[petsc-users] Ghost vector with MPIKOKKOS under DMSwarm
Mon Jan 19 11:41:40 CST 2026
On Mon, Jan 19, 2026 at 12:17 PM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
wrote:
> I still do not think it would work with ghosted Vecs, because those demand
> that the shared particles are at the end of the Vec, but Swarm has no idea
> about this division.
> That’s my concern. What I’m doing is a MD code, so I need access to ghost
> values at vectors such as position to evaluate the potential.
That would work, just not the naie local-to-global maps.
     Matt
> Miguel
> On Jan 19, 2026, at 3:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jan 19, 2026 at 7:56 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
> wrote:
>> Dear all,
>> I have a question about using DMSwarm data with Kokkos-enabled vectors.
>> My particle data (including ghost particles) are stored in a DMSwarm and
>> for solver purposes I generate PETSc vectors using VecCreateGhostWithArray.
>> I would like to use VecMPIKOKKOS for MPI+GPU computations. Am I correct
>> that DMSwarm field memory cannot be directly wrapped into a VecMPIKOKKOS
>> using VecCreateGhostWithArray or VecPlaceArray? Any idea on how to proceed?
> You can use
> https://urldefense.us/v3/__https://petsc.org/main/manualpages/DMSwarm/DMSwarmCreateGlobalVectorFromField/__;!!G_uCfscf7eWS!a_jPC7NylpspVjXQgq9aDBNQ_XOXmSByj-wvc6qzC4vcK8m5RpIj3HzaoAz9upKM3JB97V5HvtwTpdPcz1u9$
> if you have a single field, which is no-copy. However, if you want
> multiple fields in the Vec, then you need a copy. We
> do this in our PIC code, and the copy time is in the noise, so I would
> measure it before deciding you do not want a copy.
>   Thanks,
>       Matt
>> Thanks in advance.
>> Best,
>> Miguel
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a_jPC7NylpspVjXQgq9aDBNQ_XOXmSByj-wvc6qzC4vcK8m5RpIj3HzaoAz9upKM3JB97V5HvtwTpQM9O25F$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a_jPC7NylpspVjXQgq9aDBNQ_XOXmSByj-wvc6qzC4vcK8m5RpIj3HzaoAz9upKM3JB97V5HvtwTpalO8rtz$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a_jPC7NylpspVjXQgq9aDBNQ_XOXmSByj-wvc6qzC4vcK8m5RpIj3HzaoAz9upKM3JB97V5HvtwTpQM9O25F$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a_jPC7NylpspVjXQgq9aDBNQ_XOXmSByj-wvc6qzC4vcK8m5RpIj3HzaoAz9upKM3JB97V5HvtwTpalO8rtz$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260119/663001db/attachment-0001.html>
