[petsc-users] Problem running ex50 after compilation
Srinivas Kirthy K
srinivas.kirthy at gmail.com
Sat Jan 31 03:02:19 CST 2026
I'm trying to run src/ts/tutorials/ex2.c
<https://urldefense.us/v3/__https://petsc.org/release/tutorials/handson/*handson__;Iw!!G_uCfscf7eWS!ZPCw4pyB_fkaQNPaMbajMRdPOEQUxQ4FkkuynSiE6DZ18UHOg5qsEmgew5BiTm04qyouW1HqyaWvRQ-OxU8CFiIYKbuDFLY$ > using:
*/home/skirthy/petsc/arch-linux-c-debug/bin/mpiexec -n 1 ./ex2
-ts_max_steps 10 -ts_monitor*
Instead of the expected output
<https://urldefense.us/v3/__https://petsc.org/release/tutorials/handson/*handson__;Iw!!G_uCfscf7eWS!ZPCw4pyB_fkaQNPaMbajMRdPOEQUxQ4FkkuynSiE6DZ18UHOg5qsEmgew5BiTm04qyouW1HqyaWvRQ-OxU8CFiIYKbuDFLY$ >, I get this:
*Norm of error 0.000156044 iterations 6WARNING! There are options you set
that were not used!WARNING! could be spelling mistake, etc!There are 2
unused database options. They are:Option left: name:-ts_max_steps value: 10
source: command lineOption left: name:-ts_monitor (no value) source:
command line*
Trying to troubleshoot this, can anyone help?
Thanks.
On Sat, Jan 31, 2026 at 1:34 PM Srinivas Kirthy K <srinivas.kirthy at gmail.com>
wrote:
> Works now. Thank you.
> On Sat, Jan 31, 2026 at 1:29 PM Satish Balay <balay.anl at fastmail.org>
> wrote:
>> On Sat, 31 Jan 2026, Srinivas Kirthy K wrote:
>> > Hi Satish,
>> > I included this line in the makefile:
>> > *mpiexec: "${PETSC_DIR}/${PETSC_ARCH}/bin/mpiexec" *
>> > Was able to compile, still getting the same error when I run *mpiexec
>> -n 1
>> > ./ex50 -da_grid_x 4 -da_grid_y 4 -mat_view*
>> > Anything that I'm doing wrong?
>> Use:
>> /home/skirthy/petsc/arch-linux-c-debug/bin/mpiexec -n 1 ./ex50
>> Satish
>> > Thanks.
>> > On Sat, Jan 31, 2026 at 10:54 AM Satish Balay <balay.anl at fastmail.org>
>> > wrote:
>> > > Configure Options: --configModules=PETSc.Configure
>> > > --optionsModule=config.compilerOptions --download-mpich
>> > > --download-fblaslapack
>> > > Ok - so you've installed MPI via --download-mpich - so you need to
>> use:
>> > > mpiexec: /home/skirthy/petsc/arch-linux-c-debug/bin/mpiexec
>> > > [likely mpiexec used below is a different one]
>> > > Satish
>> > > > Hi,
>> > > > I'm new to PETSc.
>> > > > I was able to compile ex50.c using:
>> > > > *cd petsc/src/ksp/ksp/tutorials*
>> > > > *make ex50*
>> > > > When I run: *mpiexec -n 1 ./ex50 -da_grid_x 4 -da_grid_y 4
>> -mat_view*
>> > > > I get the error message in *PETSC_mpiexec_error.txt *(attached)
>> > > > I've defined these in the ~/.bashrc:
>> > > > *export PETSC_DIR=$HOME/petsc # added on 31/01/2026 to define PETSC
>> > > > locationexport PETSC_ARCH=arch-linux-c-debug*
>> > > > Can you help me fix this?
>> > > > I've attached the *configure.log* file as well.
>> > > > Thanks in advance.
> Regards,
> Srinivas Kirthy K
Srinivas Kirthy K
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260131/d6066fab/attachment-0001.html>
