[petsc-users] upgrading to 3.22.4
Sanjay Govindjee s_g at berkeley.edu
Sun Mar 23 02:19:53 CDT 2025
Hi Barry,
   I have moved to main and rebuilt the PETSc libraries etc.  Right now
I am having trouble just getting my source code to compile. Plenty of
subroutines with PETSc calls compile but a few are throwing errors and
killing my compile. I suspect there will be more but if I can figure
these hopefully I can debug the ones that will follow.
-sanjay
    Error: There is no specific subroutine for the generic
    'matmpibaijsetpreallocation' at (1)
    upremas.F:68:72:
        68 |      &                               ierr)
    | 1
    'matseqbaijsetpreallocation' at (1)
    upremas.F:74:72:
        74 |      &                             ierr)
    | 1
    'matmpiaijsetpreallocation' at (1)
    upremas.F:77:72:
        77 |      &                             ierr)
    | 1
    'matseqaijsetpreallocation' at (1)
    parkv.F:58:25:
        58 |       PetscViewer    Y_view
           |                         1
    Error: Type name 'tpetscviewer' at (1) is ambiguous
    parkv.F:69:9:
        69 |       endif
           |         1
    Error: Expecting END SUBROUTINE statement at (1)
    parkv.F:72:9:
        72 |       endif
           |         1
    parkv.F:91:66:
        91 |         call
    PetscViewerASCIIOpen(PETSC_COMM_WORLD,"yvec.m",Y_view,
    | 1
    Error: Symbol 'y_view' at (1) has no IMPLICIT type; did you mean 'yvec'?
    parkv.F:65:72:
        65 |         call VecCreate        (PETSC_COMM_WORLD, xvec, ierr)
    | 1
    Error: There is no specific subroutine for the generic 'veccreate'
    at (1)
    parkv.F:67:72:
        67 |         call VecSetFromOptions(xvec, ierr)
    | 1
    'vecsetfromoptions' at (1)
    parkv.F:68:72:
        68 |         call VecDuplicate     (xvec, yvec, ierr)
    | 1
    'vecduplicate' at (1)
    parkv.F:71:72:
        71 |         call VecDuplicate     (xvec, yvec, ierr)
    | 1
    parkv.F:85:72:
        85 |       call VecAssemblyBegin(xvec, ierr)
    | 1
    'vecassemblybegin' at (1)
    parkv.F:86:72:
        86 |       call VecAssemblyEnd  (xvec, ierr)
    | 1
    'vecassemblyend' at (1)
    parkv.F:88:72:
        88 |       call MatMult           (Kmat, xvec, yvec, ierr)
    | 1
    Error: There is no specific subroutine for the generic 'matmult' at (1)
    parkv.F:101:72:
       101 |       call VecGetOwnershipRange(yvec, starti, endi, ierr)
    | 1
    'vecgetownershiprange' at (1)
On 3/21/25 7:17 AM, Barry Smith wrote:
>     I have just pushed a major update to the Fortran interface to the
> main PETSc git branch. Could you please try to work with main (to
> become release in a couple of weeks) with your Fortran code as we
> debug the problem? This will save you a lot of work and hopefully make
> the debugging more straightforward.
>     You can send the same output with the debugger if it crashes in
> the main branch and I can try to track down what is going wrong.
>   Barry
>> On Mar 21, 2025, at 12:37 AM, Sanjay Govindjee via petsc-users
>> <petsc-users at mcs.anl.gov> wrote:
>> I am trying to upgrade my code to PETSc 3.22.4 (the code was last
>> updated to 3.19.4 or perhaps 3.18.1, I've lost track). I've been
>> using this code with PETSc for over 20 years.
>> To get my code to compile and link during this update, I only need to
>> make two changes; one was to use PetscViewerPushFormat instead of
>> PetscViewerSetFormat and the other was to use
>> PETSC_NULL_INTEGER_ARRAY in a spot or two.
>> When I run the code however, I am getting an error very early on
>> during a call to MatCreate near the beginning of the code.  The
>> screen output says:
>>     [3]PETSC ERROR: matcreate_() at
>>     /Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c:101
>>     Cannot create PETSC_NULL_XXX object
>>     [0]PETSC ERROR: matcreate_() at
>>     [1]PETSC ERROR: matcreate_() at
>>     [2]PETSC ERROR: matcreate_() at
>> I have a 4 processor run going.  I am running with
>> -on_error_attach_debugger but the debugger is giving me cryptic (at
>> least to me) output (the same for all 4 processes modulo the PID).
>> Stack traces seem to be unavailable :(
>>     lldb  -p 71963
>>     (lldb) process attach --pid 71963
>>     Process 71963 stopped
>>     * thread #1, queue = 'com.apple.main-thread', stop reason =
>>     signal SIGSTOP
>>         frame #0: 0x00007fff69d92746
>>     libsystem_kernel.dylib`__semwait_signal + 10
>>     libsystem_kernel.dylib`__semwait_signal:
>>     ->  0x7fff69d92746 <+10>: jae 0x7fff69d92750            ; <+20>
>>         0x7fff69d92748 <+12>: movq   %rax, %rdi
>>         0x7fff69d9274b <+15>: jmp 0x7fff69d9121d            ; cerror
>>         0x7fff69d92750 <+20>: retq
>>     Target 0: (feap) stopped.
>>     Executable module set to "/Users/sg/Feap/ver87/parfeap/feap".
>>     Architecture set to: x86_64h-apple-macosx-.
>> Does anyone have any hints as to what may be going on?  Note the
>> program starts normally and i can do stuff with the interactive
>> interface for the code -- even plotting the mesh etc. so I believe
>> the input data has been read in correctly.  The crash only occurs
>> when I initiate the formation of the matrix.
>> I am attaching the
>> /Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c file in
>> case that offers some insight.
>> Note, I have been
>> -sanjay
>> <gcreatef.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250323/1b3d5e06/attachment.html>
