[petsc-users] building kokkos matrices on the device
Steven Dargaville
dargaville.steven at gmail.com
Wed Feb 26 06:26:01 CST 2025
Those two constructors would definitely meet my needs, thanks!
Also I should note that the comment about garray and B in
MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices is correct if garray is
passed in as NULL, it's just that if you pass in a completed garray it
doesn't bother creating one or changing the column indices of B. So I would
suggest the comment be: "if garray is NULL the offdiag matrix B should have
global col ids; if garray is not NULL the offdiag matrix B should have
local col ids"
On Wed, 26 Feb 2025 at 03:35, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Mat_SeqAIJKokkos is private because it is in a private header
> src/mat/impls/aij/seq/kokkos/aijkok.hpp
> Your observation about the garray in MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices()
> might be right. The comment
> - B - the offdiag matrix using global col ids
> is out of date. Perhaps it should be "the offdiag matrix uses local column
> indices and garray contains the local to global mapping". But I need to
> double check it.
> Since you use Kokkos, I think we could provide these two constructors for
> MATSEQAIJKOKKOS and MATMPIAIJKOKKOS respectively
> - MatCreateSeqAIJKokkosWithKokkosCsrMatrix(MPI_Comm comm,
> KokkosCsrMatrix csr, Mat *A)
> - MatCreateMPIAIJKokkosWithSeqAIJKokkos(MPI_Comm comm, Mat A, Mat B,
> PetscInt *garray, Mat *mat)
> // To mimic the existing MatCreateMPIAIJWithSeqAIJ(MPI_Comm comm,
> Mat A, Mat B, const PetscInt garray[], Mat *mat);
> // A and B are MATSEQAIJKOKKOS matrices and use local column
> indices
> Do they meet your needs?
> --Junchao Zhang
> On Tue, Feb 25, 2025 at 5:35 PM Steven Dargaville <
> dargaville.steven at gmail.com> wrote:
>> Thanks for the response!
>> Although MatSetValuesCOO happens on the device if the input coo_v pointer
>> is device memory, I believe MatSetPreallocationCOO requires host pointers
>> for coo_i and coo_j, and the preallocation (and construction of the COO
>> structures) happens on the host and is then copied onto the device? I need
>> to be able to create a matrix object with minimal work on the host (like
>> many of the routines in aijkok.kokkos.cxx do internally). I originally used
>> the COO interface to build the matrices I need, but that was around 5x
>> slower than constructing the aij structures myself on the device and then
>> just directly using the MatSetSeqAIJKokkosWithCSRMatrix type methods.
>> The reason I thought MatSetSeqAIJKokkosWithCSRMatrix could easily be made
>> public is that the Mat_SeqAIJKokkos constructors are already publicly
>> accessible? In particular one of those constructors takes in pointers to
>> the Kokkos dual views which store a,i,j, and hence one can build a
>> sequential matrix with nothing (or very little) occuring on the host. The
>> only change I can see that would be necessary is for
>> MatSetSeqAIJKokkosWithCSRMatrix (or MatCreateSeqAIJKokkosWithCSRMatrix) to
>> be public is to change the PETSC_INTERN to PETSC_EXTERN?
>> For MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices, I believe all that
>> is required is declaring the method in the .hpp, as it's already defined as
>> static in mpiaijkok.kokkos.cxx. In particular, the comments
>> above MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices suggest that the
>> off-diagonal block B needs to be built with global column ids, with
>> mpiaij->garray constructed on the host along with the rewriting of the
>> global column indices in B. This happens in MatSetUpMultiply_MPIAIJ, but
>> checking the code there shows that if you pass in a non-null garray to
>> MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices, the construction and
>> compatification is skipped, meaning B can be built with local column ids as
>> long as garray is provided on the host (which I also build on the device
>> and then just copy to the host). Again this is what some of the internal
>> Kokkos routines rely on, like the matrix-product.
>> I am happy to try doing this and submitting a request to the petsc gitlab
>> if this seems sensible, I just wanted to double check that I wasn't missing
>> something important?
>> Thanks
>> Steven
>> On Tue, 25 Feb 2025 at 22:16, Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Hi, Steven,
>>> MatSetSeqAIJKokkosWithCSRMatrix(Mat A, Mat_SeqAIJKokkos *akok) uses a
>>> private data type Mat_SeqAIJKokkos, so it can not be directly made public.
>>> If you already use COO, then why not directly make the matrix of type
>>> MATAIJKOKKOS and call MatSetPreallocationCOO() and MatSetValuesCOO()?
>>> So I am confused by your needs.
>>> Thanks!
>>> --Junchao Zhang
>>> On Tue, Feb 25, 2025 at 3:39 PM Steven Dargaville <
>>>> Hi
>>>> I'm just wondering if there is any possibility of making:
>>>> MatSetSeqAIJKokkosWithCSRMatrix or MatCreateSeqAIJKokkosWithCSRMatrix
>>>> in src/mat/impls/aij/seq/kokkos/aijkok.kokkos.cxx
>>>> MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices in
>>>> src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx
>>>> publicly accessible outside of petsc, or if there is an interface I
>>>> have missed for creating Kokkos matrices entirely on the device?
>>>> MatCreateSeqAIJKokkosWithCSRMatrix for example is marked as PETSC_INTERN so
>>>> I can't link to it.
>>>> I've currently just copied the code inside of those methods so that I
>>>> can build without any preallocation on the host (e.g., through the COO
>>>> interface) and it works really well.
>>>> Thanks for your help
>>>> Steven
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250226/9727d53e/attachment.html>
