[petsc-users] PETSc using problem
Matthew Knepley
knepley at gmail.com
Sun May 11 16:11:53 CDT 2025
On Sun, May 11, 2025 at 4:00 PM Barry Smith <bsmith at petsc.dev> wrote:
> I suppose we could call the postcheck even on failure. Then your first
> check in your postcheck would be on SNESLineSearchReason. What line search
> are you using? You could add the postcheck to all the early
> PetscFunctionReturns() in the line search routine.
As I said, I don't think I agree with PostCheck in this scenario.
Matt
> On May 11, 2025, at 11:50 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, May 11, 2025 at 11:39 AM hj2000--- via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear Developer:
>> I am a user of PETSc, and I am using SNESLineSearchSetPostCheck to
>> perform some actions when the line search fails.
>> However, it seems that this function is only called when the line search
>> is successful. Why is that?
> PostCheck is intended to work on the solution found by the line search.
>> Do I need to do something else?
> Yes. We do not have a specific hook for failure, because that would make
> it a different line search (one which may not obey the advertised
> properties). Thus we would want your scheme to be its own line search.
> Thanks,
> Matt
>> My PETSc version is 3.18.6. Below is my code.
>> auto LineSearchPostCheck = []( SNESLineSearch ls, Vec x, Vec y,
>> Vec w, PetscBool* changed_Y,
>> PetscBool* changed_W, void* ) {
>> SNESLineSearchReason lscnv;
>> SNESLineSearchGetReason( ls, &lscnv );
>> SNES snes = nullptr;
>> SNESLineSearchGetSNES( ls, &snes );
>> SNESConvergedReason cnv;
>> SNESGetConvergedReason( snes, &cnv );
>> double lambda = 0.0;
>> SNESLineSearchGetLambda( ls, &lambda );
>> PetscPrintf( MPI_COMM_WORLD, "lambda=%lf\n", lambda );
>> if ( lscnv != SNES_LINESEARCH_SUCCEEDED || lambda < 1e-4 )
>> VecWAXPY( w, -0.1, y, x );
>> SNESLineSearchSetReason( ls, SNES_LINESEARCH_SUCCEEDED );
>> *changed_W = PETSC_TRUE;
>> return 0;
>> SNESLineSearchSetPostCheck( ls, LineSearchPostCheck, nullptr);
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!deFm6anFdsGG0BfyGak4ewySR2Mh9Pquul08gXi74TZ_mScnmYbiUZXpoeJy_vLlOyZxW0yM2vZTz5m24eDN$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Y6XIK823eTx-iRg60ThDREJsmpqY4jNxIxr-y3_Li6lAA2rs8JvxNjeeUrgfpgbcSCSaRzhBaYiBH_soe98y$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!deFm6anFdsGG0BfyGak4ewySR2Mh9Pquul08gXi74TZ_mScnmYbiUZXpoeJy_vLlOyZxW0yM2vZTz5m24eDN$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!deFm6anFdsGG0BfyGak4ewySR2Mh9Pquul08gXi74TZ_mScnmYbiUZXpoeJy_vLlOyZxW0yM2vZTz334Wg26$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250511/2ae9e6fb/attachment-0001.html>
