[petsc-users] [EXTERNAL] Reading -options_file
Barry Smith bsmith at petsc.dev
Thu Sep 18 15:55:44 CDT 2025
   Build a PETSC_ARCH with -with-debugging=yes as a configure option and run it, preferably in a debugger (for example -start_in_debugger option) to find out where the bus error is taking place.
> On Sep 18, 2025, at 4:42 PM, Riousset, Jeremy via petsc-users <petsc-users at mcs.anl.gov> wrote:
> That helped. I now read my input file correctly. I am getting an error with the line below:
> DM da;
> ierr = DMDACreate3d(PETSC_COMM_WORLD,DM_BOUNDARY_GHOSTED,DM_BOUNDARY_GHOSTED,DM_BOUNDARY_GHOSTED,DMDA_STENCIL_STAR,21,21,21,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,19,1,PETSC_NULL,PETSC_NULL,PETSC_NULL,&da);CHKERRQ(ierr);
> The error is:
> 0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly illegal memory access
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!fh2X84CPIXKaFn6PkQPhrXJHX2qplg9tKOZ5R9PVc5RWTkcgK4phevcVoO3P_YgU5vu4GZREF8o52gfFFZ4W1b0$  <https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!drLsYfgMTCNAyHHkj7gJrIUzQ9gnkjwyajLeWWqLLyV3mEdA2B7X0fX4pFYTyw9FVWpCJQ7BKm4Ba2f-wE5DJLwP$> and https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fh2X84CPIXKaFn6PkQPhrXJHX2qplg9tKOZ5R9PVc5RWTkcgK4phevcVoO3P_YgU5vu4GZREF8o52gfFoqV6M1A$  <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!drLsYfgMTCNAyHHkj7gJrIUzQ9gnkjwyajLeWWqLLyV3mEdA2B7X0fX4pFYTyw9FVWpCJQ7BKm4Ba2f-wJxIkrms$>
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>   Proc: [[44836,1],0]
>   Errorcode: 59
> Since the code was running with an old version of PETSc, I am wondering what I did to break it.
> Jeremy A. Riousset, Ph.D. (he, him, his)
> Associate Professor of Engineering Physics
> Physical Science
> 1 Aerospace Boulevard
> Daytona Beach, FL 32114
> +1 (386) 226-6407
> jeremy.riousset at erau.edu <mailto:jeremy.riousset at erau.edu>
> https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!fh2X84CPIXKaFn6PkQPhrXJHX2qplg9tKOZ5R9PVc5RWTkcgK4phevcVoO3P_YgU5vu4GZREF8o52gfFDu9pfak$  <https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!drLsYfgMTCNAyHHkj7gJrIUzQ9gnkjwyajLeWWqLLyV3mEdA2B7X0fX4pFYTyw9FVWpCJQ7BKm4Ba2f-wPlXko4P$>
> Embry-Riddle Aeronautical University
> Florida | Arizona | Worldwide
>> On Sep 18, 2025, at 3:59 PM, Barry Smith <bsmith at petsc.dev> wrote:
>> External Sender: Use caution with links, attachments, or when sharing information.
>>   The PETSc options all begin with a single dash, so it is -options_file input/main.in
>>> On Sep 18, 2025, at 3:44 PM, Riousset, Jeremy via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>> Hi,
>>> I’m updating a code from PETSc 3.4 to run with the latest PETSc. Here is my status:
>>> I read the parameters via: mpiexec -n 1 bin/./M4 --options_file input/main.in
>>> I’m not opening main.in correctly
>>> None of the options are retrieved by e.g., PetscOptionsGetReal
>>> Do you have a suggestion to test what file the code is actually trying to access?
>>> Thanks
>>> Physical Science
>>> +1 (386) 226-6407
>>> https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!fh2X84CPIXKaFn6PkQPhrXJHX2qplg9tKOZ5R9PVc5RWTkcgK4phevcVoO3P_YgU5vu4GZREF8o52gfFDu9pfak$  <https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!YiGxTKiNGs8EnS4pzFoO1YK18z4fx-sCtisUBloRO8dd6sUuh3kfUkimanAH5cJ-jgPhYw-Qk_8q8BBxAtPO0s_6$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250918/f03b58af/attachment-0001.html>
