[petsc-users] building kokkos matrices on the device
Junchao Zhang junchao.zhang at gmail.com
Tue Feb 25 21:35:07 CST 2025
Mat_SeqAIJKokkos is private because it is in a private header
src/mat/impls/aij/seq/kokkos/aijkok.hpp
Your observation about the garray in
MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices()
might be right.  The comment
- B - the offdiag matrix using global col ids
is out of date. Perhaps it should be "the offdiag matrix uses local column
indices and garray contains the local to global mapping".  But I need to
double check it.
Since you use Kokkos, I think we could provide these two constructors for
MATSEQAIJKOKKOS and MATMPIAIJKOKKOS respectively
   - MatCreateSeqAIJKokkosWithKokkosCsrMatrix(MPI_Comm comm,
   KokkosCsrMatrix csr, Mat *A)
   - MatCreateMPIAIJKokkosWithSeqAIJKokkos(MPI_Comm comm, Mat A, Mat B,
   PetscInt *garray, Mat *mat)
         // To mimic the existing MatCreateMPIAIJWithSeqAIJ(MPI_Comm comm,
Mat A, Mat B, const PetscInt garray[], Mat *mat);
         // A and B are MATSEQAIJKOKKOS matrices and use local column
indices
Do they meet your needs?
--Junchao Zhang
On Tue, Feb 25, 2025 at 5:35 PM Steven Dargaville <
dargaville.steven at gmail.com> wrote:
> Thanks for the response!
> Although MatSetValuesCOO happens on the device if the input coo_v pointer
> is device memory, I believe MatSetPreallocationCOO requires host pointers
> for coo_i and coo_j, and the preallocation (and construction of the COO
> structures) happens on the host and is then copied onto the device? I need
> to be able to create a matrix object with minimal work on the host (like
> many of the routines in aijkok.kokkos.cxx do internally). I originally used
> the COO interface to build the matrices I need, but that was around 5x
> slower than constructing the aij structures myself on the device and then
> just directly using the MatSetSeqAIJKokkosWithCSRMatrix type methods.
> The reason I thought MatSetSeqAIJKokkosWithCSRMatrix could easily be made
> public is that the Mat_SeqAIJKokkos constructors are already publicly
> accessible? In particular one of those constructors takes in pointers to
> the Kokkos dual views which store a,i,j, and hence one can build a
> sequential matrix with nothing (or very little) occuring on the host. The
> only change I can see that would be necessary is for
> MatSetSeqAIJKokkosWithCSRMatrix (or MatCreateSeqAIJKokkosWithCSRMatrix) to
> be public is to change the PETSC_INTERN to PETSC_EXTERN?
> For MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices, I believe all that is
> required is declaring the method in the .hpp, as it's already defined as
> static in mpiaijkok.kokkos.cxx. In particular, the comments
> above MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices suggest that the
> off-diagonal block B needs to be built with global column ids, with
> mpiaij->garray constructed on the host along with the rewriting of the
> global column indices in B. This happens in MatSetUpMultiply_MPIAIJ, but
> checking the code there shows that if you pass in a non-null garray to
> MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices, the construction and
> compatification is skipped, meaning B can be built with local column ids as
> long as garray is provided on the host (which I also build on the device
> and then just copy to the host). Again this is what some of the internal
> Kokkos routines rely on, like the matrix-product.
> I am happy to try doing this and submitting a request to the petsc gitlab
> if this seems sensible, I just wanted to double check that I wasn't missing
> something important?
> Thanks
> Steven
> On Tue, 25 Feb 2025 at 22:16, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Hi, Steven,
>>   MatSetSeqAIJKokkosWithCSRMatrix(Mat A, Mat_SeqAIJKokkos *akok) uses a
>> private data type Mat_SeqAIJKokkos, so it can not be directly made public.
>>   If you already use COO, then why not directly make the matrix of type
>> MATAIJKOKKOS and call MatSetPreallocationCOO() and MatSetValuesCOO()?
>>   So I am confused by your needs.
>> Thanks!
>> --Junchao Zhang
>> On Tue, Feb 25, 2025 at 3:39 PM Steven Dargaville <
>>> Hi
>>> I'm just wondering if there is any possibility of making:
>>> MatSetSeqAIJKokkosWithCSRMatrix or MatCreateSeqAIJKokkosWithCSRMatrix in
>>> src/mat/impls/aij/seq/kokkos/aijkok.kokkos.cxx
>>> MatSetMPIAIJKokkosWithSplitSeqAIJKokkosMatrices in
>>> src/mat/impls/aij/mpi/kokkos/mpiaijkok.kokkos.cxx
>>> publicly accessible outside of petsc, or if there is an interface I have
>>> missed for creating Kokkos matrices entirely on the device?
>>> MatCreateSeqAIJKokkosWithCSRMatrix for example is marked as PETSC_INTERN so
>>> I can't link to it.
>>> I've currently just copied the code inside of those methods so that I
>>> can build without any preallocation on the host (e.g., through the COO
>>> interface) and it works really well.
>>> Thanks for your help
>>> Steven
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250225/70215236/attachment.html>
