[Swift-commit] r3748 - provenancedb
Wed Dec 8 13:28:18 CST 2010
Author: lgadelha
Date: 2010-12-08 13:28:18 -0600 (Wed, 08 Dec 2010)
New Revision: 3748
Modified:
   provenancedb/prov-to-sql.sh
Log:
Minor fixes.
Modified: provenancedb/prov-to-sql.sh
--- provenancedb/prov-to-sql.sh	2010-12-08 18:19:27 UTC (rev 3747)
+++ provenancedb/prov-to-sql.sh	2010-12-08 19:28:18 UTC (rev 3748)
@@ -37,9 +37,9 @@
     operatorid="${WFID}operator:$thread"
     if [ $version -le 3726 ]; then
-	$lhs=$(echo $lhs | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
-	$rhs=$(echo $rhs | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
-	$result=$(echo $result | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	lhs=$(echo $lhs | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	rhs=$(echo $rhs | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	result=$(echo $result | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
     fi
     echo "INSERT INTO dataset (id) VALUES ('$lhs');" >> tmp-ds.sql
@@ -53,7 +53,7 @@
 while read id name output; do
-	$output=$(echo $output | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	output=$(echo $output | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
     fi
     echo "INSERT INTO dataset (id) VALUES ('$output');" >> tmp-ds.sql
     echo "INSERT INTO process (id, type, name, workflow_id) VALUES ('$id', 'function', '$name', '$WF');" >> tmp-p.sql
@@ -64,7 +64,7 @@
     # TODO need ordering/naming
-	$value=$(echo $value | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	value=$(echo $value | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
     fi
     echo "INSERT INTO dataset (id) VALUES ('$value');" >> tmp-ds.sql
@@ -79,8 +79,8 @@
 while read outer inner; do
-	$outer=$(echo $outer | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
-	$inner=$(echo $inner | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	outer=$(echo $outer | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	inner=$(echo $inner | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
     fi
     echo "INSERT INTO dataset (id) VALUES ('$outer');" >> tmp-ds.sql
@@ -91,7 +91,7 @@
 while read dataset filename; do
-	$dataset=$(echo $dataset | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
+	dataset=$(echo $dataset | sed -e 's/tag:benc at ci.uchicago.edu,2008:swift://g')
     fi
     echo "INSERT INTO dataset (id) VALUES ('$dataset');" >> tmp-ds.sql
@@ -101,7 +101,7 @@
 while read dataset value; do
     fi
@@ -146,7 +146,7 @@
     fi
     fi
