[Swift-commit] r3426 - in usertools/swift/swiftconfig: bin etc
noreply at svn.ci.uchicago.edu
Mon Jul 5 03:31:55 CDT 2010
Author: davidk
Date: 2010-07-05 03:31:54 -0500 (Mon, 05 Jul 2010)
New Revision: 3426
Modified:
usertools/swift/swiftconfig/bin/swiftconfig
usertools/swift/swiftconfig/etc/sites-template.xml
Log:
/home/david replacement in templates, site profiles, tc command removals
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig 2010-07-02 15:57:21 UTC (rev 3425)
+++ usertools/swift/swiftconfig/bin/swiftconfig 2010-07-05 08:31:54 UTC (rev 3426)
@@ -1,223 +1,255 @@
#!/usr/bin/perl
# Find swift configuration files and libraries
-if($ENV{'SWIFT_HOME'})
- $swifthome = $ENV{'SWIFT_HOME'};
+if ( $ENV{'SWIFT_HOME'} ) {
+ $swifthome = $ENV{'SWIFT_HOME'};
-else
- @path = split('/', which("swift"));
- @path = splice(@path, 0, $#path-1);
- $swifthome = join('/', @path);
+else {
+ @path = split( '/', which("swift") );
+ @path = splice( @path, 0, $#path - 1 );
+ $swifthome = join( '/', @path );
-use FindBin;
-use lib "$FindBin::Bin/../lib/perl"; # Use libraries in $swifthome/lib/perl
+use FindBin;
+use lib "$FindBin::Bin/../lib/perl"; # Use libraries in $swifthome/lib/perl
use Getopt::Long;
use File::Which qw(which where);
use XML::Simple;
# Variables used for translation catalog
-my $host = 'localhost'; # Host name
-my $name = ''; # Translation name
-my $path = 'null'; # Full path of executable location
-my $status = 'INSTALLED'; # Installation status (not used)
-my $platform = 'INTEL32::LINUX'; # Platform (not used)
-my $profile = 'null'; # Profile entries
-my $tcfile = "$swifthome/etc/tc.data"; # Location of TC file
+my $host = 'localhost'; # Host name
+my $name = ''; # Translation name
+my $path = "/usr/bin/$name"; # Full path of executable location
+my $status = 'INSTALLED'; # Installation status (not used)
+my $platform = 'INTEL32::LINUX'; # Platform (not used)
+my $profile = 'null'; # Profile entries
+my $tcfile = "$swifthome/etc/tc.data"; # Location of TC file
# Variables used for sites.xml
-my $templatefile = "$swifthome/etc/sites-template.xml"; # Template file
-my $template = ''; # Use template entry
-my $templates = 0; # List all templates
-my $sitesfile = "$swifthome/etc/sites.xml"; # Working sites.xml file
-my $entry = ''; # Name of new entry (pool handle)
-my $gridftp = ''; # Specify gridftp URL
-my $jobuniverse = ''; # Specify jobmanager universe
-my $joburl = ''; # Specify jobmanager URL
-my $jobmajor = ''; # Jobmanager major value
-my $jobminor = ''; # Jobmanager minor value
-my $directory = ''; # Work directory
-my $exprovider = ''; # Execution provider
-my $exmanager = ''; # Execution job manager
-my $exurl = ''; # Execution URL
-my $remove = ''; # Remove entry from sites.xml
-my $modify = ''; # Modify mode
+my $templatefile = "$swifthome/etc/sites-template.xml"; # Template file
+my $template = ''; # Use template entry
+my $templates = 0; # List all templates
+my $sitesfile = "$swifthome/etc/sites.xml"; # Working sites.xml file
+my $entry = ''; # Name of new entry (pool handle)
+my $gridftp = ''; # Specify gridftp URL
+my $jobuniverse = ''; # Specify jobmanager universe
+my $joburl = ''; # Specify jobmanager URL
+my $jobmajor = ''; # Jobmanager major value
+my $jobminor = ''; # Jobmanager minor value
+my $directory = ''; # Work directory
+my $exprovider = ''; # Execution provider
+my $exmanager = ''; # Execution job manager
+my $exurl = ''; # Execution URL
+my $remove = ''; # Remove entry from sites.xml
+my $modify = ''; # Modify mode
# Assign variables from command line options
GetOptions(
- 'host=s' => \$host,
- 'name=s' => \$name,
- 'path=s' => \$path,
- 'status=s' => \$status,
- 'platform=s' => \$platform,
- 'profile=s' => \$profile,
- 'tcfile=s' => \$tcfile,
- 'overwrite' => \$overwrite,
- 'templatefile=s' => \$templatefile,
- 'add=s' => \$add,
- 'sitesfile=s' => \$sitesfile,
- 'gridftp=s' => \$gridftp,
- 'jobuniverse=s' => \$jobuniverse,
- 'joburl=s' => \$joburl,
- 'jobmajor=i' => \$jobmajor,
- 'jobminor=i' => \$jobminor,
- 'directory=s' => \$directory,
- 'exprovider=s' => \$exprovider,
- 'exmanager=s' => \$exmanager,
- 'exurl=s' => \$exurl,
- 'remove=s' => \$remove,
- 'templates' => \$templates,
- 'modify=s' => \$modify
+ 'host=s' => \$host,
+ 'name=s' => \$name,
+ 'path=s' => \$path,
+ 'status=s' => \$status,
+ 'platform=s' => \$platform,
+ 'profile=s' => \$profile,
+ 'tcfile=s' => \$tcfile,
+ 'overwrite' => \$overwrite,
+ 'templatefile=s' => \$templatefile,
+ 'add=s' => \$add,
+ 'sitesfile=s' => \$sitesfile,
+ 'gridftp=s' => \$gridftp,
+ 'jobuniverse=s' => \$jobuniverse,
+ 'joburl=s' => \$joburl,
+ 'jobmajor=i' => \$jobmajor,
+ 'jobminor=i' => \$jobminor,
+ 'directory=s' => \$directory,
+ 'exprovider=s' => \$exprovider,
+ 'exmanager=s' => \$exmanager,
+ 'exurl=s' => \$exurl,
+ 'remove=s' => \$remove,
+ 'templates' => \$templates,
+ 'modify=s' => \$modify,
+ 'key=s' => \$key,
+ 'namespace=s' => \$namespace,
+ 'value=s' => \$value
-$xml = new XML::Simple();
+# Prepare data
+$xml = new XML::Simple();
+$template_data = $xml->XMLin(
+ "$templatefile",
+ ForceArray => [qw(workdirectory pool profile)],
+ KeyAttr => []
+$sites_data = $xml->XMLin(
+ "$sitesfile",
+ KeyAttr => []
+open( TCFILESTREAM, "$tcfile" ) or die("Unable to open tc file $tcfile!");
+ at tcdata = <TCFILESTREAM>;
+close(TCFILESTREAM);
# Update XML hash with values from command line
-sub update_xml_entry
- my $xml_data = @_[0];
- my $name = @_[1];
- foreach my $e (@{$xml_data->{pool}})
- if($name eq $e->{handle})
- if($gridftp){ $e->{gridftp}{url} = $gridftp; }
- if($jobuniverse){ $e->{jobmanager}{universe} = $jobuniverse; }
- if($joburl){ $e->{jobmanager}{url} = $joburl; }
- if($jobmajor){ $e->{jobmanager}{major} = $jobmajor; }
- if($jobminor){ $e->{jobmanager}{minor} = $jobminor; }
- if($directory){ $e->{workdirectory} = [$directory]; }
- if($exprovider){ $e->{execution}{provider} = $exprovider; }
- if($exmanager){ $e->{execution}{jobmanager} = $exmanager; }
- if($exurl){ $e->{execution}{url} = $exurl; }
- return $e;
+sub update_xml_entry {
+ my $xml_data = @_[0];
+ my $name = @_[1];
+ foreach my $e ( @{ $xml_data->{pool} } ) {
+ if ( $name eq $e->{handle} ) {
+ $e->{workdirectory}[0] =~ s/\$HOME/$ENV{'HOME'}/;
+ if ($gridftp) { $e->{gridftp}{url} = $gridftp; }
+ if ($jobuniverse) { $e->{jobmanager}{universe} = $jobuniverse; }
+ if ($joburl) { $e->{jobmanager}{url} = $joburl; }
+ if ($jobmajor) { $e->{jobmanager}{major} = $jobmajor; }
+ if ($jobminor) { $e->{jobmanager}{minor} = $jobminor; }
+ if ($directory) { $e->{workdirectory} = [$directory]; }
+ if ($exprovider) { $e->{execution}{provider} = $exprovider; }
+ if ($exmanager) { $e->{execution}{jobmanager} = $exmanager; }
+ if ($exurl) { $e->{execution}{url} = $exurl; }
+ if ( $key && $namespace && $value ) {
+ my $found = 0;
+ foreach my $profile ( @{ $e->{profile} } ) {
+ if ( $profile->{key} eq $key ) {
+ $profile->{key} = $key;
+ $profile->{namespace} = $namespace;
+ $profile->{content} = $value;
+ $found = 1;
+ if ( !$found ) {
+ push @{ $e->{profile} },
+ key => $key,
+ namespace => $namespace,
+ content => $value
+ return $e;
# Write a file given variable and filename
-sub write_file
- my ($filename, @data) = @_;
- open(TEMPFILESTREAM, ">$filename") or die("Unable to open $filename!\n");
- print TEMPFILESTREAM @data;
- close(TEMPFILESTREAM);
+sub write_file {
+ my ( $filename, @data ) = @_;
+ open( TEMPFILESTREAM, ">$filename" ) or die("Unable to open $filename!\n");
+ print TEMPFILESTREAM @data;
+ close(TEMPFILESTREAM);
# If a template is specified, find the correct one and modify as needed
-if($add)
- $data = $xml->XMLin("$templatefile", ForceArray => [qw(workdirectory pool)]);
- $data = update_xml_entry($data, $add);
+if ($add) {
+ my $data = update_xml_entry( $template_data, $add );
- # Modify entry if one already exists
- $isfound = 0;
- $data2 = $xml->XMLin("$sitesfile", ForceArray => [qw(workdirectory pool)]);
- foreach my $e (@{$data2->{pool}})
- if($add eq $e->{handle})
- $e = $data;
- $isfound = 1;
+ # Modify existing entry
+ my $isfound = 0;
+ foreach my $e ( @{ $sites_data->{pool} } ) {
+ if ( $add eq $e->{handle} ) {
+ $e = $data;
+ $isfound = 1;
- # Add a new entry if needed
- if(!$isfound)
- push @{$data2->{pool}}, $data;
+ # Add new entry
+ if ( !$isfound ) {
+ push @{ $sites_data->{pool} }, $data;
- # Write to sites file
- write_file($sitesfile, $xml->XMLout($data2, RootName => 'config'));
+ # Write to sites file
+ write_file( $sitesfile, $xml->XMLout( $sites_data, RootName => 'config' ) );
# Remove an entry
-if($remove)
- $isfound=0;
- $data = $xml->XMLin("$sitesfile", ForceArray => [qw(workdirectory pool)], SuppressEmpty => 1);
- foreach my $e (@{$data->{pool}})
- if($remove eq $e->{handle})
- undef $e;
- $isfound = 1;
+if ($remove) {
- if($isfound)
- write_file($sitesfile, $xml->XMLout($data, RootName => 'config', SuppressEmpty => 1));
+ # Look first for a site to remove
+ $isfound = 0;
+ if ( $remove eq $e->{handle} ) {
+ undef $e;
+ $isfound = 1;
+ if ($isfound) {
+ write_file(
+ $sitesfile,
+ $xml->XMLout(
+ $sites_data,
+ RootName => 'config',
+ SuppressEmpty => 1
+ # If no site found, check for a TC entry
+ else {
+ foreach $line (@tcdata) {
+ # Ignore comments
+ if ( substr( $line, 0, 1 ) eq '#' ) {
+ next;
+ ( $tmphost, $tmpname, @junk ) = split( /\s+/, $line );
+ # Replace old entry with new entry
+ if ( $remove eq $tmpname ) {
+ $line = "";
+ write_file( $tcfile, @tcdata );
# List all available templates
-if($templates)
- print $e->{handle} . "\n";
+if ($templates) {
+ foreach my $e ( @{ $template_data->{pool} } ) {
+ print $e->{handle} . "\n";
-# Modify an entry
-if($modify)
- $data = $xml->XMLin("$sitesfile", ForceArray => [qw(workdirectory pool)]);
- $data2 = update_xml_entry($data, $modify);
+# Modify a site entry
+if ($modify) {
+ my $data = update_xml_entry( $sites_data, $modify );
- if($modify eq $e->{handle})
- $e = $data2;
- $isfound = 1;
+ # Modify entry if one already exists
+ if ( $modify eq $e->{handle} ) {
+ $e = $data;
+ $xml->XMLout( $sites_data, RootName => 'config', SuppressEmpty => 1 ) );
-# Add an entry to tc.data
-if($name)
- open(TCFILESTREAM, "$tcfile") or die("Unable to open tc file $tcfile!");
- @TCDATA = <TCFILESTREAM>;
- close(TCFILESTREAM);
+# Add or modify a TC entry
+if ($name) {
- foreach $line (@TCDATA)
- # Ignore comments
- if(substr($line, 0, 1) eq '#')
- $line = "";
- next;
- ($tmphost, $tmpname, @junk) = split(/\s+/, $line);
- # Replace old entry with new entry
- if($name eq $tmpname && $host eq $tmphost)
- $isfound=1;
- $line = "\n$host\t$name\t$path\t$status\t$platform\t$profile\n";
+ # Ignore comments
+ next;
- # Add new entry
- if(!$isfound)
- push(@TCDATA, "\n$host\t$name\t$path\t$status\t$platform\t$profile\n")
+ if ( $name eq $tmpname && $host eq $tmphost ) {
+ $isfound = 1;
+ $line = "$host\t$name\t$path\t$status\t$platform\t$profile\n";
- # Write to tc.data
- write_file($tcfile, @TCDATA);
+ # Add new entry
+ push( @tcdata, "$host\t$name\t$path\t$status\t$platform\t$profile\n" );
+ # Write to tc.data
Modified: usertools/swift/swiftconfig/etc/sites-template.xml
--- usertools/swift/swiftconfig/etc/sites-template.xml 2010-07-02 15:57:21 UTC (rev 3425)
+++ usertools/swift/swiftconfig/etc/sites-template.xml 2010-07-05 08:31:54 UTC (rev 3426)
@@ -2,14 +2,14 @@
<pool handle="multisite-ssh">
<filesystem provider="ssh" url="login1.pads.ci.uchicago.edu" />
<execution provider="ssh" url="login1.pads.ci.uchicago.edu" />
- <workdirectory>/home/arjun/swiftwork</workdirectory>
+ <workdirectory>$HOME/swiftwork</workdirectory>
<profile namespace="karajan" key="jobThrottle">0</profile>
</pool>
<pool handle="teraport">
<filesystem provider="ssh" url="tp-login2.ci.uchicago.edu" />
<execution provider="ssh" url="tp-login2.ci.uchicago.edu" />
</pool>
@@ -24,7 +24,7 @@
<profile namespace="karajan" key="jobThrottle">0.5</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<filesystem provider="ssh" url="login1.pads.ci.uchicago.edu"/>
</pool>
<pool handle="teraport-remote-pbs-coasters-ssh">
@@ -38,13 +38,13 @@
<filesystem provider="ssh" url="tp-login2.ci.uchicago.edu"/>
</pool>
<pool handle="teraport-local-pbs-coasters">
<filesystem provider="local" url="none" />
<execution provider="coaster" url="none" jobmanager="local:pbs" />
<profile namespace="globus" key="maxtime">3000</profile>
<profile namespace="globus" key="workersPerNode">8</profile>
<profile namespace="globus" key="slots">1</profile>
@@ -58,7 +58,7 @@
<pool handle="pads-local-pbs-coasters">
@@ -72,28 +72,28 @@
<pool handle="pads-remote-ssh">
<filesystem url="login1.pads.ci.uchicago.edu" provider="ssh"/>
<execution url="login1.pads.ci.uchicago.edu" provider="ssh"/>
- <workdirectory >/home/arjun/swiftwork</workdirectory>
+ <workdirectory >$HOME/swiftwork</workdirectory>
</pool>
<pool handle="teraport-remote-ssh">
<filesystem url="tp-login2.ci.uchicago.edu" provider="ssh"/>
<execution url="tp-login2.ci.uchicago.edu" provider="ssh"/>
</pool>
<pool handle="pads-local-pbs">
<execution provider="local" url="none" jobmanager="local:pbs" />
</pool>
<pool handle="teraport-local-pbs">
</pool>
@@ -108,7 +108,7 @@
</pool>
<pool handle="teraport-pbs-multisite-coasters">
@@ -122,6 +122,6 @@
</pool>
</config>
More information about the Swift-commit
