[petsc-users] Question about Pseudo Time Stepping
Barry Smith
barryfsmith at icloud.com
Fri Aug 29 13:52:39 CDT 2025
Aldo,
I understand the situation you are facing.
With pseudo-continuation, when you provide an RHS function, SNES is computing udot -
F(u). Inside the SNESSolve(), specifically in TSComputeIFunction(), with the lines
if (!ts->ops->ifunction) {
ierr = TSComputeRHSFunction(ts,t,X,Y);CHKERRQ(ierr);
ierr = VecAYPX(Y,-1,Xdot);CHKERRQ(ierr);
But for the original system, we care about the norm for F(u). So in TSStep_Pseudo(), after the nonlinear solve
there is the line
pseudo->fnorm = -1; /* The current norm is no longer valid, monitor must recompute it. */
and further down
if (pseudo->fnorm < 0) {
PetscCall(VecZeroEntries(pseudo->xdot));
PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol, pseudo->xdot, pseudo->func, PETSC_FALSE));
PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
this norm is needed to determine of the nonlinear system has converged satisfactory (or if more pseudo time steps are needed).
Hence, your FormRHSFunction gets called twice with identical input.
To make matters even worse your FormRHSFunction is actually being called THREE times with identical input. Because at the start of TSStep_Pseudo() it calls TSPseudoComputeTimeStep(ts, &next_time_step) which by default uses TSPseudoTimeStepDefault() which has the same chunk of code
And the same norm is also recomputed.
Now the diff
diff --git a/src/ts/impls/pseudo/posindep.c b/src/ts/impls/pseudo/posindep.c
index 7c013435f98..813a28311e7 100644
--- a/src/ts/impls/pseudo/posindep.c
+++ b/src/ts/impls/pseudo/posindep.c
@@ -660,9 +660,11 @@ PetscErrorCode TSPseudoTimeStepDefault(TS ts, PetscReal *newdt, void *dtctx)
PetscReal inc = pseudo->dt_increment;
PetscFunctionBegin;
- PetscCall(VecZeroEntries(pseudo->xdot));
- PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol, pseudo->xdot, pseudo->func, PETSC_FALSE));
- PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
+ if (pseudo->fnorm < 0.0) {
+ PetscCall(VecZeroEntries(pseudo->xdot));
+ PetscCall(TSComputeIFunction(ts, ts->ptime, ts->vec_sol, pseudo->xdot, pseudo->func, PETSC_FALSE));
+ PetscCall(VecNorm(pseudo->func, NORM_2, &pseudo->fnorm));
if (pseudo->fnorm_initial < 0) {
/* first time through so compute initial function norm */
pseudo->fnorm_initial = pseudo->fnorm
will prevent the THIRD computation of the same function evaluation. So this is a good optimization
But eliminating the second computation is not so trivial. To review, deep inside the TS code there is
VecAYPX(Y,-1,Xdot);
This code knows nothing about TSPPseudo etc.
Then later in the Pseudo code
again calls TSComputeRHSFunction(ts,t,X,Y); with the same X. (since Xdot is not used directly by TSComputeRHSFunction()).
Now if all the code was custom for Pseudo we could simply put in a line
VecNorm(Y,NORM_2, &pseudo->fnorm)
VecAYPX(Y,-1,Xdot);
into TSComputeIFunction() and have the norm available later for pseudo.
It is not clear that there is any definitive benefit for pseudo to utilize the TS framework. It possibly gets some code reuse from TS but at the cost of extra code that won't be needed if written directly. Plus this performance hit.
Anyways I will make a merge request to remove the third redundant computation of FormRHSFunction but will await input from others on if anything else could be done to remove the inefficiency.
Thanks for reporting this challenging problem.
Barry
Note: I don't think providing the Jacobian improves the efficiency, it is just better at hiding the redundant computation.
> On Aug 26, 2025, at 4:21 AM, Aldo Bonfiglioli <aldo.bonfiglioli at unibas.it> wrote:
> Hi there,
> I am using -ts_type pseudo to find steady solutions of the Euler/NS PDEs.
> It looks like FormRHSFunction is called twice with the exactly same value of the dependent variable (u)
> before invoking TSRHSJacobianFn and then solving the linear system with KSP (u is then updated)
>> 1 TS dt 0.141197 time 0.141197
>> Calling FormRHSFunction; ||u|| = 60.489405479528003 463.15635675129079 62.813532026019146 5.9789502719351155
>> Calling TSRHSJacobianFn with ||u|| = 60.489405479528003 463.15635675129079 62.813532026019146 5.9789502719351155
>> Linear solve converged due to CONVERGED_RTOL iterations 9
>> Calling FormRHSFunction; ||u|| = 60.489405476878737 463.15635675602186 62.813532031616965 5.9789502710519811
>> 2 TS dt 0.155917 time 0.297115
>> Calling TSRHSJacobianFn with ||u|| = 60.489405476878737 463.15635675602186 62.813532031616965 5.9789502710519811
> Why is it so? Am I possibly misusing (or missing) some options?
> My .petscrc file is attached.
> Thank you,
> Aldo
> Dr. Aldo Bonfiglioli
> Associate professor of Fluid Mechanics
> Dipartimento di Ingegneria
> Universita' della Basilicata
> V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
> tel:+39.0971.205203 fax:+39.0971.205215
> web: https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!acYbzJhys-2ITKblPtrsEnhe2r7CNdFSDaXF2nMHOEw5-ee_VvldwIA-zUDXIwE1-ygMTV054Xm0g3bENdHOkmXWePU$ <https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!ci_aySHdF2Qx_B-37IOzELFDtcQRthJ2NItK-JNbfXB0M2_21B_z97WIfjxZUyKCVRRhd1mzL6b-rnCed_i8LLA56JvFdz7JBrw$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250829/add5e5ca/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250829/add5e5ca/attachment.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250829/add5e5ca/attachment-0001.html>
