[Swift-commit] r3545 - in usertools/swift/swiftconfig: bin lib/perl
    noreply at svn.ci.uchicago.edu
    Mon Aug 16 13:49:25 CDT 2010
Author: davidk
Date: 2010-08-16 13:49:25 -0500 (Mon, 16 Aug 2010)
New Revision: 3545
Modified:
   usertools/swift/swiftconfig/bin/swiftconfig
   usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
Log:
Remove version restrictions
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig	2010-08-16 18:17:07 UTC (rev 3544)
+++ usertools/swift/swiftconfig/bin/swiftconfig	2010-08-16 18:49:25 UTC (rev 3545)
@@ -19,7 +19,6 @@
 my $option_list         = q{};            # List information about config
 my $option_remove       = q{};            # Remove entry from sites.xml
 my $option_edit         = q{};            # Edit mode
-my $option_sites        = q{};            # List all usable sites
 my $option_describe     = q{};            # Print raw XML configuration
 my $option_default      = q{};            # When adding a site, use all defaults
 my $option_template     = q{};            # Create config from template specified
@@ -30,7 +29,6 @@
 # Assign variables from command line options
 GetOptions(
     'remove=s'              => \$option_remove,
-    'sites'                 => \$option_sites,
     'describe=s'            => \$option_describe,
     'default|defaults'      => \$option_default,
     'full'                  => sub { $option_default = 0; },
@@ -108,11 +106,6 @@
         . "$dotswift_directory/sites/$option_remove\n";
-# List all user-added sites
-if ($option_sites) {
-    print_directory("$dotswift_directory/sites");
 # Modify a site entry
 if ($option_edit) {
     my $output_directory = "$dotswift_directory/sites/$option_edit";
@@ -323,7 +316,6 @@
    -template sitename	Add a configuration based on a template
    -remove site	     Removes a site configuration
    -templates		     Display all available templates
-   -sites                Displays all existing configurations
    -edit site	          Specifies the name of a configuration to edit
    -copy site            Copies a configuration
    -default              Do not prompt for values, always use defaults
Modified: usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm
--- usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm	2010-08-16 18:17:07 UTC (rev 3544)
+++ usertools/swift/swiftconfig/lib/perl/SwiftConfig.pm	2010-08-16 18:49:25 UTC (rev 3545)
@@ -1,6 +1,5 @@
 package SwiftConfig;
-use 5.010001;
 use strict;
 use warnings;
@@ -555,12 +554,13 @@
         return;
-    if(-e "$ENV{'HOME'}/.swift/sites/apps") {
-        open(APPLIST, "$ENV{'HOME'}/.swift/sites/apps")
-            || die "Unable to open app list $ENV{'HOME'}/.swift/sites/apps";
+    if(-e "$ENV{'HOME'}/.swift/sites/$site/apps") {
+        open(APPLIST, "$ENV{'HOME'}/.swift/sites/$site/apps")
+            || die "Unable to open app list $ENV{'HOME'}/.swift/sites/$site/apps";
         my @apps_file_data = <APPLIST>;
         close(APPLIST);
         foreach my $current_app (@apps_file_data) {
+            print "Looking at: $current_app\n";
             if($apps) {
                 $apps = "$apps $current_app";
@@ -569,6 +569,7 @@
+    print "Apps: $apps\n";
     my @all_available_appsets = glob("$ENV{'HOME'}/.swift/apps/*.apps");
     print "Available application sets are: ";
@@ -579,9 +580,7 @@
     print "\n";
-    print "Enter application sets for $site: ";
-    $apps = <STDIN>;
-    chomp($apps);
+    $apps = get_entry("Application sets for $site", $apps, 0);
     my @all_list = split(/ /, $apps);
     open(APPFILE, ">$ENV{'HOME'}/.swift/sites/$site/apps")
         || die "Unable to open $ENV{'HOME'}/.swift/sites/$site/apps for writing!\n";
More information about the Swift-commit
