $BUILD_PACKAGE = "1" ]; then
+  build_package
+fi
-PATH=$PWD/swift-$DATE/bin:$PATH
-cd ..
-TESTDIR=$PWD/tests
-echo "Path: $PATH" >>$OUT
+PATH=$SWIFT_HOME/bin:$PATH
+cd $TOPDIR
+which swift
+TESTDIR=$TOPDIR/cog/modules/swift/tests
 cd $RUNDIR
-EXITONFAILURE=false
+if [ $ALWAYS_EXITONFAILURE != "1" ]; then
+    EXITONFAILURE=false
+fi
 TESTPART="Part II: Local Tests"
 for TEST in $( ls $TESTDIR/*.swift ); do # $TESTDIR/*.dtm
   TESTNAME=$( basename $TEST)
-  echo TESTNAME: $TESTNAME
+  echo TESTNAME: $TESTNAME $TESTDIR/$TESTNAME
   cp -uv $TESTDIR/$TESTNAME .
+  sed "s at _WORK_@$PWD/work@" < $TESTDIR/sites/localhost.xml > sites.xml
-  TEST="<a href=\"$RUNDIRBASE/$TESTNAME\">$TESTNAME</a>"
+  TESTLINK="<a href=\"$TESTNAME\">$TESTNAME</a>"
-  # ssexec "Compile" vdlc $BN
   for ((i=0; $i<9; i=$i+1)); do
-    pexec swift -sites.file ~/.vdl2/sites-local.xml $TESTNAME
+    pexec swift -sites.file sites.xml $TESTNAME
   done
-  vexec swift -sites.file ~/.vdl2/sites-local.xml $TESTNAME
+  vexec swift -sites.file sites.xml $TESTNAME
 done
+if [ $GRID_TESTS == "0" ]; then
+  exit
+fi
 TESTPART="Part III: Grid Tests"
 for TEST in `ls $TESTDIR/*.dtm $TESTDIR/*.swift`; do
