[petsc-users] Having trouble with basic Fortran-PETSc interoperability
Fri Jan 16 11:47:52 CST 2026
On Fri, Jan 16, 2026 at 12:18 PM Michael Whitten via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I realized the subject line was incorrect so I fixed it.
> I want use SNES for sure and possibly TS and Tao. I would also like to be
> able to use the matrix-vector multiplication in a similar way. Is there
> similar guidance for SNES (TS and Tao) as there is for KSP somewhere?
It should work exactly the same as it does KSP. If you have a more specific
question, please mail back.
     Matt
> I had started reading the PETSc user manual while simultaneously
> experimenting with some code and hadn't made it to that section. It's a
> large ecosystem and I am trying to get oriented. Your help is much
> appreciated.
> Michael
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Friday, January 16, 2026 11:38 AM
> *To:* Michael Whitten <mwhitte6 at jhu.edu>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] petsc-users Digest, Vol 205, Issue 12
> *      External Email - Use Caution      *
>   Michael,
>      Yes, I misunderstood the question.
>      Are you specifically wanting to use PETSc's KSP linear solver in
> parallel while your code runs sequentially (and you do not plan to use SNES
> or TS or Tao)? If so then we have code just for that purpose, explained in
> the section
> Using PETSc's MPI parallel linear solvers from a non-MPI program
> in the users manual available at petsc.org
> <https://urldefense.us/v3/__http://petsc.org/__;!!G_uCfscf7eWS!fz7gu-ydCmGQL5TnY6D1UYsCtPN06PH7qvMAmLG7pfOYZPc2OyKY_uIne_Yau1PHu2cOo9BZ_hNO2c3-h6blFkFi$>
> The PETSc code manages all the parallelism and spreading out of the matrix
> and vectors to the multiple processes. You just write a sequential program
> that uses KSP and calls KSPSolve(), make sure it works correctly and then
> add the options listed in the users manual to run the linear solve in
> parallel.
> If you want to use SNES or TS it will require you to manage moving the
> vectors and matrices in your code from sequential to parallel using PETSc
> calls. But again you would just get your code running correctly with PETSc
> sequentially and then add some extra boilerplate to use the PETSc parallel
> solvers with it.
>   Barry
> On Jan 16, 2026, at 10:03 AM, Michael Whitten via petsc-users <
> Both of your points elude to my other question so I am going to ask it in
> this thread.
> Is it possible/recommended/reasonable to run my current code sequentially,
> call a function that interfaces with the PETSc solver which runs parallel,
> and return a sequential vector to my code?
>    1. I understand your point about the additional memory usage. However,
>    I am imagining v1 as my Fortran vector passed into a function. It is
>    possible that my current plan is quite inefficient as I am becoming more
>    aware of how much of a novice I am in parallel computing.
>    2. I don't need PETSc's entire parallel vector on each process. This
>    was not my understanding of that part of the code. I need the entire vector
>    returned to my sequential code.
> I think I am trying to do something intermediate between completely
> sequential and completely parallel.
> Michael
> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
> petsc-users-request at mcs.anl.gov <petsc-users-request at mcs.anl.gov>
> *Sent:* Friday, January 16, 2026 9:52 AM
> *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* petsc-users Digest, Vol 205, Issue 12
> Send petsc-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893354257*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=XiW8wenO4*2B2NKhgAqOP9ew9u31fdVug9JZmSw3WCqio*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEvz6ygtHv$
> <https://lists.mcs.anl.gov/mailman/listinfo/petsc-users >
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
>    1. Re:  petsc-users Digest, Vol 205, Issue 2 (Barry Smith)
> Message: 1
> Date: Fri, 16 Jan 2026 08:51:29 -0600
> From: Barry Smith <bsmith at petsc.dev>
> To: Michael Whitten <mwhitte6 at jhu.edu>
> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] petsc-users Digest, Vol 205, Issue 2
> Message-ID: <B9AF4754-FD0B-49BC-8A34-4D3F51F5C7FC at petsc.dev>
> Content-Type: text/plain; charset="utf-8"
> 1) For the code
>    v1 = 1.0d0
>     PetscCallA(VecCreate(PETSC_COMM_WORLD,v1p,ierr))
>     PetscCallA(VecGetArray(v1p,v1ptr,ierr))
>     v1ptr = v1
>     PetscCallA(VecRestoreArray(v1p,v1ptr,ierr))
>   This produces two copies of the array plus time to copy values over.
> Instead drop the v1 completely and just use
>     v1ptr = 1.0d0  ! or fill it up with a loop etc
>   2) If you want/need PETSc's entire parallel vector on each process then
> you have no choice but to use the code you wrote with VecScatter.  Normally
> when writing a new MPI code from scratch one designs it so the entire
> vector is never needed together on a single process (because that is not
> scalable) but if you have a current code you need to work with this is an
> ok way to start.
>    Barry
> > On Jan 16, 2026, at 8:40?AM, Michael Whitten via petsc-users <
> > I hope that I am replying in the correct manner to respond to the
> "Having trouble with basic Fortran-PETSc interoperability" thread I
> previously started. If not, please correct me.
> > Thank you everyone for your replies, they were very helpful.
> > I have what appears to be a working example code using the suggested
> updates, specifically the VecGetArray() and VecRestoreArray() and getting
> the sequential vector back from PETSc using the information from the FAQ.
> <<Example code attached>>
> > I have a question about this example code to make sure I am writing
> reasonably efficient code. It seems like I have to create an additional
> PETSc vector 'out_seq' which will essentially be a copy of the PETSc vector
> 'v1p' which is not the most efficient use of memory. It also seems to me
> like there isn't a way around this additional 'out_seq' vector because
> there needs a place to aggregate the data from the various processes. Is
> this a reasonable use of PETSc or is there a more efficient way? Note, I am
> trying to interface my existing code base with PETSc to use the solvers and
> this may be the performance trade-off for not developing my program fully
> within the PETSc ecosystem.
> > I have another question only tangentially related to this topic. Should
> I ask it as part of this thread or create a new topic?
> > Michael
> > From: petsc-users <petsc-users-bounces at mcs.anl.gov <
> mailto:petsc-users-bounces at mcs.anl.gov <petsc-users-bounces at mcs.anl.gov>>>
> on behalf of petsc-users-request at mcs.anl.gov<
> mailto:petsc-users-request at mcs.anl.gov <petsc-users-request at mcs.anl.gov>>
> <petsc-users-request at mcs.anl.gov <mailto:petsc-users-request at mcs.anl.gov
> <petsc-users-request at mcs.anl.gov>>>
> > Sent: Saturday, January 3, 2026 1:00 PM
> > To: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov
> <petsc-users at mcs.anl.gov>> <petsc-users at mcs.anl.gov <
> mailto:petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>>>
> > Subject: petsc-users Digest, Vol 205, Issue 2
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttps*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users*26data*3D05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600339697177*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C*26sdata*3DJh2MHiTm*2Fj3*2Ft6gyDoGp295Ex3SzJAW0iyV7GN*2FDN0o*3D*26reserved*3D0__*3BJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUp58-iEhM*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893387619*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=bJNbqOfO7jxYhemrhUYKP53ocQ*2BipAdFWeq8qtU9v2Q*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKiolJSoqKioqKioqKioqKioqKiolJSoqKiolJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv5_dAoo1$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600339697177*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=Jh2MHiTm*2Fj3*2Ft6gyDoGp295Ex3SzJAW0iyV7GN*2FDN0o*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUp58-iEhM$>
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893419172*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=oF1WV15F2HwHTXa1mMb95KKl6MGMxmN*2BINiJ25rqSto*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEvyF9FaW2$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893419172*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=oF1WV15F2HwHTXa1mMb95KKl6MGMxmN*2BINiJ25rqSto*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4vv1BzWp$>
> >         petsc-users-owner at mcs.anl.gov <
> mailto:petsc-users-owner at mcs.anl.gov <petsc-users-owner at mcs.anl.gov>>
> > Today's Topics:
> >    1. Re:  Having trouble with basic Fortran-PETSc interoperability
> >       (Barry Smith)
> >    2. Re:  Having trouble with basic Fortran-PETSc interoperability
> >       (Matthew Knepley)
> > Message: 1
> > Date: Fri, 2 Jan 2026 16:33:27 -0500
> > From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev
> <bsmith at petsc.dev>>>
> > To: Michael Whitten <mwhitte6 at jhu.edu <mailto:mwhitte6 at jhu.edu
> <mwhitte6 at jhu.edu>>>
> > Cc: "petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov
> <petsc-users at mcs.anl.gov>>" <petsc-users at mcs.anl.gov <
> > Subject: Re: [petsc-users] Having trouble with basic Fortran-PETSc
> >         interoperability
> > Message-ID: <3B11AFD2-F767-4D6A-9CB6-D8D153BEA27E at petsc.dev <
> mailto:3B11AFD2-F767-4D6A-9CB6-D8D153BEA27E at petsc.dev
> <3B11AFD2-F767-4D6A-9CB6-D8D153BEA27E at petsc.dev>>>
> >   VecGetValues() uses 0 based indexing in both Fortran and C.
> >    You don't want to use VecGetValues() and VecSetValues() usually since
> they result in two copies of the arrays and copying entire arrays back and
> forth.
> >   You can avoid copying between PETSc vectors and your arrays by using
> VecGetArray(), VecGetArrayWrite(), and VecGetArrayRead(). You can also use
> VecCreateMPIWithArray() to create a PETSc vector using your array; for
> example for input to the right hand side of a KSP. These arrays start their
> indexing with the Fortran default of 1.
> >   Barry
> > > On Jan 2, 2026, at 2:42?PM, Michael Whitten via petsc-users <
> <petsc-users at mcs.anl.gov>>> wrote:
> > > Hi PETSc mailing list users,
> > > I have managed to install PETSc and run some PETSc examples and little
> test codes of my own in Fortran. I am now trying to make PETSc work with my
> existing Fortran code. I have tried to build little test examples of the
> functionality that I can then incorporate into my larger code base.
> However, I am having trouble just passing vectors back and forth between
> PETSc and Fortran.
> > > I have attached a minimum semi-working example that can be compiled
> with the standard 'Makefile.user'. It throws an error when I try to copy
> the PETSc vector back to a Fortran vector using VecGetValues(). I get that
> it can only access values of the array on the local process but how do I
> fix this? Is this even the right approach?
> > > In the final implementation I want to be able to assemble my matrix
> and vector, convert them to PETSc data structures, use PETSc to solve, and
> then convert the solution vector back to Fortran and return. I want to be
> able to do this with both the linear and nonlinear solvers. It seems like
> this is what PETSc is, in part, built to do. Is this a reasonable
> expectation to achieve? Is this a reasonable use case for PETSc?
> > > Thanks in advance for any help you can offer.
> > > best,
> > > Michael
> > > <test.F90>
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttp*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fedfefca2*2Fattachment-0001.html*26data*3D05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350658200*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C*26sdata*3DrgN4n0umo9J7Jj50HJVWtGub3AKBXQljLjTM5c4u19I*3D*26reserved*3D0__*3BJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUp3Vo7fCQ*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893442508*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=iG8rnruM8*2B6c2bnI*2FwtjoL7EpswYF6xJdZqraBAeCxE*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKioqKiolJSoqKioqKioqKioqKioqKiolJSolJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEvxhMpUKz$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttp*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fedfefca2*2Fattachment-0001.html*26data*3D05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350658200*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C*26sdata*3DrgN4n0umo9J7Jj50HJVWtGub3AKBXQljLjTM5c4u19I*3D*26reserved*3D0__*3BJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUp3Vo7fCQ*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893442508*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=iG8rnruM8*2B6c2bnI*2FwtjoL7EpswYF6xJdZqraBAeCxE*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKioqKiolJSoqKioqKioqKioqKioqKiolJSolJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4vEsJUDv$>
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=http*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fedfefca2*2Fattachment-0001.html&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893465042*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=kFnDIwMbwkWWM6*2B4pnQcu2E17DR6qdaFQucWm5WleI0*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv1gI9bsE$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=http*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fedfefca2*2Fattachment-0001.html&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893465042*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=kFnDIwMbwkWWM6*2B4pnQcu2E17DR6qdaFQucWm5WleI0*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4qkE12aj$>
> > Message: 2
> > Date: Fri, 2 Jan 2026 17:49:30 -0500
> > From: Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com
> <knepley at gmail.com>>>
> >         interoperability
> > Message-ID:
> CAMYG4GmKRM1=CoK6JWbo6iTWVPKksepEOH1q1CLLKgr2QhKKDw at mail.gmail.com<
> mailto:CAMYG4GmKRM1=CoK6JWbo6iTWVPKksepEOH1q1CLLKgr2QhKKDw at mail.gmail.com
> <CAMYG4GmKRM1=CoK6JWbo6iTWVPKksepEOH1q1CLLKgr2QhKKDw at mail.gmail.com>>>
> > On Fri, Jan 2, 2026 at 2:48?PM Michael Whitten via petsc-users <
> with my
> the
> between
> > > PETSc and Fortran.
> with
> > > the standard 'Makefile.user'. It throws an error when I try to copy the
> it
> fix
> > No. You should just call VecGetArray(), to get back an F90 pointer to the
> > values. This is much more convenient.
> > > In the final implementation I want to be able to assemble my matrix and
> then
> able
> this
> expectation to
> > Yes, that should work getting the array directly.
> >   Thanks,
> >      Matt
> > > best,
> > > Michael
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> their
> > experiments lead.
> > -- Norbert Wiener
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttps*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fwww.cse.buffalo.edu*2F*knepley*2F__*3Bfg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrh36ooFV*24*26data*3D05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350676162*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C*26sdata*3D8Uw0xpICKrArvT*2FWBDWc*2B*2FNJ6X9VgHWbSXFPKtK0R7g*3D*26reserved*3D0__*3BJSUlJSUlJSUlKiUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUpbgPoAsw*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893486117*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=UoISAPwso2SSB7TL3cam0gW9J3X7h28d20sSsj*2Bz52s*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKioqKioqKioqJSUqKioqKioqKioqKioqKioqJSUqKioqJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv41qp_JZ$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fwww.cse.buffalo.edu*2F*knepley*2F__*3Bfg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrh36ooFV*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350676162*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=8Uw0xpICKrArvT*2FWBDWc*2B*2FNJ6X9VgHWbSXFPKtK0R7g*3D&reserved=0__;JSUlJSUlJSUlKiUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUpbgPoAsw$>
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fwww.cse.buffalo.edu*2F*knepley*2F__*3Bfg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrh36ooFV*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893506591*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=CLYc3zvivKWDIM8qpc*2Bun3toP5*2BfPFeJuUPu2iXh*2Fqw*3D&reserved=0__;JSUlJSUlJSUlKiUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv_DN83Ch$
> <https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrh36ooFV$>>
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protec&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893525859*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=TE9R*2FHbQCG0c9V4jmhI6MF7KC95c5BoRqLfmZMd8ZVs*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv6HdE0VC$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protec&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893525859*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=TE9R*2FHbQCG0c9V4jmhI6MF7KC95c5BoRqLfmZMd8ZVs*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4mCiXk_3$>
> tion.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__http*3A*2F*2Fwww.cse.buffalo.edu*2F*knepley*2F__*3Bfg!!G_uCfscf7eWS
> <https://urldefense.us/v3/__http://tion.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__http*3A*2F*2Fwww.cse.buffalo.edu*2F*knepley*2F__*3Bfg!!G_uCfscf7eWS__;KioqKioqKioqKioq!!G_uCfscf7eWS!fz7gu-ydCmGQL5TnY6D1UYsCtPN06PH7qvMAmLG7pfOYZPc2OyKY_uIne_Yau1PHu2cOo9BZ_hNO2c3-h1cpqLf0$>
> !dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrgy-5x4Z*24&data=05*7C02*7Cmwhitte6*
> 40jhu.edu
> <https://urldefense.us/v3/__http://40jhu.edu/__;!!G_uCfscf7eWS!fz7gu-ydCmGQL5TnY6D1UYsCtPN06PH7qvMAmLG7pfOYZPc2OyKY_uIne_Yau1PHu2cOo9BZ_hNO2c3-hztz5foB$>*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350692343*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=DbQtrUptuDX88vl*2FuO2cXRuwy4JMHfKDnFDj5mAMF6s*3D&reserved=0__;JSUlJSUlJSUlKiUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUpKLKGLaU$
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttps*3A*2F*2Furldefense.us*2Fv3*2F__http*3A*2F*2Fwww.cse.buffalo.edu*2F*knepley*2F__*3Bfg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrgy-5x4Z*24*26data*3D05*7C02*7Cmwhitte6&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893547277*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=49sfRYYe8EnUK4hd3PMxkjgcUauw6uRaZEnsz4FRD0E*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKioqKioqKioqJSUqKiUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv2zX6UlQ$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttps*3A*2F*2Furldefense.us*2Fv3*2F__http*3A*2F*2Fwww.cse.buffalo.edu*2F*knepley*2F__*3Bfg!!G_uCfscf7eWS!dmDhrQx1yGPd8y7YN9DUoj7jpohDJracq1zV5hiJ4GBq5ELNqsZZY7ymYloqOdThUhLu3seGNM2xrgy-5x4Z*24*26data*3D05*7C02*7Cmwhitte6&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893547277*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=49sfRYYe8EnUK4hd3PMxkjgcUauw6uRaZEnsz4FRD0E*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKioqKioqKioqJSUqKiUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4oHqsghB$>
>  *40jhu.edu
> <https://urldefense.us/v3/__http://40jhu.edu/__;!!G_uCfscf7eWS!fz7gu-ydCmGQL5TnY6D1UYsCtPN06PH7qvMAmLG7pfOYZPc2OyKY_uIne_Yau1PHu2cOo9BZ_hNO2c3-hztz5foB$>*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350692343*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=DbQtrUptuDX88vl*2FuO2cXRuwy4JMHfKDnFDj5mAMF6s*3D&reserved=0__;JSUlJSUlJSUlKiUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!e5Z4bqpGanLUgkl1LVgQhM9FRHLRN-xFXCFpnkMtJ-l38HzJqQ3xHhR2i-mB0G6XbKMBZWzNnqZO2LHglZ2lM1HK$>
> > URL: <
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttp*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fe60566c6*2Fattachment-0001.html*26data*3D05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350708618*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C*26sdata*3DePJIVOq1D6x6W2Lt7tvgtIXIL71CpCJaZpel*2BvG0r1I*3D*26reserved*3D0__*3BJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUp_2aaxZg*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893571057*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=4*2BIz4xw7Rz5*2F9g*2FN*2BcECWNSDa8s5Gorh*2F6kgrrqLxkg*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKioqKiolJSoqKioqKioqKioqKioqKiolJSoqJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv0jF_L2r$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttp*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fe60566c6*2Fattachment-0001.html*26data*3D05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350708618*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C*26sdata*3DePJIVOq1D6x6W2Lt7tvgtIXIL71CpCJaZpel*2BvG0r1I*3D*26reserved*3D0__*3BJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUp_2aaxZg*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893571057*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=4*2BIz4xw7Rz5*2F9g*2FN*2BcECWNSDa8s5Gorh*2F6kgrrqLxkg*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKioqKiolJSoqKioqKioqKioqKioqKiolJSoqJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4tae2GrW$>
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=http*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fe60566c6*2Fattachment-0001.html&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893598980*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=aq*2BqnjbbjP53P9Aa3gFyyJVzsaHVliHAF4*2FH5VaIkmo*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv5Jm1dIL$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=http*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260102*2Fe60566c6*2Fattachment-0001.html&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893598980*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=aq*2BqnjbbjP53P9Aa3gFyyJVzsaHVliHAF4*2FH5VaIkmo*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4vaQHSDB$>
> > Subject: Digest Footer
> > _______________________________________________
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Furldefense.us*2Fv3*2F__https*3A*2F*2Fnam02.safelinks.protection.outlook.com*2F*3Furl*3Dhttps*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users*26data*3D05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350725058*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C*26sdata*3DUeb*2F8ra8XpzYQzLTm4qwWVo9lyMGs2P5*2FMD0nA3xsdg*3D*26reserved*3D0__*3BJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUpdaF8pOQ*24&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893633070*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=fmFnefcmhqrsOsKFsdq7Krc*2F0CDtDuB*2FCXbtDn6Rnr4*3D&reserved=0__;JSUlJSUlJSUlJSUqKioqKiolJSoqKioqKioqKioqKioqKiolJSoqKiUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv-4OOChV$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C094639f3b5f5405cfc4e08de4af1fa67*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639030600350725058*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=Ueb*2F8ra8XpzYQzLTm4qwWVo9lyMGs2P5*2FMD0nA3xsdg*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!bIMcmpMdXbyTPg56scE6PGSFLgQ9D07NeoK_UCdRbCrnEdwa1m3aLzbnLed2KLUNJJyHJeWiICB-ePUpdaF8pOQ$>
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893670294*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=o0XY48*2BZ5oVC0TxiObgNwusKIUub*2B3MPR6S30YvHQfI*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv7yMEE_u$
> <https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893670294*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=o0XY48*2BZ5oVC0TxiObgNwusKIUub*2B3MPR6S30YvHQfI*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!bhoEoF0XYYKl-EOyDlgI2fLPdGcIPgvLKpHDlZJ8j2J8urOsoci3Ml3KBNAv13782FIpFxECA2a2yLsA4l248JZj$>
> > End of petsc-users Digest, Vol 205, Issue 2
> > <test2.F90>
> URL: <
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=http*3A*2F*2Flists.mcs.anl.gov*2Fpipermail*2Fpetsc-users*2Fattachments*2F20260116*2F43b99245*2Fattachment.html&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893707812*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=8SaySLzxsoms5Vhl5vuo4PxEm4Insv3hcr*2BbbHKjgyI*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEvz0X4OjD$
> <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260116/43b99245/attachment.html >
> https://urldefense.us/v3/__https://nam02.safelinks.protection.outlook.com/?url=https*3A*2F*2Flists.mcs.anl.gov*2Fmailman*2Flistinfo*2Fpetsc-users&data=05*7C02*7Cmwhitte6*40jhu.edu*7C24e75a940a1946f44a3608de550f304c*7C9fa4f438b1e6473b803f86f8aedf0dec*7C0*7C0*7C639041720893746146*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=gNKZtz*2B5BHwQe2nCwMnYBo0dFDdYJ6lNPFaeElUrAOw*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv_zfyPm2$
> End of petsc-users Digest, Vol 205, Issue 12
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEvw-qbTXN$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fCGSZ-K1lcfkVVEE95E8-TrDnok3eRJazqaX6N_DdWheUklbAIZiBVeslnlaotQT6iOErmawK4OEv5WJUSXq$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260116/0e4a3a35/attachment-0001.html>
