[Swift-commit] r3249 - SwiftApps
Mon Feb 22 20:49:50 CST 2010
Author: wilde
Date: 2010-02-22 20:49:50 -0600 (Mon, 22 Feb 2010)
New Revision: 3249
Removed:
   SwiftApps/Swift.R
Log:
Comitted to wrong dir.
Deleted: SwiftApps/Swift.R
--- SwiftApps/Swift.R	2010-02-23 02:26:49 UTC (rev 3248)
+++ SwiftApps/Swift.R	2010-02-23 02:49:50 UTC (rev 3249)
@@ -1,76 +0,0 @@
-swiftapply <- function( func, arglists, site="local", callsperbatch=1 )
-  rundir = system("mktemp -d SwiftR.run.XXX",intern=TRUE)
-  cat("Running in ",rundir,"\n")
-  narglists = length(arglists) # number of arglists to process
-  batch=1   # Next arglist batch number to fill
-  arglist=1 # Next arglist number to insert
-  while(arglist <= narglists) {
-    arglistsleft = narglists - arglist + 1
-    if(arglistsleft >= callsperbatch) {
-      batchsize = callsperbatch
-    else {
-      batchsize = arglistsleft
-    arglistbatch = list()
-    for(i in 1 : batchsize) {
-      arglistbatch[[i]] = arglists[[arglist]]
-      arglist = arglist +1
-    rcall = list(func=func,arglistbatch=arglistbatch)
-    save(rcall,file=paste(rundir,"/cbatch.",as.character(batch),".Rdata",sep=""))
-    batch = batch + 1;
-  nbatches = batch - 1
-  system(paste("./RunSwiftScript.sh",rundir,"local",sep=" "))
-  rno = 1
-  rlist = list()
-  for(batch in 1:nbatches) {
-    load(paste(rundir,"/rbatch.",as.character(batch),".Rdata",sep=""))
-    nresults = length(result)
-    for(r in 1:nresults) {
-      rlist[[rno]] = result[[r]]
-      rno = rno + 1
-  return(rlist)
-TODO="
-x n args
-x batch
-  into svn
-  unique dirs
-  select sites and swift args (throttles etc)
-  R docs
-  R package (SwiftR)
-  Swift docs
-  async exec
-  clean up boot: fix all calls to statistics
-  error handling and null and missing values: ensure res#s correspond to arg#s
-  status
-  specify swift scripts
-  run async and grab status (track 'runs' in R)
-  increm result collect
-  pass the func as val
-  pass extra funcs and packages required
-  pass extra vals
-  pass extra files
-  specifiy unique swift scritps ala Dirk's tools
-  setup the R envs
-  coasters for persistent R Servers
-  test suites
-  use littleR
-  args as alists vs args as list
-  runids, output logging
-  select exec sites and swift  params etc
-  make polymorphic to *apply and snow
-  stream results back to R (so use can inspect as they arrive)
-  (pull them in with a Swift.poll() func)
-  handle discontiguous results
-  return good error messages including messages from R eval and from Swift
-END"
