[petsc-users] PETSc GPU matrix creation
Junchao Zhang
junchao.zhang at gmail.com
Wed Jan 14 13:32:51 CST 2026
BTW, are the i[], j[] arrays of the CSR matrix on the GPU, or merely the
value array a[]?
--Junchao Zhang
On Tue, Jan 13, 2026 at 12:50 PM Alberto Cattaneo via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Greetings
> I hope this email reaches you all well. I was wondering whether it was
> possible to create PETSc mat objects directly from data that exists on the
> GPU in AIJ format without copying? For example, either via DLPack or just
> an assurance that the pointer provided to a creation method is in the
> needed AIJ format? Ideally, I'd like to be able to build a PETSc
> AIJCUSPARSE object out of data created by another program. I know there are
> a few builder methods and paradigms, but I'm a bit confused as to which
> would be ideal in this circumstance since in some sense the matrix is
> already created in memory, just not as a PETSc object.
> Thank you for your assistance, please let me know if I should provide more
> information.
> Respectfully:
> Alberto Cattaneo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260114/69a1e60d/attachment.html>
