[petsc-users] New Fortran API to PCFieldSplitGetSubKSP
TARDIEU Nicolas
nicolas.tardieu at edf.fr
Tue Jul 1 12:11:28 CDT 2025
Thank you so much for your ultra fast answer Pierre!
Nicolas
De : pierre at joliv.et <pierre at joliv.et>
Envoyé : mardi 1 juillet 2025 18:58
À : TARDIEU Nicolas <nicolas.tardieu at edf.fr>
Cc : petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-users] New Fortran API to PCFieldSplitGetSubKSP
Expéditeur externe : Vérifier l’expéditeur avant de cliquer sur les liens ou pièces-jointes
External Sender : Check the sender before clicking any links or attachments
Dear Nicolas,
On 1 Jul 2025, at 6:31 PM, TARDIEU Nicolas via petsc-users <petsc-users at mcs.anl.gov> wrote:
Dear PETSc team,
I am having hard time upgrading our code's interface to the new Fortran API...
For instance, I lack a Fortran example of the use of PCFieldSplitGetSubKSP. The doc says "You must pass in a KSP array that is large enough to contain all the KSPs" but the interface file is :
subroutine PCFieldSplitGetSubKSP(a,b,c, z)
import tPC,tKSP
PC :: a
PetscInt :: b
KSP, pointer :: c(:)
PetscErrorCode z
end subroutine
end interface
Does it mean that I have to allocate an array of KSP before calling the routine ?
Yes.
It seems to me that the other new interfaces take care of allocating the output object. PCBJacobiGetSubKSP does it.
They do not work the same behind the scene (because for fieldsplit, in the internal structure, the sub KSP are not necessarily stored in a contiguous array), and so they are not strictly equivalent.
Pierre
Thanks in advance,
Nicolas
Nicolas Tardieu
Ing PhD Computational Mechanics
EDF - R&D Dpt ERMES
PARIS-SACLAY, FRANCE
Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
____________________________________________________
This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250701/bf59dd20/attachment.html>
