[petsc-users] problem with nested logging
    Klaij, Christiaan
    C.Klaij at marin.nl
    Fri Apr 25 03:30:58 CDT 2025
We recently upgraded from 3.19.4 to 3.22.4 but face the problem below with the nested logging. Any ideas?
Chris
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: General MPI error
[1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
[1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM3UaqHzc$  for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
[1]PETSC ERROR: refresco with 2 MPI process(es) and PETSC_ARCH  on marclus3login2 by jwindt Fri Apr 25 08:52:30 2025
[1]PETSC ERROR: Configure options: --prefix=/home/jwindt/cmake_builds/refresco/install-libs-gnu --with-mpi-dir=/cm/shared/apps/openmpi/gcc/4.0.2 --with-x=0 --with-mpe=0 --with-debugging=0 --download-superlu_dist=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM21-2D-o$  --with-blaslapack-dir=/cm/shared/apps/intel/oneapi/mkl/2021.4.0 --download-parmetis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMW0lYHko$  --download-metis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMbSrIiUg$  --with-packages-build-dir=/home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall -funroll-all-loops  -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops  -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops  -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops  -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG"
[1]PETSC ERROR: #1 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:330
[1]PETSC ERROR: #2 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
[1]PETSC ERROR: #3 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
[1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
[1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
[1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
[1]PETSC ERROR: #7 PetscLogHandlerView() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
[1]PETSC ERROR: #8 PetscLogView() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/plog.c:2040
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 98.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
dr. ir. Christiaan Klaij
 | senior researcher | Research & Development | CFD Development
T +31 317 49 33 44 |  C.Klaij at marin.nl | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMejNgRbQ$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250425/8774536d/attachment-0001.html>
Type: image/png
Desc: image898428.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250425/8774536d/attachment-0004.png>
Type: image/png
Desc: image714119.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250425/8774536d/attachment-0005.png>
Type: image/png
Desc: image138727.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250425/8774536d/attachment-0006.png>
Type: image/png
Desc: image471093.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250425/8774536d/attachment-0007.png>
