[petsc-users] [EXTERNAL] Reading -options_file
Riousset, Jeremy RIOUSSEJ at erau.edu
Thu Sep 18 15:42:14 CDT 2025
That helped. I now read my input file correctly. I am getting an error with the line below:
DM da;
ierr = DMDACreate3d(PETSC_COMM_WORLD,DM_BOUNDARY_GHOSTED,DM_BOUNDARY_GHOSTED,DM_BOUNDARY_GHOSTED,DMDA_STENCIL_STAR,21,21,21,PETSC_DECIDE,PETSC_DECIDE,PETSC_DECIDE,19,1,PETSC_NULL,PETSC_NULL,PETSC_NULL,&da);CHKERRQ(ierr);
The error is:
0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly illegal memory access
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!drLsYfgMTCNAyHHkj7gJrIUzQ9gnkjwyajLeWWqLLyV3mEdA2B7X0fX4pFYTyw9FVWpCJQ7BKm4Ba2f-wE5DJLwP$  and https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!drLsYfgMTCNAyHHkj7gJrIUzQ9gnkjwyajLeWWqLLyV3mEdA2B7X0fX4pFYTyw9FVWpCJQ7BKm4Ba2f-wJxIkrms$
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
  Proc: [[44836,1],0]
  Errorcode: 59
Since the code was running with an old version of PETSc, I am wondering what I did to break it.
Jeremy A. Riousset, Ph.D. (he, him, his)
Associate Professor of Engineering Physics
Physical Science
1 Aerospace Boulevard
Daytona Beach, FL 32114
+1 (386) 226-6407
jeremy.riousset at erau.edu<mailto:jeremy.riousset at erau.edu>
https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!drLsYfgMTCNAyHHkj7gJrIUzQ9gnkjwyajLeWWqLLyV3mEdA2B7X0fX4pFYTyw9FVWpCJQ7BKm4Ba2f-wPlXko4P$
Embry-Riddle Aeronautical University
Florida | Arizona | Worldwide
On Sep 18, 2025, at 3:59 PM, Barry Smith <bsmith at petsc.dev> wrote:
External Sender: Use caution with links, attachments, or when sharing information.
  The PETSc options all begin with a single dash, so it is -options_file input/main.in
On Sep 18, 2025, at 3:44 PM, Riousset, Jeremy via petsc-users <petsc-users at mcs.anl.gov> wrote:
I’m updating a code from PETSc 3.4 to run with the latest PETSc. Here is my status:
  *   I read the parameters via: mpiexec -n 1 bin/./M4 --options_file input/main.in
  *   I’m not opening main.in correctly
  *   None of the options are retrieved by e.g., PetscOptionsGetReal
Do you have a suggestion to test what file the code is actually trying to access?
Thanks
Physical Science
+1 (386) 226-6407
https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!drLsYfgMTCNAyHHkj7gJrIUzQ9gnkjwyajLeWWqLLyV3mEdA2B7X0fX4pFYTyw9FVWpCJQ7BKm4Ba2f-wPlXko4P$ <https://urldefense.us/v3/__https://orcid.org/0000-0003-1516-5337__;!!G_uCfscf7eWS!YiGxTKiNGs8EnS4pzFoO1YK18z4fx-sCtisUBloRO8dd6sUuh3kfUkimanAH5cJ-jgPhYw-Qk_8q8BBxAtPO0s_6$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250918/0b93e64e/attachment.html>
