[Swift-commit] r3809 - trunk/docs
noreply at svn.ci.uchicago.edu
Thu Dec 16 18:03:40 CST 2010
Author: wozniak
Date: 2010-12-16 18:03:40 -0600 (Thu, 16 Dec 2010)
New Revision: 3809
Modified:
trunk/docs/userguide.xml
Log:
Add CDM section
Modified: trunk/docs/userguide.xml
--- trunk/docs/userguide.xml 2010-12-14 22:38:55 UTC (rev 3808)
+++ trunk/docs/userguide.xml 2010-12-17 00:03:40 UTC (rev 3809)
@@ -1389,7 +1389,7 @@
<para>
The above mappers may be used to map files based on a URI which can be specified in the filename. This is useful for mapping files on remote machines.
</para>
- <para>
+ <para>
<para> Example:
@@ -3643,14 +3643,14 @@
<section id="transformationcatalog.shell_invocation"><title>shell invocation</title>
<para>
-Because the above implementation requires an entry for each executable on a given site, it is often preferable to simply have a single element for each site in the transformation catalog representing a wrapper that sets the environment and then invokes the shell to call a given application. This wrapper is installed on the site and can be used to set the <literal>PATH</literal> and other environment variables prior to invoking the shell so that each executable need not be entered in the <literal>tc.data</literal> file.
+Because the above implementation requires an entry for each executable on a given site, it is often preferable to simply have a single element for each site in the transformation catalog representing a wrapper that sets the environment and then invokes the shell to call a given application. This wrapper is installed on the site and can be used to set the <literal>PATH</literal> and other environment variables prior to invoking the shell so that each executable need not be entered in the <literal>tc.data</literal> file.
</para>
<para>for example, the entries for <literal>TGUC</literal> and <literal>localhost</literal> can now each be collapsed into a single line:
<screen>
localhost shell /usr/local/bin/swiftshell INSTALLED INTEL32::LINUX null
TGUC shell /usr/local/bin/swiftshell INSTALLED INTEL32::LINUX null
</screen>
-where <literal>swiftshell</literal> sets up the users's environment so that all the installed applications are added to the <literal>PATH</literal> before the application is invoked.
+where <literal>swiftshell</literal> sets up the users's environment so that all the installed applications are added to the <literal>PATH</literal> before the application is invoked.
</para>
<para>
<literal>touch</literal> would now be called in the SwiftScript like this:
@@ -4124,6 +4124,10 @@
</section>
</section>
+ <section id="cdm">
+ <title>Collective Data Management</title>
+ </section>
</article>
More information about the Swift-commit
