[petsc-users] PETSc GPU matrix creation
Junchao Zhang junchao.zhang at gmail.com
Tue Jan 13 17:14:45 CST 2026
Note we have MatCreateSeqAIJKokkosWithKokkosViews(MPI_Comm, PetscInt,
PetscInt, Kokkos::View<PetscInt *> &, Kokkos::View<PetscInt *> &,
Kokkos::View<PetscScalar *> &, Mat *);
Yes, I think we could provide MatCreateSeqAIJCUSPARSEWithArrays(MPI_Comm
comm, PetscInt m, PetscInt n, PetscInt i[], PetscInt j[], PetscScalar a[],
Mat *mat) with i, j, a on device.  Note we already have
MatCreateMPIAIJWithSeqAIJ(MPI_Comm comm, Mat A, Mat B, const PetscInt
garray[], Mat *mat).  With that, users are able to create MPIAIJ matrices
on device with their own data, if they can manage the complexity.
--Junchao Zhang
On Tue, Jan 13, 2026 at 4:15 PM Jed Brown <jed at jedbrown.org> wrote:
> Note that petsc4py does have DLPack interfaces for Vec. So if you like
> DLPack, you could extend those interfaces.
> Also, MatSetValuesCOO can assemble matrices in which all the data is
> provided on the device. If you're generating sparse matrices on device,
> that routine is likely to be useful.
> Barry Smith <bsmith at petsc.dev> writes:
> >   Alberto,
> >     We don't have such a routine yet, but we should and it would not be
> terribly difficult to implement (using pieces of PETSc that already exist
> and cut and pasting them into a new function
> MatCreateSeqAICUSPARSEWithArrays()).
> >    Barry
> >> On Jan 13, 2026, at 1:44 PM, Alberto Cattaneo via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> >> Greetings
> >> I hope this email reaches you all well. I was wondering whether it was
> possible to create PETSc mat objects directly from data that exists on the
> GPU in AIJ format without copying? For example, either via DLPack or just
> an assurance that the pointer provided to a creation method is in the
> needed AIJ format? Ideally, I'd like to be able to build a PETSc
> AIJCUSPARSE object out of data created by another program. I know there are
> a few builder methods and paradigms, but I'm a bit confused as to which
> would be ideal in this circumstance since in some sense the matrix is
> already created in memory, just not as a PETSc object.
> >> Thank you for your assistance, please let me know if I should provide
> more information.
> >> Respectfully:
> >> Alberto Cattaneo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20260113/8a14856d/attachment.html>
