[petsc-users] interpreting petsc streams result
Matthew Knepley
knepley at gmail.com
Thu Oct 23 10:17:02 CDT 2025
On Thu, Oct 23, 2025 at 3:42 AM Klaij, Christiaan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Thanks Junchao, that looks good. The zig zag pattern is visible but not as
> wild. The speed up is similar.
We got a similar zigzag on some of the LLNL machines. I think it is a
feature of modern memory architectures.
Matt
> Chris
> From: Junchao Zhang <junchao.zhang at gmail.com>
> Sent: Tuesday, October 21, 2025 11:17 PM
> To: Klaij, Christiaan
> Cc: PETSc users list
> Subject: Re: [petsc-users] interpreting petsc streams result
> Hi, Chris,
> I think I am done with the MR,
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7651__;!!G_uCfscf7eWS!f0ym-ubSw0zZ557es-25JfsDmPjk4EAhMPYF65uYFefhx7maXr2_xgDoONAvCV6uAJ-WpEtJKblk9W7m4wDWgDU$
> You can look at the sample output there. The array size is now very
> large, supporting an aggregated L3 cache size of 1,920MB.
> --Junchao Zhang
> On Tue, Oct 21, 2025 at 6:17 AM Klaij, Christiaan <C.Klaij at marin.nl
> <mailto:C.Klaij at marin.nl>> wrote:
> OK, experiments will have to wait till we get the hardware.
> Can you give me a sign when you are done with the merge request? I
> would like to try with the increased array size, other vendors
> already warned me that "the array in stream is quiet small".
> Chris
> From: Junchao Zhang <junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>
> Sent: Monday, October 20, 2025 6:36 PM
> Hi, Chris,
> Since we compute the speed up off the bandwidth achieved by a single MPI
> process, and a process can drive all memory channels, the maximum speed up
> can only come from experiments (vs. not by # of memory channels).
> --Junchao Zhang
> On Mon, Oct 20, 2025 at 9:45 AM Klaij, Christiaan <C.Klaij at marin.nl
> <mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>
> wrote:
> Hi Junchao,
> Thanks for you answer. Regarding the speed-up what would you expect if not
> 24 out of 64, and why?
> Chris
> [cid:ii_19a027041d3d825dd561]
> dr. ir. Christiaan Klaij | senior researcher
> Research & Development | CFD Development
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!f0ym-ubSw0zZ557es-25JfsDmPjk4EAhMPYF65uYFefhx7maXr2_xgDoONAvCV6uAJ-WpEtJKblk9W7mdXphyZs$
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!f0ym-ubSw0zZ557es-25JfsDmPjk4EAhMPYF65uYFefhx7maXr2_xgDoONAvCV6uAJ-WpEtJKblk9W7muq8j-ds$
> [Facebook]<
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!f0ym-ubSw0zZ557es-25JfsDmPjk4EAhMPYF65uYFefhx7maXr2_xgDoONAvCV6uAJ-WpEtJKblk9W7mLqrnypA$
> [LinkedIn]<
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!f0ym-ubSw0zZ557es-25JfsDmPjk4EAhMPYF65uYFefhx7maXr2_xgDoONAvCV6uAJ-WpEtJKblk9W7mzmmkNA0$
> [YouTube]<
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!f0ym-ubSw0zZ557es-25JfsDmPjk4EAhMPYF65uYFefhx7maXr2_xgDoONAvCV6uAJ-WpEtJKblk9W7mZCDzHLA$
> junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>>
> Sent: Friday, October 17, 2025 5:01 PM
> Hi, Chris,
> I did have an MR
> to improve mpistream. I should rework it after Barry's !6903. See my
> inlined comments to your questions
> On Fri, Oct 17, 2025 at 3:37 AM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>> wrote:
> Attached is a petsc streams result kindly provided by a hardware
> vendor for a single compute node, dual socket, with two AMD epyc
> 9355 processors. Each processor has 32 cores, 12 DDR5 memory
> channels and mem BW around 600 GB/s.
> * It is not immediately clear which line corresponds to which
> y-axis. Could future versions of petsc please color the axis
> label with the matching line color?
> definitely
> * Why would the achieved bandwidth be roughly 0.9 x 1e6 MB/s =
> 900 GB/s and not closer to 1200 GB/s?
> I recall it is actually not simple to get the theoretical max bandwidth.
> One has to use special SIMD instructions, compiler flags and streaming
> stores etc.
> * The speed-up seems to be 12 out of 64, provided multiples of 8
> cores are used. As expected given 12 memory channels?
> Maybe not, otherwise the speedup should be 24 as you have 24 channels.
> * Does the zig-zag pattern indicate a pinning problem, or is it
> unavoidable given the 8 core building block of these type of
> processors?
> I checked and found "make mpistream" uses --map-by core. I think we should
> use --map-by socket or --map-by l3cache.
> Chris
> [cid:ii_199f2a38566119b24a61]
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsBfp_z4A$
> [Facebook]<
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsCH7BGfA$
> [LinkedIn]<
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsDAV2fAI$
> [YouTube]<
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsEyu_yEs$
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!boS7CONGoGsO-g_0kexht90PXVFByjM2hxfLoPcZujw3MfTTD2rgVTfHepnuDOTfFNns0nI00eSQF6cNS32E$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!boS7CONGoGsO-g_0kexht90PXVFByjM2hxfLoPcZujw3MfTTD2rgVTfHepnuDOTfFNns0nI00eSQFzDIxKGd$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251023/5260cf37/attachment-0001.html>
