[petsc-users] fortran TYPE IS statement vs petsc index set IS
Klaij, Christiaan C.Klaij at marin.nl
Thu Jan 23 02:16:33 CST 2025
In fortran I'm using the following structure to check the type of
an incoming variable:
    SELECT TYPE (myvar)
    TYPE IS (mytype)
    END SELECT
Here IS is a fortan intrinsic, so far so good. However, when I
add a petsc index set as follows
    #include "petsc/finclude/petscksp.h"
    use petscksp, only: tIS
    IS :: myIS
the compiler gets confused and thinks that the intrinsic fortran
IS is the petsc index set IS, and errors-out on the SELECT
TYPE:
    error #8245: SELECT TYPE statement must be immediately followed by CLASS IS, TYPE IS, CLASS DEFAULT or END SELECT statement.
        SELECT TYPE (myvar)
    error #6410: This name has not been declared as an array or a function.   [TYPE]
        TYPE type(tIS) (mytype)
    compilation aborted
What would be the right way to deal with this problem?
dr. ir. Christiaan Klaij
 | Senior Researcher | Research & Development
T +31 317 49 33 44 |  C.Klaij at marin.nl | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!ci7RiI8WEqh81becsu6CMRqmK1It91JWMStWzWcFLARdy0n8d2WiqmINXWd-0992Ex6wcTfqupvy9nnMG_F6cHw$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250123/37dad137/attachment-0001.html>
Type: image/png
Desc: image870949.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250123/37dad137/attachment-0004.png>
Type: image/png
Desc: image753651.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250123/37dad137/attachment-0005.png>
Type: image/png
Desc: image316694.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250123/37dad137/attachment-0006.png>
Type: image/png
Desc: image966725.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250123/37dad137/attachment-0007.png>
