[petsc-users] Error compiling with cuda
Satish Balay
balay.anl at fastmail.org
Sat Aug 2 11:11:48 CDT 2025
Please send configure.log
presumably you are using a pre-installed mpi from hpc-sdk - that uses NV compilers. [and PETSc configure is defaulting to mpicc/mpif90 in PATH]
If you do not have MPI with gcc/gfortran - you can do something like:
./configure --with-cuda=1 --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich [other options]
When no options are specified - configure guesses - and picks up what it can find - and sometimes that might not be what you intend to use..
Satish
On Sat, 2 Aug 2025, Renato E Poli wrote:
> It seems that the installer is the one choosing to use nvfortran instead of
> gfortran.
> I am building a docker container (clean environment).
> I simply install CUDA SDK from
> https://urldefense.us/v3/__https://developer.download.nvidia.com/hpc-sdk/25.5/nvhpc_2025_255_Linux_x86_64_cuda_12.9.tar.gz__;!!G_uCfscf7eWS!cBTymZpXcpFZ7BHpCGxn0ooq_STD1f9CioiFgRypIYNWg9lpwnmLpddrWk0-J-wQoeTw9Ipu2FPm037mQg_C2w$
> , set paths and call petsc configure.
> RUN cd petsc-3.23.5 &&\
> ./configure --prefix=/usr/local/petsc --with-debugging=0 --with-mpi
> --download-hdf5 --download-hypre --with-blaslapack --with-cuda && \
> make all && make install
> Do you see any reason for using the wrong compiler?
> Renato
> On Sat, Aug 2, 2025 at 12:28 AM Satish Balay <balay.anl at fastmail.org> wrote:
> > NVFORTRAN (based on flang-17) does not support some F2008 features that
> > are required here (flang-19+ should work)
> > Suggest using gfortran instead.
> > Satish
> > On Fri, 1 Aug 2025, Renato E Poli wrote:
> > > Hi,
> > > I see the error below when compiling with --with-cuda.
> > > Any suggestion?
> > > CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/inode2.o
> > > CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/aijperm/aijperm.o
> > > CC
> > arch-linux-c-opt/obj/src/mat/impls/aij/seq/mattransposematmult.o
> > > CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/matptap.o
> > > CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/matrart.o
> > > FC arch-linux-c-opt/obj/src/sys/ftn-mod/petscsysmod.o
> > > NVFORTRAN-S-0034-Syntax error at or near end of line
> > > (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscsys.h: 6)
> > 18)
> > 30)
> > 42)
> > 54)
> > 65)
> > 76)
> > 88)
> > 100)
> > 112)
> > 124)
> > 136)
> > 148)
> > 160)
> > (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscviewer.h: 6)
> > > 17)
> > (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscoptions.h:
> > > 6)
> > > 18)
> > > 30)
> > > (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petsclog.h: 5)
> > 17)
> > 29)
> > (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscdevice.h: 6)
> > > 17)
> > > 0 inform, 0 warnings, 24 severes, 0 fatal for petscsysdef
