[petsc-users] Ghost vector with MPIKOKKOS under DMSwarm
MIGUEL MOLINOS PEREZ mmolinos at us.es
Mon Jan 19 11:17:40 CST 2026
I still do not think it would work with ghosted Vecs, because those demand that the shared particles are at the end of the Vec, but Swarm has no idea about this division.
That’s my concern. What I’m doing is a MD code, so I need access to ghost values at vectors such as position to evaluate the potential.
Miguel
On Jan 19, 2026, at 3:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
On Mon, Jan 19, 2026 at 7:56 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
Dear all,
I have a question about using DMSwarm data with Kokkos-enabled vectors.
My particle data (including ghost particles) are stored in a DMSwarm and for solver purposes I generate PETSc vectors using VecCreateGhostWithArray. I would like to use VecMPIKOKKOS for MPI+GPU computations. Am I correct that DMSwarm field memory cannot be directly wrapped into a VecMPIKOKKOS using VecCreateGhostWithArray or VecPlaceArray? Any idea on how to proceed?
You can use
  https://urldefense.us/v3/__https://petsc.org/main/manualpages/DMSwarm/DMSwarmCreateGlobalVectorFromField/__;!!G_uCfscf7eWS!bQ47FGy_iSJU8ODIRPz-W5bpnPyoL-_CCMluodw_v8xbtgX1pbylov4V0-B3eea4bFiyEKjKMQJyYf-t3YvaIQ$
if you have a single field, which is no-copy. However, if you want multiple fields in the Vec, then you need a copy. We
do this in our PIC code, and the copy time is in the noise, so I would measure it before deciding you do not want a copy.
      Matt
Thanks in advance.
Best,
Miguel
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bQ47FGy_iSJU8ODIRPz-W5bpnPyoL-_CCMluodw_v8xbtgX1pbylov4V0-B3eea4bFiyEKjKMQJyYf-gbn1yfA$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bQ47FGy_iSJU8ODIRPz-W5bpnPyoL-_CCMluodw_v8xbtgX1pbylov4V0-B3eea4bFiyEKjKMQJyYf85ClEsmw$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260119/8ed3d767/attachment-0001.html>
