[petsc-users] Advice on identifying boundary vertices
    Aldo Bonfiglioli
    aldo.bonfiglioli at unibas.it
    Sat Feb 15 10:37:18 CST 2025
Dear all,
I am trying to identify the boundary vertices that belong to a given
stratum of the Face sets. This is going to be used to prescribe
Dirichlet-type bcs.
I can select the boundary faces (edges in 2D) of a given stratum using
PetscCall(DMLabelGetStratumIS(label, stratum, user%bndryfaces(i), ierr))
and that looks ok;
I then try to identify the boundary vertices by looping over the points
(edges in 2D/faces in 3D) of the face set of a given stratum and
retrieve the vertices that make up each individual edge/face.
For reasons I fail to understand, the above procedure fails to identify
certain vertices (those circled in the enclosed pdf where different
colours mark different ranks) in a parallel environment.
Questions:
1. is there an available function that does what I am trying to do? I
know that the boundary points can be found in the "marker" label, but I
need to discriminate among Face Sets of different strata.
2. what might be wrong in the aforementioned approach?
Aldo
Dr. Aldo Bonfiglioli
Associate professor of Fluid Machines
Scuola di Ingegneria
Universita' della Basilicata
V.le dell'Ateneo lucano, 10 85100 Potenza ITALY
tel:+39.0971.205203 fax:+39.0971.205215
web: https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!YLL7mzBlK9H_sEdtXob1AVklf8cVLhT3NTDdExIZsdI3xMfNHBoLXr92BmYzCXOuJqtm2L6OU4DJKV_81AkjvQf-Kra-Ym8P0tU$
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250215/391457f2/attachment-0001.pdf>
