[Swift-commit] r3810 - trunk/docs
noreply at svn.ci.uchicago.edu
Thu Dec 16 18:18:25 CST 2010
Author: wozniak
Date: 2010-12-16 18:18:25 -0600 (Thu, 16 Dec 2010)
New Revision: 3810
Modified:
trunk/docs/userguide.xml
Log:
Paste in CDM features doc
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml 2010-12-17 00:03:40 UTC (rev 3809)
+++ trunk/docs/userguide.xml 2010-12-17 00:18:25 UTC (rev 3810)
@@ -4127,7 +4127,211 @@
<section id="cdm">
<title>Collective Data Management</title>
+ <programlisting>
+CDM Features
+Overview:
+ 1. The user specifies a CDM policy in a file, customarily fs.data.
+ 2. fs.data is given to Swift on the command line.
+ 3. The Swift data module (org.globus.swift.data) is informed of the CDM policy.
+ 4. At job launch time, the VDL Karajan code queries the CDM policy,
+ 1. altering the file staging phase, and
+ 2. sending fs.data to the compute site.
+ 5. At job run time, the Swift wrapper script
+ 1. consults a Perl script to obtain policy, and
+ 2. uses wrapper extensions to modify data movement.
+ 6. Similarly, stage out can be changed.
+Command line:
+ * swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
+CDM policy file format:
+Example:
+# Describe CDM for my job
+property GATHER_LIMIT 1
+rule .*input.txt DIRECT /gpfs/homes/wozniak/data
+rule .*xfile*.data BROADCAST /dev/shm
+rule .* DEFAULT
+The lines contain:
+ 1. A directive, either rule or property
+ 2. A rule has:
+ 1. A regular expression
+ 2. A policy token
+ 3. Additional policy-specific arguments
+ 3. A property has
+ 1. A policy property token
+ 2. The token value
+ 4. Comments with # .
+ 5. Blank lines are ignored.
+Notes:
+ 1. The policy file is used as a lookup database by Swift and Perl methods.
+ 2. For example, a lookup with the database above given the argument input.txt would result in the Direct policy.
+ 3. If the lookup does not succeed, the result is DEFAULT.
+ 4. Policies are listed as subclasses of org.globus.swift.data.policy.Policy .
+Policy Descriptions:
+Default:
+ * Just use file staging as provided by Swift/CoG. Identical to behavior if no CDM file is given.
+Broadcast:
+ rule .*xfile*.data BROADCAST /dev/shm
+ * The input files matching the pattern will be stored in the given directory, an LFS location, with links in the job directory.
+ * On the BG/P, this will make use of the f2cn tool.
+ * On machines not implementing an efficient broadcast, we will just ensure correctness. For example, on a workstation, the location could be in a /tmp RAM FS.
+Direct:
+ rule .*input.txt DIRECT /gpfs/scratch/wozniak/
+ * Allows for direct I/O to the parallel FS without staging.
+ * The input files matching the pattern must already exist in the given directory, a GFS location. Links will be placed in the job directory.
+ * The output files matching the pattern will be stored in the given directory, with links in the job directory.
+ * Example: In the rule above, the Swift-generated file name ./data/input.txt would be accessed by the user job in /gpfs/homes/wozniak/data/input.txt .
+Local:
+ rule .*input.txt LOCAL dd /gpfs/homes/wozniak/data obs=64K
+ * Allows for client-directed input copy to the compute node.
+ * The user may specify cp or dd as the input transfer program.
+ * The input files matching the pattern must already exist in the given directory, a GFS location. Copies will be placed in the job directory.
+ * Argument list: <tool> <GFS directory> <tool arguments>*
+Gather:
+ property GATHER_LIMIT 500000000 # 500 MB
+ property GATHER_DIR /dev/shm/gather
+ property GATHER_TARGET /gpfs/wozniak/data/gather_target
+ rule .*.output.txt GATHER
+ * The output files matching the pattern will be present to tasks in the job directory as usual but noted in a _swiftwrap shell array GATHER_OUTPUT.
+ * The GATHER_OUTPUT files will be cached in the GATHER_DIR, an LFS location.
+ * The cache will be flushed when a job ends if a du on GATHER_DIR exceeds GATHER_LIMIT.
+ * As the cache fills or on stage out, the files will be bundled into randomly named tarballs in GATHER_TARGET, a GFS location.
+ * If the compute node is an SMP, GATHER_DIR is a shared resource. It is protected by the link file GATHER_DIR/.cdm.lock .
+ * Unpacking the tarballs in GATHER_TARGET will produce the user-specified filenames.
+ Summary:
+ 1. Files created by application
+ 2. Acquire lock
+ 3. Move files to cache
+ 4. Check cache size
+ 5. If limit exceeded, move all cache files to outbox
+ 6. Release lock
+ 7. If limit was exceeded, stream outbox as tarball to target
+ Notes:
+ * Gather required quite a bit of shell functionality to manage the lock, etc. This is placed in cdm_lib.sh .
+ * vdl_int.k needed an additional task submission (cdm_cleanup.sh) to perform the final flush at workflow completion time . This task also uses cdm_lib.sh .
+VDL/Karajan processing:
+ 1. CDM functions are available in Karajan via the cdm namespace.
+ 2. These functions are defined in org.globus.swift.data.Query .
+ 3. If CDM is enabled, VDL skips file staging for files unless the policy is DEFAULT.
+Swift wrapper CDM routines:
+ 1. The cdm.pl script is shipped to the compute node if CDM is enabled.
+ 2. When linking in inputs, CDM is consulted by _swiftwrap:cdm_lookup().
+ 3. The cdm_action() shell function handles CDM methods, typically just producing a link.
+Test case:
+(See About.txt for more information.)
+ 1. Simple test cases are in:
+ https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/cdm-direct and
+ https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/all-pairs
+ 2. Do a:
+ mkdir cdm
+ cd cdm
+ svn co https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts
+ 3. In cdm-direct, run:
+ source ./setup.sh local local local
+ 4. Run workflow:
+ swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
+ 5. Note that staging is skipped for input.txt
+ policy: file://localhost/input.txt : DIRECT
+ FILE_STAGE_IN_START file=input.txt ...
+ FILE_STAGE_IN_SKIP file=input.txt policy=DIRECT
+ FILE_STAGE_IN_END file=input.txt ...
+ 6. In the wrapper output, the input file is handled by CDM functionality:
+ Progress 2010-01-21 13:50:32.466572727-0600 LINK_INPUTS
+ CDM_POLICY: DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+ CDM: jobs/t/cp_sh-tkul4nmj input.txt DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+ CDM[DIRECT]: Linking jobs/t/cp_sh-tkul4nmj/input.txt to /homes/wozniak/cdm/scripts/cdm-direct/input.txt
+ Progress 2010-01-21 13:50:32.486016708-0600 EXECUTE
+ 7. all-pairs is quite similar but uses more policies.
+PTMap case:
+ 1. Start with vanilla PTMap:
+ cd cdm
+ mkdir apps
+ cd apps
+ https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/apps/ptmap
+ 2. Source setup.sh
+ 3. Use start.sh, which
+ 1. applies CDM policy from fs.local.data
+CDM site-aware policy file format:
+Example:
+# Use DIRECT and BROADCAST if on cluster1, else use DEFAULT behavior
+rule cluster1 .*input.txt DIRECT /gpfs/homes/wozniak/data
+rule cluster1 .*xfile*.data BROADCAST /dev/shm
+rule ANYWHERE .* DEFAULT
+The lines contain:
+ 2. A rule has:
+ 1. A regular expression for site matchin
+ 2. A regular expression for filename matching
+ 3. A policy token
+ 4. Additional policy-specific arguments
+ 3. A property has
+ </programlisting>
</section>
</article>
More information about the Swift-commit
