[petsc-users] problem with nested logging, standalone example
Junchao Zhang
junchao.zhang at gmail.com
Fri Jul 11 10:39:43 CDT 2025
Were they all tested with your ex2f.F90 example?
--Junchao Zhang
On Fri, Jul 11, 2025 at 6:58 AM Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> In summary for future reference:
> - tested 3 different machines, two at Marin, one at the national HPC
> - tested 3 different mpi implementation (intelmpi, openmpi and mpich)
> - tested openmpi in both release and debug
> - tested 2 different compilers (intel and gnu), both older and very recent
> versions
> - tested with the most basic config (./configure --with-cxx=0
> --with-debugging=0 --download-mpich)
> All of these test either segfault, or hang or error-out at the call to
> PetscLogView.
> Chris
> From: Klaij, Christiaan <C.Klaij at marin.nl>
> Sent: Friday, July 11, 2025 10:10 AM
> To: Barry Smith; Junchao Zhang
> Cc: PETSc users list
> Subject: Re: [petsc-users] problem with nested logging, standalone example
> @Matt: no MPI errors indeed. I've tried with MPICH and I get the same
> hanging.
> @Barry: both stack traces aren't exactly the same, see a sample with MPICH
> below.
> If it cannot be reproduced at your side, I'm afraid this is another dead
> end. Thanks anyway, I really appreciate all your help.
> Chris
> (gdb) bt
> #0 0x000015555033bc2e in
> MPIDI_POSIX_mpi_release_gather_gather.constprop.0 ()
> from /cm/shared/apps/mpich/ge/gcc/64/3.4.2/lib/libmpi.so.12
> #1 0x000015555033db8a in MPIDI_POSIX_mpi_allreduce_release_gather ()
> #2 0x000015555033e70f in MPIR_Allreduce ()
> #3 0x000015555033f22e in PMPI_Allreduce ()
> #4 0x0000155553f85d69 in MPIU_Allreduce_Count (comm=-2080374782,
> op=1476395020, dtype=1275072547, count=1, outbuf=0x7fffffffac70,
> inbuf=0x7fffffffac60)
> at /home/cklaij/petsc/petsc-3.23.4/src/sys/objects/pinit.c:1839
> #5 MPIU_Allreduce_Private (inbuf=inbuf at entry=0x7fffffffac60,
> outbuf=outbuf at entry=0x7fffffffac70, count=count at entry=1,
> dtype=dtype at entry=1275072547, op=op at entry=1476395020,
> comm=-2080374782)
> at /home/cklaij/petsc/petsc-3.23.4/src/sys/objects/pinit.c:1869
> #6 0x0000155553f33dbe in PetscPrintXMLNestedLinePerfResults (
> viewer=viewer at entry=0x458890, name=name at entry=0x155554ef6a0d
> 'mbps\000',
> value=<optimized out>, minthreshold=minthreshold at entry=0,
> maxthreshold=maxthreshold at entry=0.01,
> minmaxtreshold=minmaxtreshold at entry=1.05)
> at
> /home/cklaij/petsc/petsc-3.23.4/src/sys/logging/handler/impls/nested/xmlviewer.c:255
> (gdb) bt
> #0 0x000015554fed3b17 in clock_gettime at GLIBC_2.2.5 () from
> /lib64/libc.so.6
> #1 0x0000155550b0de71 in ofi_gettime_ns ()
> #2 0x0000155550b0dec9 in ofi_gettime_ms ()
> #3 0x0000155550b2fab5 in sock_cq_sreadfrom ()
> #4 0x00001555505ca6f7 in MPIDI_OFI_progress ()
> #5 0x0000155550591fe9 in progress_test ()
> #6 0x00001555505924a3 in MPID_Progress_wait ()
> #7 0x000015555043463e in MPIR_Wait_state ()
> #8 0x000015555052ec49 in MPIC_Wait ()
> #9 0x000015555053093e in MPIC_Sendrecv ()
> #10 0x00001555504bf674 in MPIR_Allreduce_intra_recursive_doubling ()
> #11 0x00001555505b61de in MPIDI_OFI_mpi_finalize_hook ()
> From: Barry Smith <bsmith at petsc.dev>
> Sent: Thursday, July 10, 2025 11:10 PM
> To: Junchao Zhang
> Cc: Klaij, Christiaan; PETSc users list
> I cannot reproduce
> On Jul 10, 2025, at 3:46 PM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> Adding -mca coll_hcoll_enable 0 didn't change anything at my end. Strange.
> --Junchao Zhang
> On Thu, Jul 10, 2025 at 3:39 AM Klaij, Christiaan <C.Klaij at marin.nl
> <mailto:C.Klaij at marin.nl>> wrote:
> An additional clue perhaps: with the option OMPI_MCA_coll_hcoll_enable=0,
> the code does not hang but gives the error below.
> Chris
> $ mpirun -mca coll_hcoll_enable 0 -n 2 ./ex2f-cklaij-dbg -pc_type jacobi
> -ksp_monitor_short -ksp_gmres_cgs_refinement_type refine_always
> 0 KSP Residual norm 1.11803
> 1 KSP Residual norm 0.591608
> 2 KSP Residual norm 0.316228
> 3 KSP Residual norm < 1.e-11
> 0 KSP Residual norm 0.707107
> 1 KSP Residual norm 0.408248
> 2 KSP Residual norm < 1.e-11
> Norm of error < 1.e-12 iterations 3
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: General MPI error
> [1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ZyiwrArIFFVQEy3iWRduuvJj55fiVzKR94DvhrQs9yD59inAYaV8ixbXwagVSTSKcTFN80eCIfFWyH6SWODSjHOBKqtO$ <
> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJjkYxsN9$>
> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> [1]PETSC ERROR: ./ex2f-cklaij-dbg with 2 MPI process(es) and PETSC_ARCH on
> login1 by cklaij Thu Jul 10 10:33:33 2025
> [1]PETSC ERROR: Configure options:
> --prefix=/home/cklaij/ReFRESCO/trunk/install/extLibs
> --with-mpi-dir=/cm/shared/apps/openmpi/gcc/5.0.6-debug --with-x=0
> --with-mpe=0 --with-debugging=0 --download-superlu_dist=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!ZyiwrArIFFVQEy3iWRduuvJj55fiVzKR94DvhrQs9yD59inAYaV8ixbXwagVSTSKcTFN80eCIfFWyH6SWODSjEz07NgJ$ <
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJkouVHb2$>
> --with-blaslapack-dir=/cm/shared/apps/oneapi/2024.2.1/mkl/2024.2
> --download-parmetis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!ZyiwrArIFFVQEy3iWRduuvJj55fiVzKR94DvhrQs9yD59inAYaV8ixbXwagVSTSKcTFN80eCIfFWyH6SWODSjK2HNCeG$ <
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrjo6-SP$>
> --download-metis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!ZyiwrArIFFVQEy3iWRduuvJj55fiVzKR94DvhrQs9yD59inAYaV8ixbXwagVSTSKcTFN80eCIfFWyH6SWODSjL4z_WUP$ <
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJhCc9MRE$>
> --with-packages-build-dir=/home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild
> --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops
> -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime
> -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops
> -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops
> [1]PETSC ERROR: #1 PetscLogNestedTreePrintLine() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:289
> [1]PETSC ERROR: #2 PetscLogNestedTreePrint() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:377
> [1]PETSC ERROR: #3 PetscLogNestedTreePrint() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> [1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> [1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> [1]PETSC ERROR: #7 PetscLogHandlerView() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> [1]PETSC ERROR: #8 PetscLogView() at
> /home/cklaij/ReFRESCO/trunk/build-extlibs/superbuild/petsc/src/src/sys/logging/plog.c:2040
> [1]PETSC ERROR: #9 ex2f-cklaij-dbg.F90:301
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
> Proc: [[55228,1],1]
> Errorcode: 98
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> prterun has exited due to process rank 1 with PID 0 on node login1 calling
> "abort". This may have caused other processes in the application to be
> terminated by signals sent by prterun (as reported here).
> <image198746.png>
> dr. ir. Christiaan Klaij | senior researcher
> Research & Development | CFD Development
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!ZyiwrArIFFVQEy3iWRduuvJj55fiVzKR94DvhrQs9yD59inAYaV8ixbXwagVSTSKcTFN80eCIfFWyH6SWODSjDGFyRHJ$ <
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrOqapgp$
> <image542473.png><
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJoD4fuV7$
> <image555176.png><
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJospHf95$
> <image269837.png><
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJrpsjB_W$
> From: Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>
> Sent: Thursday, July 10, 2025 10:15 AM
> To: Junchao Zhang
> Hi Junchao,
> Thanks for testing. I've fixed the error but unfortunately that doesn't
> change the behavior, the code still hangs as before, with the same stack
> trace...
> Chris
> From: Junchao Zhang <junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>
> Sent: Tuesday, July 8, 2025 10:58 PM
> To: Klaij, Christiaan
> Hi, Chris,
> First, I had to fix an error in your test by adding "
> PetscCallA(MatSetFromOptions(AA,ierr))" at line 254.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Mat object's type is not set: Argument # 1
> [0]PETSC ERROR: #1 MatSetValues() at
> /scratch/jczhang/petsc/src/mat/interface/matrix.c:1503
> [0]PETSC ERROR: #2 ex2f.F90:258
> Then I could ran the test without problems
> mpirun -n 2 ./ex2f -pc_type jacobi -ksp_monitor_short
> I used petsc-3.22.4, gcc-11.3, openmpi-5.0.6 and configured with
> ./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-openmpi --with-ssl=0 --with-shared-libraries=1
> CFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG"
> CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG "
> COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG"
> CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG "
> FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0
> -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3
> -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0
> -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0
> -DNDEBUG"
> Could you fix the error and retry?
> --Junchao Zhang
> On Sun, Jul 6, 2025 at 12:57 PM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>> wrote:
> Attached is a standalone example of the issue described in the
> earlier thread "problem with nested logging". The issue appeared
> somewhere between petsc 3.19.4 and 3.23.4.
> The example is a variation of ../ksp/tutorials/ex2f.F90, where
> I've added the nested log viewer with one event as well as the
> solution of a small system on rank zero.
> When running on mulitple procs the example hangs during
> PetscLogView with the backtrace below. The configure.log is also
> attached in the hope that you can replicate the issue.
> Chris
> #0 0x000015554c84ea9e in mca_pml_ucx_recv (buf=0x7fffffff9e30, count=1,
> datatype=0x15554c9ef900 <ompi_mpi_2dblprec>, src=1, tag=-12,
> comm=0x7f1e30, mpi_status=0x0) at pml_ucx.c:700
> #1 0x000015554c65baff in ompi_coll_base_allreduce_intra_recursivedoubling (
> sbuf=0x7fffffff9e20, rbuf=0x7fffffff9e30, count=1,
> dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630)
> at base/coll_base_allreduce.c:247
> #2 0x000015554c6a7e40 in ompi_coll_tuned_allreduce_intra_do_this (
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630,
> algorithm=3, faninout=0, segsize=0) at coll_tuned_allreduce_decision.c:142
> #3 0x000015554c6a054f in ompi_coll_tuned_allreduce_intra_dec_fixed (
> at coll_tuned_decision_fixed.c:216
> #4 0x000015554c68e160 in mca_coll_hcoll_allreduce (sbuf=0x7fffffff9e20,
> rbuf=0x7fffffff9e30, count=1, dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaecb80)
> at coll_hcoll_ops.c:217
> #5 0x000015554c59811a in PMPI_Allreduce (sendbuf=0x7fffffff9e20,
> recvbuf=0x7fffffff9e30, count=1, datatype=0x15554c9ef900
> <ompi_mpi_2dblprec>, op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30)
> at allreduce.c:123
> #6 0x0000155553eabede in MPIU_Allreduce_Private () from
> /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #7 0x0000155553e50d08 in PetscPrintXMLNestedLinePerfResults () from
> #8 0x0000155553e5123e in PetscLogNestedTreePrintLine () from
> #9 0x0000155553e51f3a in PetscLogNestedTreePrint () from
> #10 0x0000155553e51e96 in PetscLogNestedTreePrint () from
> #11 0x0000155553e51e96 in PetscLogNestedTreePrint () from
> #12 0x0000155553e52142 in PetscLogNestedTreePrintTop () from
> #13 0x0000155553e5257b in PetscLogHandlerView_Nested_XML () from
> #14 0x0000155553e4e5a0 in PetscLogHandlerView_Nested () from
> #15 0x0000155553e56232 in PetscLogHandlerView () from
> #16 0x0000155553e588c3 in PetscLogView () from
> #17 0x0000155553e40eb5 in petsclogview_ () from
> #18 0x0000000000402c8b in MAIN__ ()
> #19 0x00000000004023df in main ()
> [cid:ii_197ebccaa1d27ee6ef21]
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!ZyiwrArIFFVQEy3iWRduuvJj55fiVzKR94DvhrQs9yD59inAYaV8ixbXwagVSTSKcTFN80eCIfFWyH6SWODSjDGFyRHJ$ <
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cbfMf1uAUCQ_T756UiU6Vd_NZkAvFLYRqJzL47P2JiAVi_2KCG5Q1u2oHseUcGLNAIW5qWtWbWHMIk_YNR8bJhphmV4x$
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imk4ivm_tE$
> [Facebook]<
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkLNCvsiI$
> [LinkedIn]<
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkrb79Ay4$
> [YouTube]<
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkJiCoeLw$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250711/2d5b1503/attachment-0001.html>
