[petsc-users] [C/Fortran] Calling DMPlexComputeCellGeometryFEM in a loop
    Noam T.
    dontbugthedevs at proton.me
    Mon May 12 16:29:35 CDT 2025
Hello,
I ran into a seemingly non-consistent behavior of the function
[DMPlexComputeCellGeometryFEM](https://urldefense.us/v3/__https://petsc.org/release/manualpages/DMPlex/DMPlexComputeCellGeometryFEM/__;!!G_uCfscf7eWS!YEv7_aaCdN0cxV8sUhRBIACYZGNNcwQusNjEpfVep6yOAxRYE9f8kw4XiVENrjEvQEVwiheebMTQVhPw4eenYApT_rJABo0_$ )
[DM](https://urldefense.us/v3/__https://petsc.org/release/manualpages/DM/DM/__;!!G_uCfscf7eWS!YEv7_aaCdN0cxV8sUhRBIACYZGNNcwQusNjEpfVep6yOAxRYE9f8kw4XiVENrjEvQEVwiheebMTQVhPw4eenYApT_kyYWLFi$ )
dm
[PetscInt](https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscInt/__;!!G_uCfscf7eWS!YEv7_aaCdN0cxV8sUhRBIACYZGNNcwQusNjEpfVep6yOAxRYE9f8kw4XiVENrjEvQEVwiheebMTQVhPw4eenYApT_jAVrwAd$ )
cell
[PetscQuadrature](https://urldefense.us/v3/__https://petsc.org/release/manualpages/DT/PetscQuadrature/__;!!G_uCfscf7eWS!YEv7_aaCdN0cxV8sUhRBIACYZGNNcwQusNjEpfVep6yOAxRYE9f8kw4XiVENrjEvQEVwiheebMTQVhPw4eenYApT_jVjnRvX$ )
quad
[PetscReal](https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/PetscReal/__;!!G_uCfscf7eWS!YEv7_aaCdN0cxV8sUhRBIACYZGNNcwQusNjEpfVep6yOAxRYE9f8kw4XiVENrjEvQEVwiheebMTQVhPw4eenYApT_heQHCRx$ )
v
J
invJ
detJ
Calling it in a loop happens to crash, only some times, when the input npoints is not equal to one.
Attached is a mesh file (msh format), consisting of four quadrilaterals. Small examples in both C and Fortran also attached; they read the mesh, create a Gauss tensor quadrature rule and then loop through all cells in order to get the mapped quadrature points.
When the quadrature created has a single point per dimension (npoints = 1), there seems to be no issue. The program runs and the output is the expected.
On the C side, For npoints = 2 the program hangs, usually no errors; sometimes
*** stack smashing detected ***: terminated,
[:1345101] *** Process received signal ***
[:1345101] Signal: Aborted (6)
[:1345101] Signal code: (-6)
or
LeakSanitizer: detected memory leaks (when compiled with -fsanitize=addres).
On the Fortran side, similar behavior for npoints = 1 or 2. Either no error at all (no error meaning the one that only mentions "probably memory access out of bounds"), or sometimes "corrupted size vs. prev_size", followed by a stack trace.
Question: Do the arguments J, invJ need to be allocated (e.g. allocate(J(4))) before calling DMPlexComputeCellGeometryFEM? Allocation seems to be the cause for triggering an error.
NOTE: The interface to DMPlexComputeCellGeometryFEM, under $PETSC_ARCH$/ftn/dm/petscdmplex.h90, read:
interface DMPlexComputeCellGeometryFEM
subroutine DMPlexComputeCellGeometryFEM(a,b,c,d,e,f,g, z)
import tDM,tPetscQuadrature
DM :: a
PetscInt :: b
PetscQuadrature :: c
PetscReal :: d #### should it be d(*) ?
PetscReal :: e(*)
PetscReal :: f(*)
PetscReal :: g
PetscErrorCode z
end subroutine
end interface
Should argument d (referring to the array of the mapped integration points v) be defined differently?
NOTE: Tested with PETSc 3.23.1 (from the tarball) and the latest git.
Configured with ./configure --with-fortran-bindings=1
Using gcc/gfortran 11.4.0, OpenMPI 4.1.2
Noam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250512/62b630b5/attachment.html>
Type: model/mesh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250512/62b630b5/attachment.msh>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250512/62b630b5/attachment.bin>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250512/62b630b5/attachment-0001.bin>
