[petsc-users] [GPU] Jacobi preconditioner
Junchao Zhang junchao.zhang at gmail.com
Thu Jul 31 10:05:10 CDT 2025
What would embarrass me more is to copy the same code to MatGetDiagonal_
SeqAIJHIPSPARSE.
--Junchao Zhang
On Wed, Jul 30, 2025 at 1:34 PM Barry Smith <bsmith at petsc.dev> wrote:
>    We absolutely should have a MatGetDiagonal_SeqAIJCUSPARSE().
> It's somewhat embarrassing that we don't provide this.
>    I have found some potential code at
> https://urldefense.us/v3/__https://stackoverflow.com/questions/60311408/how-to-get-the-diagonal-of-a-sparse-matrix-in-cusparse__;!!G_uCfscf7eWS!eFR7ZzxJzlmh7BCszleLr5XhdKGWWrJhH0s5z1UvCfSHo3N0wJBFRvxofvWDbFPYNGW2tSRU8lzHC4w2RMCL0W4wbMZv$
>    Barry
> On Jul 28, 2025, at 11:43 AM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> Yes, MatGetDiagonal_SeqAIJCUSPARSE hasn't been implemented.  petsc/cuda
> and petsc/kokkos backends are separate code.
> If petsc/kokkos meet your needs, then just use them.  For petsc users, we
> hope it will be just a difference of extra --download-kokkos
> --download-kokkos-kernels in configuration.
> --Junchao Zhang
> On Mon, Jul 28, 2025 at 2:51 AM LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
>> Hello all,
>> We are solving with PETSc a linear system updated every time step
>> (constant stencil but coefficients changing).
>> The matrix is preallocated once with MatSetPreallocationCOO() then
>> filled each time step with MatSetValuesCOO() and we use device pointers
>> for coo_i, coo_j, and coefficients values.
>> It is working fine with a GMRES Ksp solver and PC Jacobi but we are
>> surprised to see that every time step, during PCSetUp,
>> MatGetDiagonal_SeqAIJ is called whereas the matrix is on the device.
>> Looking at the API, it seems there is no MatGetDiagonal_SeqAIJCUSPARSE()
>> but a MatGetDiagonal_SeqAIJKOKKOS().
>> Does it mean we should use Kokkos backend in PETSc to have Jacobi
>> preconditioner built directly on device ? Or I am doing something wrong ?
>> NB: Gmres is running well on device.
>> I could use -ksp_reuse_preconditioner to avoid Jacobi being recreated
>> each solve on host but it increases significantly the number of iterations.
>> Thanks,
>> <pastedImage.png>
>> Pierre LEDAC
>> Commissariat à l’énergie atomique et aux énergies alternatives
>> Centre de SACLAY
>> DES/ISAS/DM2S/SGLS/LCAN
>> Bâtiment 451 – point courrier n°41
>> F-91191 Gif-sur-Yvette
>> +33 1 69 08 04 03
>> +33 6 83 42 05 79
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250731/252bd236/attachment-0001.html>
