[petsc-users] Question Regarding Duplicate Indices in VecSetValues().
Tue Jan 14 08:31:39 CST 2025
On Tue, Jan 14, 2025 at 9:06 AM Mark Adams <mfadams at lbl.gov> wrote:
> INSERT_VALUES is clearly an error, but we can't check that easily so you
> will probably just get the last value, and ADD_VALUES should work.
For INSERT_VALUES, it will overwrite with the last value. For ADD_VALUES,
it will add.
    Matt
> Mark
> On Tue, Jan 14, 2025 at 8:20 AM Venkata Narayana Sarma Dhavala <
> dhavala at udel.edu> wrote:
>> Dear PETSc Development Team,
>> I hope this message finds you well. I am currently working with the
>> VecSetValues() function in PETSc, and I have a question regarding its
>> behavior when there are duplicate indices in the input array.
>> PetscErrorCode VecSetValues(Vec x, PetscInt ni, const PetscInt ix[],
>> const PetscScalar y[], InsertMode iora)
>> Specifically, what is the expected behavior if the ix[] array passed to
>> VecSetValues() contains duplicate indices? Does the function overwrite the
>> value at those indices, or does it handle duplicates differently depending
>> on the insert mode (INSERT_VALUES or ADD_VALUES)?
>> I would greatly appreciate any clarification on this matter, as it will
>> help me better understand how to manage values when working with
>> potentially repeated indices in the input.
>> Thank you for your time and assistance.
>> Best regards,
>> Narayana Dhavala.
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZrWqm3ouVJY_jjPcpNhmzIsTmWA-OY60MzKAlKcDJ5o_jUPAhxhaQ3iueKObVE-ZlFN2Au1qH1z2PtGbINMn$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZrWqm3ouVJY_jjPcpNhmzIsTmWA-OY60MzKAlKcDJ5o_jUPAhxhaQ3iueKObVE-ZlFN2Au1qH1z2PiuXkG3q$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250114/ae910925/attachment-0001.html>
