[Swift-commit] r3744 - trunk/tests/cdm
Mon Dec 6 16:04:56 CST 2010
Author: wozniak
Date: 2010-12-06 16:04:55 -0600 (Mon, 06 Dec 2010)
New Revision: 3744
Added:
   trunk/tests/cdm/601-local-cp.check.sh
   trunk/tests/cdm/601-local-cp.clean.sh
   trunk/tests/cdm/601-local-cp.setup.sh
   trunk/tests/cdm/601-local-cp.swift
   trunk/tests/cdm/602-local-dd.check.sh
   trunk/tests/cdm/602-local-dd.clean.sh
   trunk/tests/cdm/602-local-dd.setup.sh
   trunk/tests/cdm/602-local-dd.swift
Removed:
   trunk/tests/cdm/601-local.check.sh
   trunk/tests/cdm/601-local.clean.sh
   trunk/tests/cdm/601-local.setup.sh
   trunk/tests/cdm/601-local.swift
   trunk/tests/cdm/602-local.check.sh
   trunk/tests/cdm/602-local.clean.sh
   trunk/tests/cdm/602-local.setup.sh
   trunk/tests/cdm/602-local.swift
Log:
Put cp/dd in the test name
Copied: trunk/tests/cdm/601-local-cp.check.sh (from rev 3742, trunk/tests/cdm/601-local.check.sh)
--- trunk/tests/cdm/601-local-cp.check.sh	                        (rev 0)
+++ trunk/tests/cdm/601-local-cp.check.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,8 @@
+#!/bin/sh
+set -x
+grep $( uname -m ) 601/601-input.txt || exit 1
+grep $( uname -m ) 601-output.txt    || exit 1
+exit 0
Copied: trunk/tests/cdm/601-local-cp.clean.sh (from rev 3742, trunk/tests/cdm/601-local.clean.sh)
--- trunk/tests/cdm/601-local-cp.clean.sh	                        (rev 0)
+++ trunk/tests/cdm/601-local-cp.clean.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 601-output.txt 601
+exit 0
Copied: trunk/tests/cdm/601-local-cp.setup.sh (from rev 3742, trunk/tests/cdm/601-local.setup.sh)
--- trunk/tests/cdm/601-local-cp.setup.sh	                        (rev 0)
+++ trunk/tests/cdm/601-local-cp.setup.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,12 @@
+#!/bin/sh
+set -x
+mkdir -pv 601 || exit 1
+  uname -a
+  date
+} > 601/601-input.txt
+exit 0
Copied: trunk/tests/cdm/601-local-cp.swift (from rev 3742, trunk/tests/cdm/601-local.swift)
--- trunk/tests/cdm/601-local-cp.swift	                        (rev 0)
+++ trunk/tests/cdm/601-local-cp.swift	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,14 @@
+type file;
+app (file o) copy (file i)
+  cp @i @o;
+// Will be transformed by CDM to 601/601-input.txt:
+file f1<"601-input.txt">;
+file f2<"601-output.txt">;
+f2 = copy(f1);
Deleted: trunk/tests/cdm/601-local.check.sh
--- trunk/tests/cdm/601-local.check.sh	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/601-local.check.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,8 +0,0 @@
-#!/bin/sh
-set -x
-grep $( uname -m ) 601/601-input.txt || exit 1
-grep $( uname -m ) 601-output.txt    || exit 1
-exit 0
Deleted: trunk/tests/cdm/601-local.clean.sh
--- trunk/tests/cdm/601-local.clean.sh	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/601-local.clean.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,7 +0,0 @@
-#!/bin/sh
-set -x
-rm -rv 601-output.txt 601
-exit 0
Deleted: trunk/tests/cdm/601-local.setup.sh
--- trunk/tests/cdm/601-local.setup.sh	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/601-local.setup.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,12 +0,0 @@
-#!/bin/sh
-set -x
-mkdir -pv 601 || exit 1
-  uname -a
-  date
-} > 601/601-input.txt
-exit 0
Deleted: trunk/tests/cdm/601-local.swift
--- trunk/tests/cdm/601-local.swift	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/601-local.swift	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,14 +0,0 @@
-type file;
-app (file o) copy (file i)
-  cp @i @o;
-// Will be transformed by CDM to 601/601-input.txt:
-file f1<"601-input.txt">;
-file f2<"601-output.txt">;
-f2 = copy(f1);
Copied: trunk/tests/cdm/602-local-dd.check.sh (from rev 3743, trunk/tests/cdm/602-local.check.sh)
--- trunk/tests/cdm/602-local-dd.check.sh	                        (rev 0)
+++ trunk/tests/cdm/602-local-dd.check.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,8 @@
+#!/bin/sh
+set -x
+grep $( uname -m ) 602/602-input.txt || exit 1
+grep $( uname -m ) 602-output.txt    || exit 1
+exit 0
Copied: trunk/tests/cdm/602-local-dd.clean.sh (from rev 3743, trunk/tests/cdm/602-local.clean.sh)
--- trunk/tests/cdm/602-local-dd.clean.sh	                        (rev 0)
+++ trunk/tests/cdm/602-local-dd.clean.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 602-output.txt 602
+exit 0
Copied: trunk/tests/cdm/602-local-dd.setup.sh (from rev 3743, trunk/tests/cdm/602-local.setup.sh)
--- trunk/tests/cdm/602-local-dd.setup.sh	                        (rev 0)
+++ trunk/tests/cdm/602-local-dd.setup.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,12 @@
+#!/bin/sh
+set -x
+mkdir -pv 602 || exit 1
+  uname -a
+  date
+} > 602/602-input.txt
+exit 0
Copied: trunk/tests/cdm/602-local-dd.swift (from rev 3743, trunk/tests/cdm/602-local.swift)
--- trunk/tests/cdm/602-local-dd.swift	                        (rev 0)
+++ trunk/tests/cdm/602-local-dd.swift	2010-12-06 22:04:55 UTC (rev 3744)
@@ -0,0 +1,14 @@
+type file;
+  cp @i @o;
+// Will be transformed by CDM to 602/602-input.txt:
+file f1<"602-input.txt">;
+file f2<"602-output.txt">;
+f2 = copy(f1);
Deleted: trunk/tests/cdm/602-local.check.sh
--- trunk/tests/cdm/602-local.check.sh	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/602-local.check.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,8 +0,0 @@
-#!/bin/sh
-set -x
-grep $( uname -m ) 602/602-input.txt || exit 1
-grep $( uname -m ) 602-output.txt    || exit 1
-exit 0
Deleted: trunk/tests/cdm/602-local.clean.sh
--- trunk/tests/cdm/602-local.clean.sh	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/602-local.clean.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,7 +0,0 @@
-#!/bin/sh
-set -x
-rm -rv 602-output.txt 602
-exit 0
Deleted: trunk/tests/cdm/602-local.setup.sh
--- trunk/tests/cdm/602-local.setup.sh	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/602-local.setup.sh	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,12 +0,0 @@
-#!/bin/sh
-set -x
-mkdir -pv 602 || exit 1
-  uname -a
-  date
-} > 602/602-input.txt
-exit 0
Deleted: trunk/tests/cdm/602-local.swift
--- trunk/tests/cdm/602-local.swift	2010-12-06 22:02:58 UTC (rev 3743)
+++ trunk/tests/cdm/602-local.swift	2010-12-06 22:04:55 UTC (rev 3744)
@@ -1,14 +0,0 @@
-type file;
-  cp @i @o;
-// Will be transformed by CDM to 602/602-input.txt:
-file f1<"602-input.txt">;
-file f2<"602-output.txt">;
-f2 = copy(f1);
