[petsc-users] problem with nested logging
    Junchao Zhang
    junchao.zhang at gmail.com
    Sat Apr 26 08:51:57 CDT 2025
Toby (Cc'ed) might know it.  Or could you provide an example?
--Junchao Zhang
On Fri, Apr 25, 2025 at 3:31 AM Klaij, Christiaan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> We recently upgraded from 3.19.4 to 3.22.4 but face the problem below with
> the nested logging. Any ideas?
> Chris
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: General MPI error
> [1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!f64jR8FwcQdcTxYskijm4-CJ5UqGKAC-HRru1lRJXB558lncnm34NquLCRjFYnofEAp_ylqjbPxnKjJxuRyJXJ0UQMzn$
> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM3UaqHzc$>
> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> [1]PETSC ERROR: refresco with 2 MPI process(es) and PETSC_ARCH on
> marclus3login2 by jwindt Fri Apr 25 08:52:30 2025
> [1]PETSC ERROR: Configure options:
> --prefix=/home/jwindt/cmake_builds/refresco/install-libs-gnu
> --with-mpi-dir=/cm/shared/apps/openmpi/gcc/4.0.2 --with-x=0 --with-mpe=0
> --with-debugging=0 --download-superlu_dist=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!f64jR8FwcQdcTxYskijm4-CJ5UqGKAC-HRru1lRJXB558lncnm34NquLCRjFYnofEAp_ylqjbPxnKjJxuRyJXBC6iON-$
> <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM21-2D-o$>
> --with-blaslapack-dir=/cm/shared/apps/intel/oneapi/mkl/2021.4.0
> --download-parmetis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!f64jR8FwcQdcTxYskijm4-CJ5UqGKAC-HRru1lRJXB558lncnm34NquLCRjFYnofEAp_ylqjbPxnKjJxuRyJXNfbyQij$
> <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMW0lYHko$>
> --download-metis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!f64jR8FwcQdcTxYskijm4-CJ5UqGKAC-HRru1lRJXB558lncnm34NquLCRjFYnofEAp_ylqjbPxnKjJxuRyJXAjPuW1M$
> <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMbSrIiUg$>
> --with-packages-build-dir=/home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild
> --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops
> -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime
> -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops
> -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops
> [1]PETSC ERROR: #1 PetscLogNestedTreePrint() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:330
> [1]PETSC ERROR: #2 PetscLogNestedTreePrint() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [1]PETSC ERROR: #3 PetscLogNestedTreePrint() at
> [1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> [1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> [1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> [1]PETSC ERROR: #7 PetscLogHandlerView() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> [1]PETSC ERROR: #8 PetscLogView() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/plog.c:2040
> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
> with errorcode 98.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> dr. ir.  Christiaan  Klaij
>  |  senior researcher  |  Research & Development  |  CFD Development
> T +31 317 49 33 44 <+31%20317%2049%2033%2044>  |   C.Klaij at marin.nl  |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!f64jR8FwcQdcTxYskijm4-CJ5UqGKAC-HRru1lRJXB558lncnm34NquLCRjFYnofEAp_ylqjbPxnKjJxuRyJXPv1evZa$
> <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM8tSNH1g$>
> [image: Facebook]
> <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMcVCZ9hk$>
> [image: LinkedIn]
> <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMIDBZW7k$>
> [image: YouTube]
> <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMVKWos24$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250426/93b3c096/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250426/93b3c096/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250426/93b3c096/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250426/93b3c096/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250426/93b3c096/attachment-0007.png>
