[Swift-commit] r3427 - usertools/swift/swiftconfig/bin
noreply at svn.ci.uchicago.edu
Tue Jul 6 03:22:26 CDT 2010
Author: davidk
Date: 2010-07-06 03:22:26 -0500 (Tue, 06 Jul 2010)
New Revision: 3427
Modified:
usertools/swift/swiftconfig/bin/swiftconfig
Log:
perldoc
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig 2010-07-05 08:31:54 UTC (rev 3426)
+++ usertools/swift/swiftconfig/bin/swiftconfig 2010-07-06 08:22:26 UTC (rev 3427)
@@ -52,7 +52,6 @@
'platform=s' => \$platform,
'profile=s' => \$profile,
'tcfile=s' => \$tcfile,
- 'overwrite' => \$overwrite,
'templatefile=s' => \$templatefile,
'add=s' => \$add,
'sitesfile=s' => \$sitesfile,
@@ -68,7 +67,6 @@
'remove=s' => \$remove,
'templates' => \$templates,
'modify=s' => \$modify,
- 'profile=s' => \$profile,
'key=s' => \$key,
'namespace=s' => \$namespace,
'value=s' => \$value
@@ -253,3 +251,79 @@
write_file( $tcfile, @tcdata );
+__END__
+=head1 NAME
+swiftconfig - Utility for managing Swift configuration
+=head1 SYNOPSIS
+swiftconfig [B<-option> value]
+=head1 OVERVIEW
+The swiftconfig program allows users to configure Swift. It allows for the adding, removing, and modification of remote sites by utilizing a set of standard templates. It also provides a way to quickly add, remove and modify translation catalog entries without having to manually edit files.
+=head1 DESCRIPTION
+General operations:
+ -add sitename add a site from template
+ -remove site removes a site from sites.xml
+ -remove command removes a command from the catalog
+ -templates display all available sites in template
+ -modify site Specifies the name of a site to modify
+Translation catalog settings:
+ -host hostname hostname of the translation catalog entry
+ -name name translation name
+ -path path full pathname to location of program
+ -status status installation status (deprecated)
+ -profile setting define the profile value for an entry
+ -tcfile filename explicitly specify a translation file
+Sites settings:
+ -templatefile file explicitly set the template file to use
+ -sitesfile file explicitly set the sites file to use
+ -gridftp GridFTPURL GridFTP URL
+ -jobuniverse universe job manager universe
+ -joburl URL job manager URL
+ -jobmajor major job mager number
+ -jobminor minor job minor number
+ -directory dir work directory
+ -exprovider name execution provider
+ -exmanager name execution job manager
+ -exurl URL execution URL
+ -key key profile key
+ -value value profile value
+ -namespace name profile namespace
+=head1 EXAMPLES
+List all templates available for adding
+ swiftconfig -templates
+Add a site from template into working sites.xml
+ swiftconfig -add teraport
+Modify the work directory of a site
+ swiftconfig -modify teraport -directory /var/tmp
+Remove a site
+ swiftconfig -remove teraport
+Add a new command to translation catalog
+ swiftconfig -name convert -path /usr/local/bin/convert
+Modify an existing command in the translation catalog
+ swiftconfig -name convert -path /usr/bin/convert
+Remove a command from the translation catalog
+ swiftconfig -remove convert
+=head1 CAVEATS
+Swiftconfig will attempt to automatically determine the location of swift configuration files. It first checks for an environment variable called $SWIFT_HOME. If that is not found, it will look for the location of "swift" in the path, and try to find the configuration files from there. This default behavior can be overwridden by manually specifying the location of files with -templatefile, -sitesfile, and -tcfile.
+The XML library that swiftconfig uses ignores comments in XML. All comments will be stripped from sites.xml as it gets modified.
+=cut
More information about the Swift-commit
