[petsc-users] Error compiling with cuda
Renato E Poli rpoli at utexas.edu
Sat Aug 2 12:12:21 CDT 2025
 Understood.
I believe I am running in circles.
I managed to create the container, but it ended up with multiple MPI
implementations.
It seems that CUDA SDK has its own MPI, and polutes the PATH.
Is there any docker container PETSC+CUDA you would recommend?
This is a snippet of my Dockerfile, but I am not 100% happy with it.
FROM docker.io/ubuntu:24.04
# Install necessary build tools and dependencies
RUN apt-get update && apt-get install -y  libmpich-dev   gfortran
libomp-dev  (...)
## NVIDIA HPC SDK
RUN wget
https://urldefense.us/v3/__https://developer.download.nvidia.com/hpc-sdk/25.5/nvhpc_2025_255_Linux_x86_64_cuda_12.9.tar.gz__;!!G_uCfscf7eWS!ft2AAfoKdKf-j-6E6nTqtzXHqQEmnbsH7as3hylOIpz7OiONASpD-qNuRNcnDapAFok1YeTP2lLQfH7ne1cFSw$
    tar xpzfv nvhpc_2025_255_Linux_x86_64_cuda_12.9.tar.gz &&
    nvhpc_2025_255_Linux_x86_64_cuda_12.9/install --silent --accept-license
--instal-dir /opt/nvidia/hpc_sdk
RUN cd petsc-3.23.5 &&\
    ./configure --prefix=/usr/local/petsc  --PETSC_ARCH=arch-linux-c-opt
--with-debugging=0 \
        --with-mpi --download-hypre --with-blaslapack --with-cuda
        --with-cuda-dir=/opt/nvidia/hpc_sdk/Linux_x86_64/25.5/cuda  && \
    make all install && \
    cd ..
ENV PATH=${NVHPC_ROOT}/compilers/bin:${NVHPC_ROOT}/comm_libs/mpi/bin:${PATH}
ENV MANPATH=${NVHPC_ROOT}/compilers/man:${MANPATH}
ENV LD_LIBRARY_PATH=${NVHPC_ROOT}/compilers/lib:${LD_LIBRARY_PATH}
Renato
On Sat, Aug 2, 2025 at 11:11 AM Satish Balay <balay.anl at fastmail.org> wrote:
> Please send configure.log
> presumably you are using a pre-installed mpi from hpc-sdk - that uses NV
> compilers. [and PETSc configure is defaulting to mpicc/mpif90 in PATH]
> If you do not have MPI with gcc/gfortran - you can do something like:
> ./configure --with-cuda=1 --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-mpich [other options]
> When no options are specified - configure guesses - and picks up what it
> can find - and sometimes that might not be what you intend to use..
> Satish
> On Sat, 2 Aug 2025, Renato E Poli wrote:
> > It seems that the installer is the one choosing to use nvfortran instead
> of
> > gfortran.
> > I am building a docker container (clean environment).
> > I simply install CUDA SDK from
> https://urldefense.us/v3/__https://developer.download.nvidia.com/hpc-sdk/25.5/nvhpc_2025_255_Linux_x86_64_cuda_12.9.tar.gz__;!!G_uCfscf7eWS!cBTymZpXcpFZ7BHpCGxn0ooq_STD1f9CioiFgRypIYNWg9lpwnmLpddrWk0-J-wQoeTw9Ipu2FPm037mQg_C2w$
> > , set paths and call petsc configure.
> >     ./configure --prefix=/usr/local/petsc  --with-debugging=0  --with-mpi
> > --download-hdf5   --download-hypre  --with-blaslapack   --with-cuda && \
> >     make all && make install
> > Do you see any reason for using the wrong compiler?
> > Renato
> > On Sat, Aug 2, 2025 at 12:28 AM Satish Balay <balay.anl at fastmail.org>
> wrote:
> > > NVFORTRAN (based on flang-17) does not support some F2008 features that
> > > are required here (flang-19+ should work)
> > > Suggest using gfortran instead.
> > > Satish
> > > On Fri, 1 Aug 2025, Renato E Poli wrote:
> > > >  Hi,
> > > > I see the error below when compiling with --with-cuda.
> > > > Any suggestion?
> > > >          CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/inode2.o
> > > >          CC
> arch-linux-c-opt/obj/src/mat/impls/aij/seq/aijperm/aijperm.o
> > > >          CC
> > > arch-linux-c-opt/obj/src/mat/impls/aij/seq/mattransposematmult.o
> > > >          CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/matptap.o
> > > >          CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/matrart.o
> > > >          FC arch-linux-c-opt/obj/src/sys/ftn-mod/petscsysmod.o
> > > > NVFORTRAN-S-0034-Syntax error at or near end of line
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscsys.h: 6)
> > > 18)
> > > 30)
> > > 42)
> > > 54)
> > > 65)
> > > 76)
> > > 88)
> > > 100)
> > > 112)
> > > 124)
> > > 136)
> > > 148)
> > > 160)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscviewer.h: 6)
> > > > 17)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscoptions.h:
> > > > 6)
> > > > 18)
> > > > 30)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petsclog.h: 5)
> > > 17)
> > > 29)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscdevice.h: 6)
> > > > 17)
> > > >   0 inform,   0 warnings,  24 severes, 0 fatal for petscsysdef
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250802/87ea3f57/attachment.html>
