[petsc-users] Question Regarding Duplicate Indices in VecSetValues().
Mark Adams mfadams at lbl.gov
Tue Jan 14 08:05:57 CST 2025
INSERT_VALUES is clearly an error, but we can't check that easily so you
will probably just get the last value, and ADD_VALUES should work.
On Tue, Jan 14, 2025 at 8:20 AM Venkata Narayana Sarma Dhavala <
dhavala at udel.edu> wrote:
> Dear PETSc Development Team,
> I hope this message finds you well. I am currently working with the
> VecSetValues() function in PETSc, and I have a question regarding its
> behavior when there are duplicate indices in the input array.
> PetscErrorCode VecSetValues(Vec x, PetscInt ni, const PetscInt ix[], const
> PetscScalar y[], InsertMode iora)
> Specifically, what is the expected behavior if the ix[] array passed to
> VecSetValues() contains duplicate indices? Does the function overwrite the
> value at those indices, or does it handle duplicates differently depending
> on the insert mode (INSERT_VALUES or ADD_VALUES)?
> I would greatly appreciate any clarification on this matter, as it will
> help me better understand how to manage values when working with
> potentially repeated indices in the input.
> Thank you for your time and assistance.
> Best regards,
> Narayana Dhavala.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250114/f207d886/attachment.html>
