[petsc-users] upgrading to 3.22.4
Sanjay Govindjee s_g at berkeley.edu
Fri Mar 21 14:43:05 CDT 2025
Ok.  Thanks for the recommendation.
Sanjay Govindjee, PhD, PE
Horace, Dorothy, and Katherine Johnson Professor in Engineering
Distinguished Professor of Civil and Environmental Engineering
779 Davis Hall
University of California
Berkeley, CA 94720-1710
Voice:  +1 510 642 6060
FAX:    +1 510 643 5264
s_g at berkeley.edu
https://urldefense.us/v3/__http://faculty.ce.berkeley.edu/sanjay__;!!G_uCfscf7eWS!ct_FDSjTgbv5A4gaXMu_9l5RlvbTb3RjdZb2hG_OAjUmHLOWHQLRgouXdedWwdktCXxk5kb-O6apdPOI7VvqHw$
Books:
Continuum Mechanics of Solids
https://urldefense.us/v3/__https://global.oup.com/academic/product/continuum-mechanics-of-solids-9780198864721__;!!G_uCfscf7eWS!ct_FDSjTgbv5A4gaXMu_9l5RlvbTb3RjdZb2hG_OAjUmHLOWHQLRgouXdedWwdktCXxk5kb-O6apdPOzghiWbQ$
Example Problems for Continuum Mechanics of Solids
https://urldefense.us/v3/__https://www.amazon.com/dp/1083047361/__;!!G_uCfscf7eWS!ct_FDSjTgbv5A4gaXMu_9l5RlvbTb3RjdZb2hG_OAjUmHLOWHQLRgouXdedWwdktCXxk5kb-O6apdPOSFqFuvA$
Engineering Mechanics of Deformable Solids
https://urldefense.us/v3/__https://www.amazon.com/dp/0199651647__;!!G_uCfscf7eWS!ct_FDSjTgbv5A4gaXMu_9l5RlvbTb3RjdZb2hG_OAjUmHLOWHQLRgouXdedWwdktCXxk5kb-O6apdPPTM57GyA$
Engineering Mechanics 3 (Dynamics) 2nd Edition
https://urldefense.us/v3/__http://www.amazon.com/dp/3642537111__;!!G_uCfscf7eWS!ct_FDSjTgbv5A4gaXMu_9l5RlvbTb3RjdZb2hG_OAjUmHLOWHQLRgouXdedWwdktCXxk5kb-O6apdPPLiq9kJg$
Engineering Mechanics 3, Supplementary Problems: Dynamics
https://urldefense.us/v3/__http://www.amzn.com/B00SOXN8JU__;!!G_uCfscf7eWS!ct_FDSjTgbv5A4gaXMu_9l5RlvbTb3RjdZb2hG_OAjUmHLOWHQLRgouXdedWwdktCXxk5kb-O6apdPN9mztOew$
NSF NHERI SimCenter
https://urldefense.us/v3/__https://simcenter.designsafe-ci.org/__;!!G_uCfscf7eWS!ct_FDSjTgbv5A4gaXMu_9l5RlvbTb3RjdZb2hG_OAjUmHLOWHQLRgouXdedWwdktCXxk5kb-O6apdPNFCf49Yw$
On Fri, Mar 21, 2025 at 12:39 PM Satish Balay <balay.anl at fastmail.org>
wrote:
> On Fri, 21 Mar 2025, Sanjay Govindjee via petsc-users wrote:
> > Thanks.  I will give that a try.  To be clear, I should do
> >  >  > git checkout origin/main
> >  >  > make all
> >  >  > make check
> > Or do I also need to run my (long) .\configure before the make all?
> I would start a clean build from a clean repo.
> Satish
> > -sanjay
> > On 3/21/25 7:17 AM, Barry Smith wrote:
> > >     I have just pushed a major update to the Fortran interface to the
> main
> > > PETSc git branch. Could you please try to work with main (to become
> release
> > > in a couple of weeks) with your Fortran code as we debug the problem?
> This
> > > will save you a lot of work and hopefully make the debugging more
> > > straightforward.
> > >     You can send the same output with the debugger if it crashes in
> the main
> > > branch and I can try to track down what is going wrong.
> > >   Barry
> > >> On Mar 21, 2025, at 12:37 AM, Sanjay Govindjee via petsc-users
> > >> <petsc-users at mcs.anl.gov> wrote:
> > >> I am trying to upgrade my code to PETSc 3.22.4 (the code was last
> updated
> > >> to 3.19.4 or perhaps 3.18.1, I've lost track). I've been using this
> code
> > >> with PETSc for over 20 years.
> > >> To get my code to compile and link during this update, I only need to
> make
> > >> two changes; one was to use PetscViewerPushFormat instead of
> > >> PetscViewerSetFormat and the other was to use
> PETSC_NULL_INTEGER_ARRAY in a
> > >> spot or two.
> > >> When I run the code however, I am getting an error very early on
> during a
> > >> call to MatCreate near the beginning of the code.  The screen output
> says:
> > >>     [3]PETSC ERROR: matcreate_() at
> > >>     /Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c:101
> > >>     Cannot create PETSC_NULL_XXX object
> > >>     [0]PETSC ERROR: matcreate_() at
> > >>     [1]PETSC ERROR: matcreate_() at
> > >>     [2]PETSC ERROR: matcreate_() at
> > >> I have a 4 processor run going.  I am running with
> > >> -on_error_attach_debugger but the debugger is giving me cryptic (at
> least
> > >> to me) output (the same for all 4 processes modulo the PID).  Stack
> traces
> > >> seem to be unavailable :(
> > >>     lldb  -p 71963
> > >>     (lldb) process attach --pid 71963
> > >>     Process 71963 stopped
> > >>     * thread #1, queue = 'com.apple.main-thread', stop reason =
> > >>     signal SIGSTOP
> > >>         frame #0: 0x00007fff69d92746
> > >>     libsystem_kernel.dylib`__semwait_signal + 10
> > >>     libsystem_kernel.dylib`__semwait_signal:
> > >>     ->  0x7fff69d92746 <+10>: jae 0x7fff69d92750            ; <+20>
> > >>         0x7fff69d92748 <+12>: movq   %rax, %rdi
> > >>         0x7fff69d9274b <+15>: jmp 0x7fff69d9121d            ; cerror
> > >>         0x7fff69d92750 <+20>: retq
> > >>     Target 0: (feap) stopped.
> > >>     Executable module set to "/Users/sg/Feap/ver87/parfeap/feap".
> > >>     Architecture set to: x86_64h-apple-macosx-.
> > >> Does anyone have any hints as to what may be going on?  Note the
> program
> > >> starts normally and i can do stuff with the interactive interface for
> the
> > >> code -- even plotting the mesh etc. so I believe the input data has
> been
> > >> read in correctly.  The crash only occurs when I initiate the
> formation of
> > >> the matrix.
> > >> I am attaching the
> > >> /Users/sg/petsc-3.22.4/gnug/src/mat/utils/ftn-auto/gcreatef.c file in
> case
> > >> that offers some insight.
> > >> Note, I have been
> > >> -sanjay
> > >> <gcreatef.c>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250321/7546a95a/attachment-0001.html>
