[petsc-users] extract arbitrary subset of a DMDA
Matteo Semplice matteo.semplice at uninsubria.it
Fri Oct 10 08:48:35 CDT 2025
Dear all,
     I am wondering if there is a way to extract a subset of a DMDA and
use it as a mesh. The use case is to program a finite-difference method
in which the domain is defined by a levelset function: if I could
completely ignore the parts of the background DMDA that are "far away"
from the object, I guess I would avoid some cores having almost no
workload. I figure that I could setup a DMDA, load/compute the levelset
on the entire box, then mark the nodes to be retained, extract the
submesh and repartition it. I would also need a mean to transfer some
Vec data from the DMDA to the new mesh.
I guess that the extracted mesh would then become a DMPlex and it would
not retain any DMDA flavour (like notions of which are the grid nodes
sitting on top/bottom, left/right of a given node), right?
Thanks
     Matteo
Prof. Matteo Semplice
Università degli Studi dell’Insubria
Dipartimento di Scienza e Alta Tecnologia – DiSAT
Professore Associato
Via Valleggio, 11 – 22100 Como (CO) – Italia
tel.: +39 031 2386316
