sieve-dev IndicesVisitor
Shi Jin jinzishuai at gmail.com
Mon Sep 15 23:19:04 CDT 2008
Hi there,
I have the following loop:
typedef
ALE::ISieveVisitor::IndicesVisitor<PETSC_MESH_TYPE::real_section_type ,
    PETSC_MESH_TYPE::order_type,PetscInt> visitor_type;
    int numIndices;
    int e=0;
    for (PETSC_MESH_TYPE::label_sequence::iterator c_iter = cells->begin();
c_iter
            !=cells->end(); ++c_iter, e++)//Loop thru local elements
        *visitor_type velVisitor(*vel[0], *velGlobalOrder, (int) (pow(
                sieve->getMaxConeSize(), m->depth())+1)*m->getMaxDof(),
                m->depth() > 1);
        visitor_type preVisitor(*p, *preGlobalOrder, (int) (pow(
                m->depth() > 1);*
        computeIndicesForCell(e, vel[0], &numIndices, velVisitor);
        for (int i=0; i<numIndices; i++)
            velCellIndices[e*numIndices+i]=elementIndices[i];
        computeIndicesForCell(e, p, &numIndices, preVisitor);
            preCellIndices[e*numIndices+i]=elementIndices[i];
Where the function computeIndicesForCell() calls the visitor by reference.
I want to take the definitions of the two visitors out of loop since I think
they can be reused. However, if I do that, an exception will be thrown at
void visitPoint(const point_type& point, const int orientation) {
        if (p >= size) {
          ostringstream msg;
         * msg << "Too many points (>" << size << ")for IndicesVisitor
visitor";*
          throw ALE::Exception(msg.str().c_str());
        if (points) {
          int pp;
          for(pp = 0; pp < p; ++pp) {if (points[pp] == point) break;}
          if (pp != p) return;
          points[*p++*] = point;
due to too large p value.
I wonder if this is normal.  The value of p increments in each call to
visitPoint() and it does not get reset in the clear() call as i does.
Should I just keep the definitions inside the loop? Thanks a lot.
Sincerely,
Shi Jin, Ph.D.
http://www.ualberta.ca/~sjin1/
URL: <https://lists.mcs.anl.gov/mailman/private/sieve-dev/attachments/20080915/eadaa4c2/attachment.htm>
More information about the sieve-dev mailing list
