[petsc-users] Problem running ex50 after compilation
Srinivas Kirthy K
srinivas.kirthy at gmail.com
Sat Jan 31 02:04:12 CST 2026
Works now. Thank you.
On Sat, Jan 31, 2026 at 1:29 PM Satish Balay <balay.anl at fastmail.org> wrote:
> On Sat, 31 Jan 2026, Srinivas Kirthy K wrote:
> > Hi Satish,
> > I included this line in the makefile:
> > *mpiexec: "${PETSC_DIR}/${PETSC_ARCH}/bin/mpiexec" *
> > Was able to compile, still getting the same error when I run *mpiexec -n
> 1
> > ./ex50 -da_grid_x 4 -da_grid_y 4 -mat_view*
> > Anything that I'm doing wrong?
> Use:
> /home/skirthy/petsc/arch-linux-c-debug/bin/mpiexec -n 1 ./ex50 -da_grid_x
> Satish
> > Thanks.
> > On Sat, Jan 31, 2026 at 10:54 AM Satish Balay <balay.anl at fastmail.org>
> > wrote:
> > > Configure Options: --configModules=PETSc.Configure
> > > --optionsModule=config.compilerOptions --download-mpich
> > > --download-fblaslapack
> > > Ok - so you've installed MPI via --download-mpich - so you need to use:
> > > mpiexec: /home/skirthy/petsc/arch-linux-c-debug/bin/mpiexec
> > > [likely mpiexec used below is a different one]
> > > Satish
> > > > Hi,
> > > > I'm new to PETSc.
> > > > I was able to compile ex50.c using:
> > > > *cd petsc/src/ksp/ksp/tutorials*
> > > > *make ex50*
> > > > When I run: *mpiexec -n 1 ./ex50 -da_grid_x 4 -da_grid_y 4
> -mat_view*
> > > > I get the error message in *PETSC_mpiexec_error.txt *(attached)
> > > > I've defined these in the ~/.bashrc:
> > > > *export PETSC_DIR=$HOME/petsc # added on 31/01/2026 to define PETSC
> > > > locationexport PETSC_ARCH=arch-linux-c-debug*
> > > > Can you help me fix this?
> > > > I've attached the *configure.log* file as well.
> > > > Thanks in advance.
Srinivas Kirthy K
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260131/1c5372ee/attachment.html>
