[petsc-users] problem with nested logging, standalone example
Barry Smith
bsmith at petsc.dev
Fri Jul 11 16:22:36 CDT 2025
And yet we cannot reproduce.
Please tell us the exact PETSc version and MPI implementation versions. And reattach your reproducing example. And exactly how you run it.
Can you reproduce it on an "ordinary" machine, say a Mac or Linux laptop.
Barry
If I could reproduce the problem here is how I would debug. I put use -start_in_debugger and then put break points in places which it seem problematic. Presumably I would end up with a hang with each MPI process in a "different place" and from that I may be able to determine how that happened.
> On Jul 11, 2025, at 7:58 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> In summary for future reference:
> - tested 3 different machines, two at Marin, one at the national HPC
> - tested 3 different mpi implementation (intelmpi, openmpi and mpich)
> - tested openmpi in both release and debug
> - tested 2 different compilers (intel and gnu), both older and very recent versions
> - tested with the most basic config (./configure --with-cxx=0 --with-debugging=0 --download-mpich)
> All of these test either segfault, or hang or error-out at the call to PetscLogView.
> Chris
> From: Klaij, Christiaan <C.Klaij at marin.nl>
> Sent: Friday, July 11, 2025 10:10 AM
> To: Barry Smith; Junchao Zhang
> Cc: PETSc users list
> Subject: Re: [petsc-users] problem with nested logging, standalone example
> @Matt: no MPI errors indeed. I've tried with MPICH and I get the same hanging.
> @Barry: both stack traces aren't exactly the same, see a sample with MPICH below.
> If it cannot be reproduced at your side, I'm afraid this is another dead end. Thanks anyway, I really appreciate all your help.
> Chris
> (gdb) bt
> #0 0x000015555033bc2e in MPIDI_POSIX_mpi_release_gather_gather.constprop.0 ()
> from /cm/shared/apps/mpich/ge/gcc/64/3.4.2/lib/libmpi.so.12
> #1 0x000015555033db8a in MPIDI_POSIX_mpi_allreduce_release_gather ()
> #2 0x000015555033e70f in MPIR_Allreduce ()
> #3 0x000015555033f22e in PMPI_Allreduce ()
> #4 0x0000155553f85d69 in MPIU_Allreduce_Count (comm=-2080374782,
> op=1476395020, dtype=1275072547, count=1, outbuf=0x7fffffffac70,
> inbuf=0x7fffffffac60)
> at /home/cklaij/petsc/petsc-3.23.4/src/sys/objects/pinit.c:1839
> #5 MPIU_Allreduce_Private (inbuf=inbuf at entry=0x7fffffffac60,
> outbuf=outbuf at entry=0x7fffffffac70, count=count at entry=1,
> dtype=dtype at entry=1275072547, op=op at entry=1476395020, comm=-2080374782)
> at /home/cklaij/petsc/petsc-3.23.4/src/sys/objects/pinit.c:1869
> #6 0x0000155553f33dbe in PetscPrintXMLNestedLinePerfResults (
> viewer=viewer at entry=0x458890, name=name at entry=0x155554ef6a0d 'mbps\000',
> value=<optimized out>, minthreshold=minthreshold at entry=0,
> maxthreshold=maxthreshold at entry=0.01,
> minmaxtreshold=minmaxtreshold at entry=1.05)
> at /home/cklaij/petsc/petsc-3.23.4/src/sys/logging/handler/impls/nested/xmlviewer.c:255
> (gdb) bt
> #0 0x000015554fed3b17 in clock_gettime at GLIBC_2.2.5 () from /lib64/libc.so.6
> #1 0x0000155550b0de71 in ofi_gettime_ns ()
> #2 0x0000155550b0dec9 in ofi_gettime_ms ()
> #3 0x0000155550b2fab5 in sock_cq_sreadfrom ()
> #4 0x00001555505ca6f7 in MPIDI_OFI_progress ()
> #5 0x0000155550591fe9 in progress_test ()
> #6 0x00001555505924a3 in MPID_Progress_wait ()
> #7 0x000015555043463e in MPIR_Wait_state ()
> #8 0x000015555052ec49 in MPIC_Wait ()
> #9 0x000015555053093e in MPIC_Sendrecv ()
> #10 0x00001555504bf674 in MPIR_Allreduce_intra_recursive_doubling ()
> #11 0x00001555505b61de in MPIDI_OFI_mpi_finalize_hook ()
> From: Barry Smith <bsmith at petsc.dev>
> Sent: Thursday, July 10, 2025 11:10 PM
> To: Junchao Zhang
> Cc: Klaij, Christiaan; PETSc users list
> I cannot reproduce
> On Jul 10, 2025, at 3:46 PM, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Adding -mca coll_hcoll_enable 0 didn't change anything at my end. Strange.
> --Junchao Zhang
> On Thu, Jul 10, 2025 at 3:39 AM Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
> An additional clue perhaps: with the option OMPI_MCA_coll_hcoll_enable=0, the code does not hang but gives the error below.
> Chris
> $ mpirun -mca coll_hcoll_enable 0 -n 2 ./ex2f-cklaij-dbg -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always
> 0 KSP Residual norm 1.11803
> 1 KSP Residual norm 0.591608
> 2 KSP Residual norm 0.316228
> 3 KSP Residual norm < 1.e-11
> 0 KSP Residual norm 0.707107
> 1 KSP Residual norm 0.408248
> 2 KSP Residual norm < 1.e-11
> Norm of error < 1.e-12 iterations 3
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR: General MPI error
> [1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cXtuTTf7kilpktOAvL4X2xIl72hhvfnklH8dS4VBuh1CJ5LTt8I5kFBOJO8taiyBqpO3BZ0A0AINRRcHohe__EA$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJjkYxsN9$> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> [1]PETSC ERROR: ./ex2f-cklaij-dbg with 2 MPI process(es) and PETSC_ARCH on login1 by cklaij Thu Jul 10 10:33:33 2025
> [1]PETSC ERROR: Configure options: --prefix=/home/cklaij/ReFRESCO/trunk/install/extLibs --with-mpi-dir=/cm/shared/apps/openmpi/gcc/5.0.6-debug --with-x=0 --with-mpe=0 --with-debugging=0 --download-superlu_dist=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!cXtuTTf7kilpktOAvL4X2xIl72hhvfnklH8dS4VBuh1CJ5LTt8I5kFBOJO8taiyBqpO3BZ0A0AINRRcHKz6JNHs$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJkouVHb2$> --with-blaslapack-dir=/cm/shared/apps/oneapi/2024.2.1/mkl/2024.2 --download-parmetis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!cXtuTTf7kilpktOAvL4X2xIl72hhvfnklH8dS4VBuh1CJ5LTt8I5kFBOJO8taiyBqpO3BZ0A0AINRRcHlxt0gc0$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrjo6-SP$> --download-metis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!cXtuTTf7kilpktOAvL4X2xIl72hhvfnklH8dS4VBuh1CJ5LTt8I5kFBOJO8taiyBqpO3BZ0A0AINRRcH8j4pep0$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJhCc9MRE$> --with-packages-build-dir=/home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG"
> [1]PETSC ERROR: #1 PetscLogNestedTreePrintLine() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:289
> [1]PETSC ERROR: #2 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:377
> [1]PETSC ERROR: #3 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> [1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> [1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> [1]PETSC ERROR: #7 PetscLogHandlerView() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> [1]PETSC ERROR: #8 PetscLogView() at /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/plog.c:2040
> [1]PETSC ERROR: #9 ex2f-cklaij-dbg.F90:301
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
> Proc: [[55228,1],1]
> Errorcode: 98
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> prterun has exited due to process rank 1 with PID 0 on node login1 calling
> "abort". This may have caused other processes in the application to be
> terminated by signals sent by prterun (as reported here).
> <image198746.png>
> dr. ir. Christiaan Klaij | senior researcher
> Research & Development | CFD Development
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cXtuTTf7kilpktOAvL4X2xIl72hhvfnklH8dS4VBuh1CJ5LTt8I5kFBOJO8taiyBqpO3BZ0A0AINRRcHmL7cVmc$ <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrOqapgp$>
> <image542473.png><https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJoD4fuV7$>
> <image555176.png><https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJospHf95$>
> <image269837.png><https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrpsjB_W$>
> From: Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>
> Sent: Thursday, July 10, 2025 10:15 AM
> To: Junchao Zhang
> Hi Junchao,
> Thanks for testing. I've fixed the error but unfortunately that doesn't change the behavior, the code still hangs as before, with the same stack trace...
> Chris
> From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
> Sent: Tuesday, July 8, 2025 10:58 PM
> To: Klaij, Christiaan
> Hi, Chris,
> First, I had to fix an error in your test by adding " PetscCallA(MatSetFromOptions(AA,ierr))" at line 254.
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Mat object's type is not set: Argument # 1
> [0]PETSC ERROR: #1 MatSetValues() at /scratch/jczhang/petsc/src/mat/interface/matrix.c:1503
> [0]PETSC ERROR: #2 ex2f.F90:258
> Then I could ran the test without problems
> mpirun -n 2 ./ex2f -pc_type jacobi -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always
> I used petsc-3.22.4, gcc-11.3, openmpi-5.0.6 and configured with
> ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-openmpi --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG"
> Could you fix the error and retry?
> --Junchao Zhang
> On Sun, Jul 6, 2025 at 12:57 PM Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>> wrote:
> Attached is a standalone example of the issue described in the
> earlier thread "problem with nested logging". The issue appeared
> somewhere between petsc 3.19.4 and 3.23.4.
> The example is a variation of ../ksp/tutorials/ex2f.F90, where
> I've added the nested log viewer with one event as well as the
> solution of a small system on rank zero.
> When running on mulitple procs the example hangs during
> PetscLogView with the backtrace below. The configure.log is also
> attached in the hope that you can replicate the issue.
> Chris
> #0 0x000015554c84ea9e in mca_pml_ucx_recv (buf=0x7fffffff9e30, count=1,
> datatype=0x15554c9ef900 <ompi_mpi_2dblprec>, src=1, tag=-12,
> comm=0x7f1e30, mpi_status=0x0) at pml_ucx.c:700
> #1 0x000015554c65baff in ompi_coll_base_allreduce_intra_recursivedoubling (
> sbuf=0x7fffffff9e20, rbuf=0x7fffffff9e30, count=1,
> dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630)
> at base/coll_base_allreduce.c:247
> #2 0x000015554c6a7e40 in ompi_coll_tuned_allreduce_intra_do_this (
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630,
> algorithm=3, faninout=0, segsize=0) at coll_tuned_allreduce_decision.c:142
> #3 0x000015554c6a054f in ompi_coll_tuned_allreduce_intra_dec_fixed (
> at coll_tuned_decision_fixed.c:216
> #4 0x000015554c68e160 in mca_coll_hcoll_allreduce (sbuf=0x7fffffff9e20,
> rbuf=0x7fffffff9e30, count=1, dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaecb80)
> at coll_hcoll_ops.c:217
> #5 0x000015554c59811a in PMPI_Allreduce (sendbuf=0x7fffffff9e20,
> recvbuf=0x7fffffff9e30, count=1, datatype=0x15554c9ef900 <ompi_mpi_2dblprec>, op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30) at allreduce.c:123
> #6 0x0000155553eabede in MPIU_Allreduce_Private () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #7 0x0000155553e50d08 in PetscPrintXMLNestedLinePerfResults () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #8 0x0000155553e5123e in PetscLogNestedTreePrintLine () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #9 0x0000155553e51f3a in PetscLogNestedTreePrint () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #10 0x0000155553e51e96 in PetscLogNestedTreePrint () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #11 0x0000155553e51e96 in PetscLogNestedTreePrint () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #12 0x0000155553e52142 in PetscLogNestedTreePrintTop () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #13 0x0000155553e5257b in PetscLogHandlerView_Nested_XML () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #14 0x0000155553e4e5a0 in PetscLogHandlerView_Nested () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #15 0x0000155553e56232 in PetscLogHandlerView () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #16 0x0000155553e588c3 in PetscLogView () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #17 0x0000155553e40eb5 in petsclogview_ () from /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #18 0x0000000000402c8b in MAIN__ ()
> #19 0x00000000004023df in main ()
> [cid:ii_197ebccaa1d27ee6ef21]
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cXtuTTf7kilpktOAvL4X2xIl72hhvfnklH8dS4VBuh1CJ5LTt8I5kFBOJO8taiyBqpO3BZ0A0AINRRcHmL7cVmc$ <https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJhphmV4x$><https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imk4ivm_tE$>
> [Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkLNCvsiI$>
> [LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkrb79Ay4$>
> [YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkJiCoeLw$>
