sieve-dev Sieve examples
Yaakoub El Khamra
yye00 at tacc.utexas.edu
Wed May 12 11:29:09 CDT 2010
That is perfectly understandable. I am hoping to get started with sieve, so
if there is a better starting point please do let me know. Andy was kind
enough to provide the Sieve intro slides which made the terminology much
clearer.
Regards
Yaakoub El Khamra
On Wed, May 12, 2010 at 11:14 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Sorry Yaakoub,
> All the examples are indeed broken, which shows how many people use them.
> I will fix them on the weekend. The problem is that the main Sieve users
> (PyLith,
> Blaise, PetFMM) required changes, and do not use any of the examples.
> Thanks,
> Matt
> On Wed, May 12, 2010 at 10:43 AM, Yaakoub El Khamra <yye00 at tacc.utexas.edu
> > wrote:
>> So I am trying to build the sieve examples and have run into interesting
>> errors. I only managed to get the watson example to compile but it segfaults
>> when I run it. All others refuse to compile with varying errors ranging from
>> missing header files to:
>> error: invalid initialization of reference of type
>> ‘ALE::Obj<ALE::IMesh<ALE::LabelSifter<int, int,
>> ALE::malloc_allocator<ALE::NewSifterDef::Arrow<int, int> > > >,
>> ALE::malloc_allocator<ALE::IMesh<ALE::LabelSifter<int, int,
>> ALE::malloc_allocator<ALE::NewSifterDef::Arrow<int, int> > > > > >&’ from
>> expression of type ‘ALE::Obj<ALE::Mesh, ALE::malloc_allocator<ALE::Mesh> >’
>> I did compile with fiat and the generator but obviously I am missing
>> something. Any thoughts/recommendations are greatly appreciated.
>> Regards
>> Yaakoub El Khamra
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/sieve-dev/attachments/20100512/fb6b0235/attachment.htm>
More information about the sieve-dev
