[petsc-users] Solving Stokes problem in high aspect ratio domains
    Mark Adams
    mfadams at lbl.gov
    Fri May  9 14:08:17 CDT 2025
Hi Hardik,
The domain shape is not critical but the element shapes are. Your 100:1
domain aspect ratio is bad if you have N^3 mesh and thus element aspect
ratios of 100:1.
If that is the case then you probably want to look at
semi-coarsening multigrid.
On Fri, May 9, 2025 at 9:55 AM Hardik Kothari <hardik.kothari at corintis.com>
wrote:
> Dear PETSc team,
> We are solving the Stokes equations using PETSc (via Firedrake) on a
> highly anisotropic 3D domain (L_x=1, L_y=0.01, L_z=0.1).
> In this setup, standard Schur complement preconditioners using a mass
> inverse for pressure struggle to converge. We could solve the problem with
> the LSC preconditioner (solver parameters are shown in the script).
> We have the following questions:
>    - Why standard preconditioners struggle in such domains?
>    - Why is the preconditioned residual norm for the Schur complement
>    system much higher than the true residual norm?
>    - Would you recommend alternative or more robust preconditioners for
>    such geometries?
> Thank you for your help.
> Best regards,
> Hardik
> *HARDIK KOTHARI*
> *hardik.kothari at corintis.com* <hardik.kothari at corintis.com>
> Corintis SA
> EPFL Innovation Park Building C
> 1015 Lausanne
> [image: Logo-black.png]
> Here at Corintis we care for your privacy. That is why we have taken
> appropriate measures to ensure that the data you have provided to us is
> always secure
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250509/7d8bfba9/attachment.html>
