[petsc-users] Question regarding SNES error about locked vectors
David Knezevic
david.knezevic at akselos.com
Wed Dec 17 11:50:18 CST 2025
Hi all,
I have a question about this error:
> Vector 'Vec_0x84000005_0' (argument #2) was locked for read-only access in
> unknown_function() at unknown file:0 (line numbers only accurate to
> function begin)
I'm encountering this error in an FE solve where there is an error
encountered during the residual/jacobian assembly, and what we normally do
in that situation is shrink the load step and continue, starting from the
"last converged solution". However, in this case I'm running on 32
processes, and 5 of the processes report the error above about a "locked
vector".
We clear the SNES object (via SNESDestroy) before we reset the solution to
the "last converged solution", and then we make a new SNES object
subsequently. But it seems to me that somehow the solution vector is still
marked as "locked" on 5 of the processes when we modify the solution
vector, which leads to the error above.
I was wondering if someone could advise on what the best way to handle this
would be? I thought one option could be to add an MPI barrier call prior to
updating the solution vector to "last converged solution", to make sure
that the SNES object is destroyed on all procs (and hence the locks
cleared) before editing the solution vector, but I'm unsure if that would
make a difference. Any help would be most appreciated!
David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251217/30e819e4/attachment.html>
