[Swift-commit] r3749 - in provenancedb: . apps/oops
    noreply at svn.ci.uchicago.edu
    Wed Dec  8 16:28:44 CST 2010
Author: lgadelha
Date: 2010-12-08 16:28:44 -0600 (Wed, 08 Dec 2010)
New Revision: 3749
Modified:
   provenancedb/apps/oops/oops_extractor.sh
   provenancedb/prov-init.sql
   provenancedb/swift-prov-import-all-logs
Log:
Minor fixes.
Modified: provenancedb/apps/oops/oops_extractor.sh
--- provenancedb/apps/oops/oops_extractor.sh	2010-12-08 19:28:18 UTC (rev 3748)
+++ provenancedb/apps/oops/oops_extractor.sh	2010-12-08 22:28:44 UTC (rev 3749)
@@ -6,7 +6,7 @@
 # OOPS' Swift logs.
 PROVDB_HOME=~/provenancedb
-PROTESTS_HOME=//CASP
+PROTESTS_HOME=/gpfs/pads/oops/aashish/CASP
 IMPORT_HOME=~/protests
 source $PROVDB_HOME/etc/provenance.config
@@ -27,12 +27,14 @@
 	if ! grep --silent $i provdb_imported; then
 	    if grep --silent "Swift finished with no errors" $PROTESTS_HOME/$k/$i/psim.loops-*.log; then
 		cd swift-logs
-		for j in `ls $PROTESTS_HOME/$k/$i | grep psim.loops-`; do
-		    ln -s $PROTESTS_HOME/$k/$i/$j
-		done
+		#for j in `ls $PROTESTS_HOME/$k/$i | grep psim.loops-`; do
+		#    ln -s $PROTESTS_HOME/$k/$i/$j
+		#done
 		cd import
 	        # swift-prov-import-all-logs also controls what already has been
 	        # imported, so it does not repeat work
+		echo "export LOGREPO=$PROTESTS_HOME/$k/$i" > $PROVDB_HOME/etc/provenance.config
+		echo "export SQLCMD=\"psql -U provdb -h db.ci.uchicago.edu provdb\"" >> $PROVDB_HOME/etc/provenance.config
 		$PROVDB_HOME/swift-prov-import-all-logs
 		cd $IMPORT_HOME
 		echo $i >> provdb_imported
Modified: provenancedb/prov-init.sql
--- provenancedb/prov-init.sql	2010-12-08 19:28:18 UTC (rev 3748)
+++ provenancedb/prov-init.sql	2010-12-08 22:28:44 UTC (rev 3749)
@@ -252,7 +252,7 @@
  annot_wf_num,
  annot_wf_txt,
  annot_wf_bool,
- extrainfo,
+-- extrainfo,
  createarray,
  createarray_member,
  array_range
Modified: provenancedb/swift-prov-import-all-logs
--- provenancedb/swift-prov-import-all-logs	2010-12-08 19:28:18 UTC (rev 3748)
+++ provenancedb/swift-prov-import-all-logs	2010-12-08 22:28:44 UTC (rev 3749)
@@ -41,35 +41,38 @@
 	EXISTING=$($SQLCMD --tuples-only -c "select count(*) from workflow where log_filename='$filename';")
 	if [ "$EXISTING" -eq "0" ];  then
-	    echo IMPORTING
-	    if grep --silent "DEBUG Loader Swift finished with no errors" $filename; then
-		wfstatus="SUCCESS"
-    	    else
-		wfstatus="FAIL"
+	    PROV_ENABLED=$(grep provenance $filename | wc -l)
+	    if [ "$PROV_ENABLED" -ge "0" ]; then
+		echo IMPORTING
+		if grep --silent "DEBUG Loader Swift finished with no errors" $filename; then
+		    wfstatus="SUCCESS"
+    		else
+		    wfstatus="FAIL"
+		fi
+		export RUNID=$(basename $filename .log)
+		export WF="${RUNID}"
+		echo "INSERT INTO workflow (id, log_filename, swift_version, import_status) VALUES ('$WF','$filename','$version','$wfstatus');" | $SQLCMD
+		echo version $version in log file $filename
+		echo ============= will import =============
+		prepare-for-import $filename
+		if [ "$?" != "0" ]; then
+		    echo prepare-for-import failed
+		    exit 2
+		fi
+		version=$version import-run-to-sql $filename
+		    echo import-run-to-sql failed
+		    exit 3
+		fi
+                #     import-run-to-xml $filename
+		echo SKIP: provenance.log not true in swift.properties
 	    fi
-	    export RUNID=$(basename $filename .log)
-	    export WF="${RUNID}"
-	    echo "INSERT INTO workflow (id, log_filename, swift_version, import_status) VALUES ('$WF','$filename','$version','$wfstatus');" | $SQLCMD
-	    echo version $version in log file $filename
-	    echo ============= will import =============
-	    prepare-for-import $filename
-	    if [ "$?" != "0" ]; then
-		echo prepare-for-import failed
-		exit 2
-	    fi
-	    version=$version import-run-to-sql $filename
-		echo import-run-to-sql failed
-		exit 3
-	    fi
-            #     import-run-to-xml $filename
 	else
 	    echo SKIP: Already known in workflow
 	fi
More information about the Swift-commit
