[petsc-users] Question regarding SNES error about locked vectors
Stefano Zampini
stefano.zampini at gmail.com
Wed Dec 17 13:02:21 CST 2025
You are not allowed to call VecGetArray on the solution vector of an SNES
object within a user callback, nor to modify its values in any other way.
Put in C++ lingo, the solution vector is a "const" argument
It would be great if you could provide an MWE to help us understand your
problem
Il giorno mer 17 dic 2025 alle ore 20:51 David Knezevic via petsc-users <
petsc-users at mcs.anl.gov> ha scritto:
> Hi all,
> I have a question about this error:
>> Vector 'Vec_0x84000005_0' (argument #2) was locked for read-only access
>> in unknown_function() at unknown file:0 (line numbers only accurate to
>> function begin)
> I'm encountering this error in an FE solve where there is an error
> encountered during the residual/jacobian assembly, and what we normally do
> in that situation is shrink the load step and continue, starting from the
> "last converged solution". However, in this case I'm running on 32
> processes, and 5 of the processes report the error above about a "locked
> vector".
> We clear the SNES object (via SNESDestroy) before we reset the solution to
> the "last converged solution", and then we make a new SNES object
> subsequently. But it seems to me that somehow the solution vector is still
> marked as "locked" on 5 of the processes when we modify the solution
> vector, which leads to the error above.
> I was wondering if someone could advise on what the best way to handle
> this would be? I thought one option could be to add an MPI barrier call
> prior to updating the solution vector to "last converged solution", to make
> sure that the SNES object is destroyed on all procs (and hence the locks
> cleared) before editing the solution vector, but I'm unsure if that would
> make a difference. Any help would be most appreciated!
> Thanks,
> David
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251217/4074371e/attachment.html>
