[petsc-users] interpreting petsc streams result
Klaij, Christiaan
C.Klaij at marin.nl
Mon Oct 20 09:45:29 CDT 2025
Hi Junchao,
Thanks for you answer. Regarding the speed-up what would you expect if not 24 out of 64, and why?
Chris
_____
dr. ir. Christiaan Klaij | senior researcher
Research & Development | CFD Development
T +31 317 49 33 44 | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!dkRjTO35gYlTQIMwhRteR45CyztokJhS-tZqqfhmLbel4doCt4smq3sAWssIeXAtdh9w2ffm5zooSLNT-LxhuP4$
___________________________________
Sent: Friday, October 17, 2025 5:01 PM
To: Klaij, Christiaan
Cc: PETSc users list
Subject: Re: [petsc-users] interpreting petsc streams result
Hi, Chris,
I did have an MR https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7651__;!!G_uCfscf7eWS!dkRjTO35gYlTQIMwhRteR45CyztokJhS-tZqqfhmLbel4doCt4smq3sAWssIeXAtdh9w2ffm5zooSLNTuKitErU$ to improve mpistream. I should rework it after Barry's !6903. See my inlined comments to your questions
On Fri, Oct 17, 2025 at 3:37 AM Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Attached is a petsc streams result kindly provided by a hardware
vendor for a single compute node, dual socket, with two AMD epyc
9355 processors. Each processor has 32 cores, 12 DDR5 memory
channels and mem BW around 600 GB/s.
* It is not immediately clear which line corresponds to which
y-axis. Could future versions of petsc please color the axis
label with the matching line color?
definitely
* Why would the achieved bandwidth be roughly 0.9 x 1e6 MB/s =
900 GB/s and not closer to 1200 GB/s?
I recall it is actually not simple to get the theoretical max bandwidth. One has to use special SIMD instructions, compiler flags and streaming stores etc.
* The speed-up seems to be 12 out of 64, provided multiples of 8
cores are used. As expected given 12 memory channels?
Maybe not, otherwise the speedup should be 24 as you have 24 channels.
* Does the zig-zag pattern indicate a pinning problem, or is it
unavoidable given the 8 core building block of these type of
processors?
I checked and found "make mpistream" uses --map-by core. I think we should use --map-by socket or --map-by l3cache.
Chris
[cid:ii_199f2a38566119b24a61]
T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!dkRjTO35gYlTQIMwhRteR45CyztokJhS-tZqqfhmLbel4doCt4smq3sAWssIeXAtdh9w2ffm5zooSLNT-LxhuP4$ <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsBfp_z4A$>
[Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsCH7BGfA$>
[LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsDAV2fAI$>
[YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!fqSBpN3Ld5fjzXGShGI09uJke12M-5LukEHe-y-gw0Bw9msZeH7wNiId6DZxQpluR_RUWpuoQWUD2HSsEyu_yEs$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0001.html>
Type: image/png
Desc: image014564.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0008.png>
Type: image/png
Desc: image076541.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0009.png>
Type: image/png
Desc: image600589.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0010.png>
Type: image/png
Desc: image758659.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0011.png>
Type: image/png
Desc: image918583.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0012.png>
Type: image/png
Desc: image489453.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0013.png>
Type: image/png
Desc: image542102.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0014.png>
Type: image/png
Desc: image611951.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251020/02d27eae/attachment-0015.png>
