[Swift-commit] r3743 - trunk/tests/cdm
Mon Dec 6 16:02:58 CST 2010
Author: wozniak
Date: 2010-12-06 16:02:58 -0600 (Mon, 06 Dec 2010)
New Revision: 3743
Added:
   trunk/tests/cdm/602-local.check.sh
   trunk/tests/cdm/602-local.clean.sh
   trunk/tests/cdm/602-local.setup.sh
   trunk/tests/cdm/602-local.swift
Modified:
   trunk/tests/cdm/fs.template.data
Log:
New CDM LOCAL test with dd
Added: trunk/tests/cdm/602-local.check.sh
--- trunk/tests/cdm/602-local.check.sh	                        (rev 0)
+++ trunk/tests/cdm/602-local.check.sh	2010-12-06 22:02:58 UTC (rev 3743)
@@ -0,0 +1,8 @@
+#!/bin/sh
+set -x
+grep $( uname -m ) 602/602-input.txt || exit 1
+grep $( uname -m ) 602-output.txt    || exit 1
+exit 0
Property changes on: trunk/tests/cdm/602-local.check.sh
___________________________________________________________________
Added: trunk/tests/cdm/602-local.clean.sh
--- trunk/tests/cdm/602-local.clean.sh	                        (rev 0)
+++ trunk/tests/cdm/602-local.clean.sh	2010-12-06 22:02:58 UTC (rev 3743)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 602-output.txt 602
+exit 0
Property changes on: trunk/tests/cdm/602-local.clean.sh
Added: trunk/tests/cdm/602-local.setup.sh
--- trunk/tests/cdm/602-local.setup.sh	                        (rev 0)
+++ trunk/tests/cdm/602-local.setup.sh	2010-12-06 22:02:58 UTC (rev 3743)
@@ -0,0 +1,12 @@
+#!/bin/sh
+set -x
+mkdir -pv 602 || exit 1
+  uname -a
+  date
+} > 602/602-input.txt
+exit 0
Property changes on: trunk/tests/cdm/602-local.setup.sh
Added: trunk/tests/cdm/602-local.swift
--- trunk/tests/cdm/602-local.swift	                        (rev 0)
+++ trunk/tests/cdm/602-local.swift	2010-12-06 22:02:58 UTC (rev 3743)
@@ -0,0 +1,14 @@
+type file;
+app (file o) copy (file i)
+  cp @i @o;
+// Will be transformed by CDM to 602/602-input.txt:
+file f1<"602-input.txt">;
+file f2<"602-output.txt">;
+f2 = copy(f1);
Modified: trunk/tests/cdm/fs.template.data
--- trunk/tests/cdm/fs.template.data	2010-12-06 21:53:10 UTC (rev 3742)
+++ trunk/tests/cdm/fs.template.data	2010-12-06 22:02:58 UTC (rev 3743)
@@ -8,3 +8,4 @@
 rule .*301-input.txt BROADCAST _PWD_/301
 rule .*501-output.*.txt GATHER
 rule .*601-input.*.txt LOCAL cp _PWD_/601
+rule .*602-input.*.txt LOCAL dd _PWD_/602
