[petsc-users] interpreting petsc streams result
Junchao Zhang
junchao.zhang at gmail.com
Mon Oct 20 11:36:11 CDT 2025
Hi, Chris,
Since we compute the speed up off the bandwidth achieved by a single MPI
process, and a process can drive all memory channels, the maximum speed up
can only come from experiments (vs. not by # of memory channels).
--Junchao Zhang
On Mon, Oct 20, 2025 at 9:45 AM Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Hi Junchao,
> Thanks for you answer. Regarding the speed-up what would you expect if not
> 24 out of 64, and why?
> Chris
> dr. ir. Christiaan Klaij | senior researcher
> Research & Development | CFD Development
> T +31 317 49 33 44 <+31%20317%2049%2033%2044> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!eWQ9V6JC_rYZNcX9e_xTrfUjf7r2ZdoUyieeSwP7mc9QEj97847bdPUYphA8CBkYwpsrwb65pvMYnmpUnOFERUomu-nz$
> [image: Facebook] <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!eWQ9V6JC_rYZNcX9e_xTrfUjf7r2ZdoUyieeSwP7mc9QEj97847bdPUYphA8CBkYwpsrwb65pvMYnmpUnOFERT9e7Q2s$ >
> [image: LinkedIn] <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!eWQ9V6JC_rYZNcX9e_xTrfUjf7r2ZdoUyieeSwP7mc9QEj97847bdPUYphA8CBkYwpsrwb65pvMYnmpUnOFERUf1DiSy$ >
> [image: YouTube] <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!eWQ9V6JC_rYZNcX9e_xTrfUjf7r2ZdoUyieeSwP7mc9QEj97847bdPUYphA8CBkYwpsrwb65pvMYnmpUnOFERRQd8GVj$ >
> From: Junchao Zhang <junchao.zhang at gmail.com>
> Sent: Friday, October 17, 2025 5:01 PM
> To: Klaij, Christiaan
> Cc: PETSc users list
> Subject: Re: [petsc-users] interpreting petsc streams result
> Hi, Chris,
> I did have an MR https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7651__;!!G_uCfscf7eWS!eWQ9V6JC_rYZNcX9e_xTrfUjf7r2ZdoUyieeSwP7mc9QEj97847bdPUYphA8CBkYwpsrwb65pvMYnmpUnOFERYIUu7jT$ to
> improve mpistream. I should rework it after Barry's !6903. See my inlined
> comments to your questions
> On Fri, Oct 17, 2025 at 3:37 AM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> Attached is a petsc streams result kindly provided by a hardware
> vendor for a single compute node, dual socket, with two AMD epyc
> 9355 processors. Each processor has 32 cores, 12 DDR5 memory
> channels and mem BW around 600 GB/s.
> * It is not immediately clear which line corresponds to which
> y-axis. Could future versions of petsc please color the axis
> label with the matching line color?
> definitely
> * Why would the achieved bandwidth be roughly 0.9 x 1e6 MB/s =
> 900 GB/s and not closer to 1200 GB/s?
> I recall it is actually not simple to get the theoretical max bandwidth.
> One has to use special SIMD instructions, compiler flags and streaming
> stores etc.
> * The speed-up seems to be 12 out of 64, provided multiples of 8
> cores are used. As expected given 12 memory channels?
> Maybe not, otherwise the speedup should be 24 as you have 24 channels.
> * Does the zig-zag pattern indicate a pinning problem, or is it
> unavoidable given the 8 core building block of these type of
> processors?
> I checked and found "make mpistream" uses --map-by core. I think we should
> use --map-by socket or --map-by l3cache.
> Chris
> [cid:ii_199f2a38566119b24a61]
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!eWQ9V6JC_rYZNcX9e_xTrfUjf7r2ZdoUyieeSwP7mc9QEj97847bdPUYphA8CBkYwpsrwb65pvMYnmpUnOFERUomu-nz$ <
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsBfp_z4A$
> [Facebook]<
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsCH7BGfA$
> [LinkedIn]<
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsDAV2fAI$
> [YouTube]<
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsEyu_yEs$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/da16174a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/da16174a/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/da16174a/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/da16174a/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/da16174a/attachment-0003.png>
