[petsc-users] Question about Pseudo Time Stepping
Aldo Bonfiglioli
aldo.bonfiglioli at unibas.it
Sat Aug 30 16:42:19 CDT 2025
Barry,
thank you for the update.
Aldo
*Aldo Bonfiglioli*
Professore associato di Fluidodinamica settore scientifico disciplinare
IIND-01/F
Dipartimento di Ingegneria
Viale dell'Ateneo Lucano, 10 85100 Potenza
Tel: 0971.205203
Il ven 29 ago 2025, 20:52 Barry Smith <barryfsmith at icloud.com> ha scritto:
> Aldo,
> I understand the situation you are facing.
> With pseudo-continuation, when you provide an RHS function, SNES is
> computing udot -
> F(u). Inside the SNESSolve(), specifically in TSComputeIFunction(), with
> the lines
> if (!ts->ops->ifunction) {
> ierr = TSComputeRHSFunction(ts,t,X,Y);CHKERRQ(ierr);
> ierr = VecAYPX(Y,-1,Xdot);CHKERRQ(ierr);
> But for the original system, we care about the norm for F(u). So in
> TSStep_Pseudo(), after the nonlinear solve
> there is the line
> pseudo->fnorm = -1; /* The current norm is no longer valid, monitor
> must recompute it. */
> and further down
> if (pseudo->fnorm < 0) {
> PetscCall(VecZeroEntries(pseudo->xdot));
> PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol, pseudo->xdot,
> pseudo->func, PETSC_FALSE));
> PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
> this norm is needed to determine of the nonlinear system has converged
> satisfactory (or if more pseudo time steps are needed).
> Hence, your FormRHSFunction gets called twice with identical input.
> To make matters even worse your FormRHSFunction is actually being called
> THREE times with identical input. Because at the start of TSStep_Pseudo()
> it calls TSPseudoComputeTimeStep(ts, &next_time_step) which by default
> uses TSPseudoTimeStepDefault() which has the same chunk of code
> And the same norm is also recomputed.
> Now the diff
> diff --git a/src/ts/impls/pseudo/posindep.c
> b/src/ts/impls/pseudo/posindep.c
> index 7c013435f98..813a28311e7 100644
> --- a/src/ts/impls/pseudo/posindep.c
> +++ b/src/ts/impls/pseudo/posindep.c
> @@ -660,9 +660,11 @@ PetscErrorCode TSPseudoTimeStepDefault(TS ts,
> PetscReal *newdt, void *dtctx)
> PetscReal inc = pseudo->dt_increment;
> PetscFunctionBegin;
> - PetscCall(VecZeroEntries(pseudo->xdot));
> - PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol, pseudo->xdot,
> - PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
> + if (pseudo->fnorm < 0.0) {
> + PetscCall(VecZeroEntries(pseudo->xdot));
> + PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol,
> pseudo->xdot, pseudo->func, PETSC_FALSE));
> + PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
> if (pseudo->fnorm_initial < 0) {
> /* first time through so compute initial function norm */
> pseudo->fnorm_initial = pseudo->fnorm
> will prevent the THIRD computation of the same function evaluation. So
> this is a good optimization
> But eliminating the second computation is not so trivial. To review, deep
> inside the TS code there is
> VecAYPX(Y,-1,Xdot);
> This code knows nothing about TSPPseudo etc.
> Then later in the Pseudo code
> again calls TSComputeRHSFunction(ts,t,X,Y); with the same X. (since Xdot
> is not used directly by TSComputeRHSFunction()).
> Now if all the code was custom for Pseudo we could simply put in a line
> VecNorm(Y,NORM_2, &pseudo->fnorm)
> VecAYPX(Y,-1,Xdot);
> into TSComputeIFunction() and have the norm available later for pseudo.
> It is not clear that there is any definitive benefit for pseudo to utilize
> the TS framework. It possibly gets some code reuse from TS but at the cost
> of extra code that won't be needed if written directly. Plus this
> performance hit.
> Anyways I will make a merge request to remove the third redundant
> computation of FormRHSFunction but will await input from others on if
> anything else could be done to remove the inefficiency.
> Thanks for reporting this challenging problem.
> Barry
> Note: I don't think providing the Jacobian improves the efficiency, it is
> just better at hiding the redundant computation.
> On Aug 26, 2025, at 4:21 AM, Aldo Bonfiglioli <aldo.bonfiglioli at unibas.it>
> wrote:
> Hi there,
> I am using -ts_type pseudo to find steady solutions of the Euler/NS PDEs.
> It looks like FormRHSFunction is called twice with the exactly same value
> of the dependent variable (u)
> before invoking TSRHSJacobianFn and then solving the linear system with
> KSP (u is then updated)
> 1 TS dt 0.141197 time 0.141197
> Calling FormRHSFunction; ||u|| = 60.489405479528003
> 463.15635675129079 62.813532026019146
> 5.9789502719351155
> 5.9789502719351155
> Calling TSRHSJacobianFn with ||u|| = 60.489405479528003
> 5.9789502719351155
> Linear solve converged due to CONVERGED_RTOL iterations 9
> Calling FormRHSFunction; ||u|| = 60.489405476878737
> 463.15635675602186 62.813532031616965 5.9789502710519811
> 2 TS dt 0.155917 time 0.297115
> Calling TSRHSJacobianFn with ||u|| = 60.489405476878737
> Why is it so? Am I possibly misusing (or missing) some options?
> My .petscrc file is attached.
> Thank you,
> Aldo
> Dr. Aldo Bonfiglioli
> Associate professor of Fluid Mechanics
> Universita' della Basilicata
> V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY <https://urldefense.us/v3/__https://www.google.com/maps/search/dell'Ateneo*Lucano,*10*85100*Potenza*ITALY?entry=gmail&source=g__;KysrKys!!G_uCfscf7eWS!cZ77DpN-ZOmpsgsHdMBQK2uUmuwgxPNkFjRagyCeSOxwLdNzcF4P6MSOrFAI0DkC-mAR9S9bUYDAYLbaid8o_doR6zJYm8OSexM$ >
> tel:+39.0971.205203 fax:+39.0971.205215
> web: https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!cZ77DpN-ZOmpsgsHdMBQK2uUmuwgxPNkFjRagyCeSOxwLdNzcF4P6MSOrFAI0DkC-mAR9S9bUYDAYLbaid8o_doR6zJYMQyUmBE$ <https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!ci_aySHdF2Qx_B-37IOzELFDtcQRthJ2NItK-JNbfXB0M2_21B_z97WIfjxZUyKCVRRhd1mzL6b-rnCed_i8LLA56JvFdz7JBrw$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250830/ce9a4313/attachment-0001.html>
