[Swift-commit] r3544 - in usertools/swift/swiftconfig: bin etc
noreply at svn.ci.uchicago.edu
Mon Aug 16 13:17:07 CDT 2010
Author: davidk
Date: 2010-08-16 13:17:07 -0500 (Mon, 16 Aug 2010)
New Revision: 3544
Modified:
usertools/swift/swiftconfig/bin/swiftconfig
usertools/swift/swiftconfig/etc/TODO
Log:
Replaced -templates and -describe with -list
swiftconfig -list templates
swiftconfig -list configs
swiftconfig -list <sitename>
Modified: usertools/swift/swiftconfig/bin/swiftconfig
--- usertools/swift/swiftconfig/bin/swiftconfig 2010-08-16 17:40:59 UTC (rev 3543)
+++ usertools/swift/swiftconfig/bin/swiftconfig 2010-08-16 18:17:07 UTC (rev 3544)
@@ -16,7 +16,7 @@
use Data::Dumper;
# Variables used for sites.xml
-my $option_templates = q{}; # List all templates
+my $option_list = q{}; # List information about config
my $option_remove = q{}; # Remove entry from sites.xml
my $option_edit = q{}; # Edit mode
my $option_sites = q{}; # List all usable sites
@@ -30,7 +30,6 @@
# Assign variables from command line options
GetOptions(
'remove=s' => \$option_remove,
- 'templates' => \$option_templates,
'sites' => \$option_sites,
'describe=s' => \$option_describe,
'default|defaults' => \$option_default,
@@ -40,6 +39,7 @@
'copy=s' => \$option_copy,
'apps|applications' => \$option_applications,
'import=s' => \$option_import,
+ 'list=s' => \$option_list,
'help|man' => sub { pod2usage(-verbose => 2); },
@@ -95,15 +95,6 @@
-# Describe a site
-if ($option_describe) {
- my $site_file = "$dotswift_directory/sites/$option_describe/sites.xml";
- if ( !-e $site_file ) {
- die "Unable to locate configuration for $option_describe\n";
- system("cat $site_file");
# Remove an entry
if ($option_remove) {
@@ -117,11 +108,6 @@
. "$dotswift_directory/sites/$option_remove\n";
-# List all available templates
-if ($option_templates) {
- print_directory($template_directory);
# List all user-added sites
if ($option_sites) {
print_directory("$dotswift_directory/sites");
@@ -299,7 +285,22 @@
+if($option_list) {
+ if ($option_list eq "templates") {
+ print_directory($template_directory);
+ elsif ($option_list eq "configs") {
+ print_directory("$dotswift_directory/sites");
+ # Assume it's the name of a configuration
+ else {
+ my @matched_configs = glob("$dotswift_directory/sites/$option_list");
+ foreach my $site (@matched_configs) {
+ system("cat $site/sites.xml");
__END__
=head1 NAME
@@ -324,10 +325,12 @@
-templates Display all available templates
-sites Displays all existing configurations
-edit site Specifies the name of a configuration to edit
- -describe site Prints the raw XML site configuration
-copy site Copies a configuration
-default Do not prompt for values, always use defaults
-full Edit every available configuration option
+ -import Import a sites.xml file into swiftconfig
+ -list Options: templates, configs, or a config
+ -apps Edit or create application sets
=head1 EXAMPLES
@@ -342,4 +345,17 @@
Remove a site
swiftconfig -remove teraport
+Edit application sets
+ swiftconfig -apps
+List available templates
+ swiftconfig -list templates
+List all configurations
+ swiftconfig -list configs
+List information about one particular configuration
+ swiftconfig -list configuration_name
=cut
Modified: usertools/swift/swiftconfig/etc/TODO
--- usertools/swift/swiftconfig/etc/TODO 2010-08-16 17:40:59 UTC (rev 3543)
+++ usertools/swift/swiftconfig/etc/TODO 2010-08-16 18:17:07 UTC (rev 3544)
@@ -1,9 +1,6 @@
Running and testing on more setups, OSG, teragrid, others
Job tagging with search capabilities
Ability to group groups of sites (other than 'all')
Have swiftrun be flexible enough to work for new users, as well as advanced users
-swiftconfig -import to allow integration with existing configurations
+Site aliases
+Ability to "undo" edits
More information about the Swift-commit
